Hot Rods Stopping air leaks in firewall
Discussion in 'The Hokey Ass Message Board' started by little red 50, Jun 21, 2017.
  1. little red 50
    little red 50
    I'm trying to find a good way to stop the air (hot and cold) and the smells from the engine compartment from coming inside. I'm talking about leaks from around hoses and wires with grommets, the air still comes in. Anybody have a any good ideas?
  2. Grommets.
    Dino 64 likes this.
  3. 57 HEAP
    57 HEAP
    Test fitting the "factory" firewall seals before final ***embly. I didn't do that and I have the same problem. All the duct tape and caulk I have used has helped.
    little red 50 likes this.
  4. RMONTY
    RMONTY
    One of those little pine trees that hangs on the rear view mirror?
    Dino 64 likes this.
  5. oldolds
    oldolds
    As seen on TV.. spray foam. :cool:
    I would get some caulking and get busy sealing things up.
  6. Mark Roby
    Mark Roby
    I would use silicone
  7. tfeverfred
    tfeverfred
    There's this stuff called....."monkey ****". NOT the trade name, just a nick name. It's like a putty (that kinda looks like monkey ****) that you form into shape and press into the hole or gape that you want filled. Contractors use it.
    GeezersP15 and little red 50 like this.
  8. southcross2631
    southcross2631
    Use the a/c stuff that comes in strips. It has around for years mechanics call it dumb-dumb. You form it around your hoses and wires. The factory even uses it on A/C hoses.
  9. Bugguts
    Bugguts
    I second this for helping loose grommets to fit and seal. 3M makes the stuff I use. I think it's called strip caulk. A box will last you a long time and you will find more and more stuff to use it for.
    Sent from my SM-G900R4 using The H.A.M.B. mobile app
    tb33anda3rd and little red 50 like this.
  10. RMONTY
    RMONTY
    It's called insulating cork tape if I remember correctly
  11. little red 50
    little red 50
    Thanks guys, I can't wait to go to the parts store and ask for some monkey **** or dumb dumb. All kidding aside thanks for the suggestions.
    Mark Roby likes this.
  12. Bandit Billy
    Bandit Billy
    The dumb dumb I use is 3M strip calk, works great and easy to apply. What you don't use seems to last for years if you leave it in the box.
  13. tfeverfred
    tfeverfred
    THAT'S IT! Monkey ****!
  14. Bandit Billy
    Bandit Billy
    I have asked you to stop calling me that Fred!
    dogwalkin and mgtstumpy like this.
  15. tfeverfred
    tfeverfred
  16. tfeverfred
    tfeverfred
  17. On Most Old Cars when you Take the Door Panel off the Car
    you will Find a lot of it ( Monkey-**** ) or Dumb Dumb
    Where the Rods go so there is No Rattle
    or in the Holes any place you want to use it
    Its Great Stuff
    Just my 3.5 cents
    Live Learn & Die a Fool
  18. Refrigeration suppliers will have this or similar stuff. Stays pliable so it doesn,t dry out and fall out.
  19. southcross2631
    southcross2631
    I have a box of that stuff too. It does last forever if you keep he box closed.
  20. 325w
    325w
    3m 8578 has changed its formula. It's sticky now and does not work as easy as before. If the sealer is hidden try the rope chalk from the hardware store. It has the consistinsey of the old 3m. We used s the black seal in the factory made by mortel. It lasted for years. I have a small amount left now. Have to store it in plastic wrap.
  21. Roger O'Dell
    Roger O'Dell
    I hav e a friend that keeps the 3m strip calk in his frig , mine just stays in the garage. He helps me a lot and says his way keeps it fresher and closer to as purchased. Just saying
  22. manyolcars
    manyolcars
    black 3M weatherstrip glue works good around grommets
  23. Strip calk sounds like something I have no interest in seeing....
    Oh wait....
    Dumb dumb does work well.
  24. 41woodie
    41woodie
    The fact that you are so intimately familiar with monkey **** that you can recognize it from a photograph is somewhat disturbing.
  25. Dick Stevens
    Dick Stevens
    It is actually called Thum-Gum and can be bought in most home improvement stores or online.
    That was the brand name of putty that we used in the manufacture of refrigerated semi trailers to seal up the sections in the walls, floors and roofs before foaming, anyway
  26. tb33anda3rd
    tb33anda3rd
    that stuff works good. i also use it around body clips to seal panels. it also will hold a nut/bolt into a socket for those hard to reach areas.
  27. Joe Blow
    Joe Blow
  28. I agree with Mark.I used clear silicone on a couple of my projects.It Stopped the smells, noise and the heat. Bruce.
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Monkey Sh*t. I don't know the color of it but it makes me wonder if this is a case of man do what monkey do. An action that monkey's do/did with they're poo to seal up holes up. What a monkey would seal up, that's another question.
  30. Vimtage Iron
    Vimtage Iron
    I've got it in a roll, its Butyl tape, its usually used in windshields between the rubber and body to complete a seal, NAPA carries it it does come in several sizes, my old parts guy called it dum dum also.
    Looks just like the factory stuff around wires and hoses.
    lbcd likes this.
