Projects Henry J Southeast Gassers build
Discussion in 'The Hokey Ass Message Board' started by Uncledirty616, Jan 16, 2016.
  1. Uncledirty616
    Uncledirty616
    Yes, it's a Biondo. A friend said he had decent luck with one, and my funds are getting LOW.
    loudbang and Higgy's Henry like this.
  2. Uncledirty616
    Uncledirty616
    Yeah i will post pics the day i do it. It would have been today, but i was prepping the cage for final welding tonight.
  3. saltflats
    saltflats
    from Missouri
    Took out the ring gear bolts.
    Going with a Pontiac now.
  4. Dog_Patch
    Dog_Patch
    Those are probably OK the Jegs brand ones failed on everyone we run with.
  5. southcross2631
    southcross2631
    If it's a Biondo . It will be fine. Did not mean to put a scare into you but I learned my lesson trying to save money on a line lock.
    Dog_Patch, loudbang and Uncledirty616 like this.
  6. Uncledirty616
    Uncledirty616
    bummer man.
  7. Uncledirty616
    Uncledirty616
    appreciated either way
  8. Uncledirty616
    Uncledirty616
    A friend came in and finished TIG welding the cage the other night. Can finally start ***embly on the car. Was bending brake lines tonight but no photos , so heres the finished cage. PS sorry the shop is a disaster, im in whirlwind mode lol cage finished.jpg
  9. saltflats
    saltflats
    from Missouri
    Gettin closer to some front wheel hand time!!!
  10. Uncledirty616
    Uncledirty616
    Purchased a paint gun from work with the intentions of getting the car into one color. decided to try tinting the windows also first window.jpg windows painted.jpg
    Gammz, Dog_Patch, saltflats and 4 others like this.
  11. Uncledirty616
    Uncledirty616
    Then spent the rest of the day prepping and "painting" the car. Which by the way was supposed to be black...so why is it gray? Ps the wife has decided she loves body work and wants to fix the body and repaint the car lol No joke she really does. cage masked off.jpg me door jams.jpg wife painting.jpg painted.jpg
  12. southcross2631
    southcross2631
    Looks like a good color to race all the bugs out and paint this winter if you want to race this season.
  13. Uncledirty616
    Uncledirty616
    Im warming up to the color. Cleaned the garage tonight in preparation painted side view.jpg for ***embling the short block tomorrow. In doing so i had to pull the covers off the car just to have a peak.
  14. Uncledirty616
    Uncledirty616
    Started engine ***embly today. Got the general block prep done and then got the crank in. From there i started to set up the clutch. I figured it would be much easier on the bench then in the car. block.jpg table lifters.jpg
  15. Uncledirty616
    Uncledirty616
    Hated to do it , but need to make "adjustments" to my bellhousing so i can adjust the clutch. press plate adjust.jpg feeler clutch.jpg
  16. Uncledirty616
    Uncledirty616
    And then after doing that i indicated in the Bellhousing mouth to see if it's concentric to the Crank. I have .006 of runout. so i will have to correct it. indicating in.jpg
  17. Higgy's Henry
    Higgy's Henry
    I do see your name on the pre entry list!!!!! C'mon man!! YOU CAN DOOOO IT!!!!!
    powrshftr and loudbang like this.
  18. Dog_Patch
    Dog_Patch
    If everyone on the planet has to measure the air gap, why don't these come with a hole - or plate to get access?
  19. Gammz
    Gammz
    from Lincoln Ne
    How did that work out. Kid and I want to do the windows in our car. We are thinking tinted plexigl*** or lexan. If paint tint looks just as good and is maybe cheaper I'd be willing to give it a try.
  20. Uncledirty616
    Uncledirty616
    There are some out there that do. With us using adjustable clutches it helps to have the access holes. I tried it without, and its alot of extra work
  21. Uncledirty616
    Uncledirty616
    Not bad i **** at spraying so mine have stripes, but they look pretty good none the less. I did cheat though. Im not using paint, i have a friend who owns a paint shop, he mixed clear with a paint "tinter" that is transparent. so it made it easier.
    Hang'emHigh and loudbang like this.
  22. southcross2631
    southcross2631
    Does anybody remember the spray on tint that came in spray cans? I did a 55 Belair back in 69 and it came out perfect except for the fly that landed on it and crawled around and died before it dryed.
    Bought it at Western Auto. Strawberry red tint on a red and white Belair hardtop with Crager SS mags.
  23. Higgy's Henry
    Higgy's Henry
    Thats what I used....VHT nightshade. Red of course!
  24. Fiddle Picker
    Fiddle Picker
    I did the same years ago. The instructions said, start at the top edge and spray till it runs, then continue feeding the run all the way to the bottom to get even coverage ( smoke tint on my 46 Chevy Coupe, 327 w/4 speed, loved it). Worked good back then. This time thought of trying it out on a piece of s**** first. When I spray tinted my head lights for my Stude G***er, didn't have to run it down and it covered even. I used Duplicolor Metal-Cast red. Probably the same stuff as Night Shades. Keep up the good work !!
  25. Uncledirty616
    Uncledirty616
    I will check tomorrow, i think Napa Sells nightshade
  26. loudbang and Higgy's Henry like this.
  27. Fancy drill press! I was more like a 1/2 hand drill with a unibit. :D
  28. II FUNNY
    II FUNNY
    Duplicolor metalcast paint works good for headlights and windows and is available in a bunch of colors.
    loudbang and Fiddle Picker like this.
  29. II FUNNY
    II FUNNY
  30. II FUNNY
    II FUNNY
    I used the blue when I built this.
