Ok guys ... Next one Going to do all new brake lines around truck. Like everything else never done before. Whats required in terms of fittings. Basically i have ordered https://www.amazon.com/gp/product/B015YGQYW2/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 and http://www.eastwood.com/professiona...rkkDm7oi9L0M7tUWiK-62sLxJTbnJyE_B7BoC7VXw_wcB what fittings do I actually need at each point though ....... eg ?? https://www.amazon.com/Pack-12-24-F...rd_wg=RFhgV&psc=1&refRID=5RMJBYBQW56DZV1FGSGR or a mix of other fittings ? Dakota IFS front Explorer 8.8 rear.
Fixed Thanks squirell ...... not sure something when copying from my mobile as it was posted from phone Just finished puttinmg in/mocking rear axle and welding front sheetmetal. Have a wheel on way with small -ve offset ..... Ill add a tire and check and then order 4 wheels/tires. figure need to get brakes done ......... (hydroboost off a 1500 truck and brake lines) ...... then work on wiring and interior ........ before I can finally look for an engine
Thanks mgtstump - Brisbane hey - Im a sand*****r Yes I may need a good tube cutter and bender to be addedto list as well as holdodwns. The fitting part is the confusing part I mean ......... for starters like David mentioned SAE or metric ......... thread size ..... and how many different sizes for different lcoations (eg line terminations at actual brakes , MC differnt size) etc
Plugging in 1993 dakota into autozone for frono soft lines ... get http://www.autozone.com/brakes-and-...t/duralast-brake-hose-front/124782_99196_2362 Fitting Size (1): Banjo - 0.375 Fitting Size (2): Female - 3/8-24 So looks like its 3/8-24 ......... guess thats one way to determine
You need the correct tube nut for the flare needed. DOT flares are 45 degrees and are recessed where the flare seats whilst the other tube not is flat in the same area. http://www.fedhillusa.com/webnuts/common flares6.pdf
Thanks - I had read that website - but not that actual article. As they mention in the doc for double flare... The 3/8 x 24 UNF American nut will thread very easily and loosely into a 10mm x 1.0 thread fitting but will hopefully strip the threads when you tighten it down You can start the 10mm x 1.0 thread nut in a 3/8 x 24 UNF thread fitting but it will immediatly begin stripping the threads So guess the way to tell is get one of each ...... and start threading the 10mm to see if it takes or not ... if not then should be 3/8-24 Not sure about the MC end......
I'm a big fan of copper nickel brake line. Like stainless, do it once and forget about it, no rot like steel lines. Bends very easily. Hate to tell you this, but I have the same Eastwood flaring tool that you linked to, nice tool for steel line but does not make useable flares in copper nickel. I've tried 3/16 and 1/4 line, for some reason their tooling doesn't start a double flare nicely, doesn't produce a nice 45 degree double flare. I use my decades- old Mac flaring tool for copper nickel. I buy the line and flare nuts from my local NAPA store.
I use that exact roll of tubing and the exact bender all the time. I've done probably eight complete brake plumbing jobs in the past few years. Out of hundreds of flares, I've messed up three or four, usually attributable to not deburring well enough. I've used it on 3/16", 1/4", 5/16" cunifer. I even use it for "bubble" on the end of fuel lines so they don't slide off by barely starting the flare with the second step. I love that tool. Like others have said, just get all of your parts together and try to screw the fittings in where they go before you start making lines up. Good luck, you've got the right start.
I bought a kit from that same vendor. Cupro-nickel is great stuff like everyone says. I'm using it with my decades old KD flaring tool and it works great.
The basic KD Tools double flaring kit, sold at NAPA, and other places, works just fine. I used one, or another, for a few decades, until I moved up to a hydraulic Mastercool unit.
