Projects Not Your Average Coupe Build: ‘37 Chevy Unearthed
Discussion in 'Traditional Customs' started by oneratfink57, Jan 31, 2017.
  1. Leakie
    Leakie
    FYI sedan doors are different then coupe doors.
    oneratfink57 likes this.
  2. 1blown57
    1blown57
    from Florida
    Found some pics When first dragged home! IMG_8961.JPG IMG_8964.JPG IMG_8963.JPG
  3. chevy54man
    chevy54man
    from NC
    Incredible job you're doing, best to you man~!
  4. rusty1
    rusty1
    ...what happened to this project?
    oneratfink57 and 39 Aaron NZ like this.
  5. 1blown57
    1blown57
    from Florida
    Summer time!!!
  6. rusty1
    rusty1
    yeah, I know the feeling, I don't get nuthin done on projects in the summer....
  7. jp52
    jp52
    Those floors look great! 16 or 18 gauge?
  8. oneratfink57
    oneratfink57
    from Wisconsin
    Hey guys I'm still here! Summertime family fun has consumed me for the past 6 weeks. However I've got the week of the 4th off so I'll be hammering some work out on the 37. But I'm going to be ****oning up some stuff on my 57 too! Just got my 57 ***led and registered. I might cheat a little and post some 57 progress on here too!
    Glad to know you guys are still into it!
    jp52 i used 20 gauge for the floor pans. With the spacing I've got on the floor structure and the beads, the 20 gauge holds up just fine
    kidcampbell71, brEad, jp52 and 3 others like this.
  9. rusty1
    rusty1
    nice to see you're back, and I wouldn't mind seein the 57 stuff also.
    kidcampbell71 and oneratfink57 like this.
  10. sololobo
    sololobo
    Rspect for your skills, this is looking great. I love these coupes and the awesome stling, yours will be an instant icon. Best wishes on the project.
  11. oneratfink57
    oneratfink57
    from Wisconsin
    Had a few hours until our family excursion to the local drive in movie theatre so wanted to get back in the swing of things with the 37.
    I wasn't much for do***enting today, but I needed a transition panel between the rear floor pans and the drive shaft tunnel. I actually made two. The first panel I made would of had to be **** welded and could of turned into a nightmare with distortion of the rear panel.
    So I s****ped that idea
    Instead I went for a design that had a flange in it so I could plug weld which would match the rest of the floors design. Unfortunately the panel wouldn't fit back in my bead roller to roll a bead on the tunnel side, but it'll remain rigid nonetheless. This was a little more time consuming but I used a flange stretcher on the vertical portion of the flange, which would help form the radius of the part.
    I used the planishing hammer to smooth the marks left by the stretcher and dialed in the overall shape with the panel beater bag and tapered mallet
    Since I've gotten as far as cleco pinning all the components in place, I'll sneak in the garage tomorrow to plug weld them all up
    Can't promise much more progress this week on the 37 despite having the week off. I'm planning on splitting some time with my 57 to get some more bodywork done and install my new factory gas tank setup.
    And of course there's the Iola swap meet on Friday!
  12. oneratfink57
    oneratfink57
    from Wisconsin
    As promised, Rear floor pans and p***enger front floor pan welded in today
  13. oneratfink57
    oneratfink57
    from Wisconsin
    Started brainstorming some rear body mounts. Sketched a few concepts but this is what I came up with. I'll weld it up and weld it to the floor structure and use the factory rubber insulation pads between the mount and the frame. When I make the trunk tail pan, I'll likely just make small access panels to get to the bolts
  14. oneratfink57
    oneratfink57
    from Wisconsin
    I hope everyone had a great 4th of July!
    Today I got some serious garage time which was nice for a change. Threw back a couple PBR's, threw on some rockabilly, and threw on my weld helmet. As usual, progress below
    Welded rear mounts
    Ground them smooth for reasons unknown to science, since they'll never be seen
    Welded the mounts to the trunk tube structure. Don't mind the file marks on the frame
    Made the p***enger front floor transition for the firewall. Need to do some more rust repair before I weld it in though, on both sides.
    There should be some stuff there
    Something like this with less holes in it! But that repair is for another day
    Last step of the day was welding all the floor pans I could (like I've been rambling about for several postings.)
    Before I weld the trunk pans I need to finish the rear shock cross member as me and rusty1 were discussing
    Before I weld the drivers front floor pan in, I'd like to mount my underfloor brake pedal and master, as well as mount my Lokar shifter
    Which reminds me, I'm not sure if I ever posted a picture of it. The knob was 1 of 80 or so cast by a fellow hamber about 10 years ago. I'm sure some purists won't like the knob, so before anyone gets excited, the great thing about shift knobs is you can change them. :)
  15. oneratfink57
    oneratfink57
    from Wisconsin
    You may have noticed the two discolored spots on the p***enger floor, I got a little planishing hammer happy on that one. It's easy to hide mistakes behind the internet, but I'd like to highlight one of my many mistakes during this build.
    So what happened is I got oil canning in two spots from over stretching the material with the planishing hammer, so I tried my hand at shrinking them with the torch.
    For those who are experts or have better do***entation, feel free to share some thread shortcuts or insight!
    For those of you who haven't done it, you take a torch and heat up the high spot in the panel, until there's a portion that is red hot. Quickly take a hammer and dolly and hammer around the hot spot
    What's happening is by heating the panel to red hot, you're allowing the panel to be more maleable again, just like when material is hot rolled , by hammering the hot spot, you're trying to counter intuitively trying to stretch the red hot material, but the cold material around it is stronger, forcing the isolated hot spot to shrink.
    Repeat until panel is relatively flat, then you can hammer and dolly out imperfections without heat, but use caution not to stretch the panel again.
    Again for those of you who would try this for the first time, you're eyes aren't deceiving you, when you heat the panel the high spot grows because the heat is temporarily stretching the material even further, technically making the problem worse lol.
    This is my second time doing this torch shrink method and it took me about 5 minutes per spot to eliminate the oil canning. I know that there are WAY MORE well do***ented and more detailed descriptions on how this is done. But the more this kind of thing is talked about, hopefully the more interest in the craft will be generated
  16. oneratfink57
    oneratfink57
    from Wisconsin
    Today I was determined to actually finish the p***enger compartment floors.
    As I stated in my last post, I had some rust repair to do before I welded the front floor pans in.
    So o started with the driver side since it had more of the old pieces that I could try to mimic.
    In order to access the area, I had to cut the outer portion of the cowl. Since this area is hidden by the fender, I didn't take as much care as maybe I should of when cutting apart
    Cut the lower portion of the cowl that I'll be replacing
    Made and test fit cardboard template, followed by transferring it to 16 gauge steel.
    This portion of the cowl is structural and holds the front body mounts in location which is why I used 16 gauge
    Bend the new patch to it would fit flush against the front floor structure I made
    Welded it solid then repeated on the p***enger side
    Once all this was done, I was able to weld my front floor transitions and the drivers side front floor pan. So now all that is left is the trans tunnel!
  17. hacknwhack
    hacknwhack
    from mass
  18. oneratfink57
    oneratfink57
    from Wisconsin
    That car is the sole reason I committed to save this coupe. Love it!
  19. hacknwhack
    hacknwhack
    from mass
    Yes its stunning.
    You will get there.
    Just takes time.
    I spent 10 years on my last one...
    Hope it goes quicker for you.
    Sent from my SM-G920P using Tapatalk
  20. oneratfink57
    oneratfink57
    from Wisconsin
    Trunk floor is in!
    There's only a couple transition pieces left and the trans tunnel. So I roughed the two inner wheel well panels in with a stump and shaping mallet. Just need to planish and trim
    Before
    During
    After
  21. oneratfink57
    oneratfink57
    from Wisconsin
    Smoothed out the transition panels I made last week with the planishing hammer
    And welded them in
  22. jp52
    jp52
    I like your wooden form. I see a husky which I ***ume was used to make it?
  23. oneratfink57
    oneratfink57
    from Wisconsin
    If I was smart I would of used the chainsaw lol but I took a 6-1/2 circular saw and buried the blade into the stump, rotating it about 5 degrees every time, creating an asterisk shape * .Then used a wood chisel to carve out all the sections into a bowl shape and cleaned up with a grinder. I haven't spent the time to make it perfectly smooth, but it's also not a hardwood stump so I didn't want to spend the time.
    If you look up metal shrinking stump online there's some videos on how to make them and use them. Then the hammer I got from Joe Mielke at Snap-fab.com
    jp52 likes this.
  24. oneratfink57
    oneratfink57
    from Wisconsin
    Today was the day to finish the p***enger compartment floors!! (Almost)
    The Trans tunnel was the mighty adversary that I've been brainstorming for several weeks on how I wanted to do it. Keep it removable like the factory? Or weld it solid. Turns out I'm indecisive so I did a little bit of both
    Trans tunnel opening
    Used paper template to get approximate shape
    Roughed in shape over my knee. In upcoming pictures you will see I beadrolled the rear edge so it would fit with the beaded offset I put in the tapering portion of the tunnel
    This is where it could of gotten a little tricky, but given the amount of space I had between the motor and trans, I found a flat panel was provide enough clearance. Cut down a cardboard template
    Now I didn't do a good job taking progress pictures from here on out. But I bead rolled a recess and welded weld nuts to the back side of the floor panel. This would allow me to cut an opening and make a panel later on that would fit snugly inside the recessed area
    You can also see the transition panel I made. I took a 2" strip of 20 gauge, formed it to a 90, then used my Eastwood shrinker/ stretcher to form the compound curve. Not only do the ends taper down, but they also angle forward as well towards the rear of the car
    Sort of finished product. I ran out of time, so I wasn't able to weld it, but I'll probably sneak in the garage tomorrow to ****on it up
    Zoomed out
  25. oneratfink57
    oneratfink57
    from Wisconsin
    Not a lot of excitement today, just welding. Welded the tunnel and a couple of areas throughout
    tb33anda3rd and brEad like this.
  26. 39 Aaron NZ
    39 Aaron NZ
    Your "Not a lot of excitement today" was still more than my car for this weekend!
    Your floor is looking awesome, really liking all that beed roller work! Keep the updates comming.
    Cheers Aaron.
    Sent from my SM-G360G using The H.A.M.B. mobile app
  27. Pete
    Pete
    Much respect, I know from experience the work involved with resurrecting a forgotten soul.
    Looks killer, can't wait to see it with the nose on.
  28. oneratfink57
    oneratfink57
    from Wisconsin
    Thanks gents!
    Getting all the panels mocked up isn't far off on the to do list. I've been thinking of doing it soon, so maybe I'll realize Im actually working on a car and not just a floor lol
    kidcampbell71 and brEad like this.
  29. metalman
    metalman
    After looking thru your thread here all I can say I really glad I live in the rust free desert. As crusty as that car looks I'm amazed you can get enough solid metal to weld to. I don't see where you're grinding or sandblasting the parent metal down to clean anywhere, how are you welding that?
  30. oneratfink57
    oneratfink57
    from Wisconsin
    I'm using some abrasive sponge pads on my grinder to clean up the weld zone prior to weld, the fluxcore soot hides the ground down areas in the pictures so you can't see it very well. Fluxcore scavenges most of the impurities from the weld puddle so theoretically it welds a little better than solidwire on a a less than ideal surface
    kidcampbell71 likes this.
