Hot Rods metal to fiberglass
Discussion in 'The Hokey Ass Message Board' started by Lake Modified, Jun 21, 2017.
  1. Lake Modified
    Lake Modified
    I want to use aluminum sheeting for the interior of my T-bucket. Would there be any issues fiber-gl***ing aluminum or steel square tubing to the interior walls of the fibergl*** body to give me a base to rivet the aluminum sheet to?
    Thanks
    Sm
  2. steinauge
    steinauge
    from 1960
    I would make sure your aluminum or steel was very clean and had a rough surface.I had to gl*** a couple of pieces of 1" square steel tubing into a fibergl*** body once and that was what I learned about the process.By "rough surface" I mean about 36 grit.
  3. K13
    K13
    Use an epoxy based panel bonding adhesive. It will be much stronger than fibergl***ing it. You can get some from Evercoat that can be used in a caulking gun if you don't have access to the side by side gun that most use..
    http://www.evercoat.com/adhesives-sealants/us/
    loudbang, Hatchet and anthony myrick like this.
  4. VTjunk
    VTjunk
    SEM 39747 Panel Adhesive. This is why body shops don't use welders much anymore. Everything is glued on. It's tough.
    This stuff is made for steel, aluminum, wood, fibergl***, etc.
    loudbang and Hatchet like this.
  5. Lake Modified
    Lake Modified
    Thanks very much for the responses. Learning new stuff everyday.
    SM
  6. HOTRODPRIMER
    HOTRODPRIMER
    The problem with bonding metal to fibergl*** it will pull the gl*** in and the shape will be visible from the back side. HRP
  7. wbrw32
    wbrw32
    A fibergl*** wholesaler will have a product like "Corebond" made for boat industry for bonding wood down in the bilges...kinds looks like a superior product as Bondo.
    loudbang and tb33anda3rd like this.
  8. Panel adhesive is fairly pricey, milled gl*** strands or chopped gl*** strand is cheap like borsht. Get your metal reinforcement close to the contour (1/8" is OK) grind the inner gl*** to rough it up, sand the metal at the attachment point with 36-40 grit and make a thick paste with polyester resin and the chopped gl*** (available in 1/32 to 1/4" lengths at my local marine supply)- 1/8th would work good for you. Save some resin back, brush a light coat of catalized resin onto both parts first, then put the paste on your metal reinforcement, put it in place and hold it till it kicks, while smoothing/brushing the squeeze out, to form a fillet and remove any excess. You won't be able to pull it apart and because it is filling the void with gl*** consistently, it shouldn't imprint to the outside.
  9. Lake Modified
    Lake Modified
    What if I bonded wood strip to the fibergl*** and then a strip metal to the wood for the rivets?
    Sm
  10. Mr48chev
    T bucket builders did and still do gl*** wood strips inside of gl*** T bucket bodies. That may or may not be simpler than gl***ing the metal strips in place. That would allow you to fasten metal strips to the wood (that was used to give the bodies structure back when they didn't come with any reinforcement) to the wood. Several ways to do it and the only wrong ones are when you cause damage to the outside of the body that you have to repair.
  11. Mr48chev
    Years ago there were some articles in the rod rags about gl***ing wood into T bodies. A lot of those bodies came just as a very basic shell/skin with no reinforcement.
  12. bobss396
    bobss396
    3M 8115 or 8116 is made for composite bonding to metals. The SEM product mentioned above is good too.
  13. Lake Modified
    Lake Modified
    According to the builder of the body, it does not need wood reinforcement. It is very stiff. It is made by Street Rod Fab near Orlando Florida if anyone is familiar. To make sure if I have this straight,
    1. If I bond metal tubing to the inside you will be able to see it on the outside?
    2. If I bond wood to the inside would I still be able to see it from the outside?
    3. If I fibergl***ed wood to the inside I would not be able to see it from the outside?
    Thanks for everyone patience while I figure out the best way to go about this.
    Here is a pic of the car so far...
    Hatchet likes this.
  14. DDDenny
  15. dirt t
    dirt t
  16. Lake Modified
    Lake Modified
    Thanks, I think this is the direction I will go in...
    SM
  17. Dick Stevens
    Dick Stevens
  18. Lake Modified
    Lake Modified
  19. DDDenny
  20. Lake Modified
    Lake Modified
