Projects 26 roadster build; Bang Bang
Discussion in 'Traditional Hot Rods' started by h.i., Nov 4, 2012.
  1. h.i.
    h.i.
    from denver
    Thanks guys. Ill try and keep the updates coming till its done. I think Ive promised that before tho, haha
  2. ChuckleHead_Al
    ChuckleHead_Al
    Looks great man, I like it. You wouldn't happen to have another trunk lid would you :cool: ?
  3. falconsprint63
    falconsprint63
    from Mayberry
    I soooo want one of these. keep up the good work. I'll live vicariously for now. trying to stay focused on my avatar.
    Sent from my SM-G920R4 using The H.A.M.B. mobile app
  4. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Anything happening as of late ?
    tsk
  5. h.i.
    h.i.
    from denver
    Yes! Lots of painting. In the middle of painting all the drivetrain and ch***is bits. Time consuming and boring for pics. Ill put some up when I get a chance but not much to look at.
    HawgHead and spurgeonforge like this.
  6. h.i.
    h.i.
    from denver
    Ok time for an update. What's this? Freshly blasted ch***is bits.
    OFT likes this.
  7. h.i.
    h.i.
    from denver
    Etch prime everything.
    OFT likes this.
  8. h.i.
    h.i.
    from denver
    Prime and paint some more stuff
    brEad, kidcampbell71 and OFT like this.
  9. h.i.
    h.i.
    from denver
    Get distracted again
  10. h.i.
    h.i.
    from denver
    Time for the block. Guess we should clean this up.
    OFT likes this.
  11. h.i.
    h.i.
    from denver
    More cleanup and paint.
  12. h.i.
    h.i.
    from denver
    Hot tank the really gross bits:
    OFT likes this.
  13. h.i.
    h.i.
    from denver
    While were here may as well rebuild the box. Thanks to my pal Pineapple™ and Meteor Motors® for the expert ****** work. And thanks to our Koozie sponsor Ron Barbarino and the Iron Lords™®©.
  14. h.i.
    h.i.
    from denver
    A little mockabilly action to see how everything looks. Not completely sold on the Edmunds LEGO manifold anymore but we'll see how things shake out.
    brEad, bct and kidcampbell71 like this.
  15. h.i.
    h.i.
    from denver
    Pineapple doing some top-secret distributor stuff in the Meteor Motors lab.
    kidcampbell71 and ChuckleHead_Al like this.
  16. h.i.
    h.i.
    from denver
    A lot of other OT stuff happened in between here and there but this catches us up on the worlds slowest 27 roadster build. Thanks to you guys for the support and inspiration over the years. Ill try and keep posting as we go.
    kidcampbell71, bct and s55mercury66 like this.
  17. Atwater Mike
    Atwater Mike
    We're relying on it, H.I....
    As for intakes: My '27 tub's flathead was going to get the cheapie Offie intake (2 X 2, back to the rear...to accept my converted 6 volt '38 generator to 12 volt, with a cutout relay. (and a gen. mounted FAN!)
    Luckily, I found a mint NAVARRO, with carbs right over the ports. An elder gent had it under his bed since '52...
    But alas, now a side generator mount...and a bracket/idler for the fan.
    Engine is a 59AB, factory relief...so it's short in front, with '42 crab distributor.
    Meanwhile, waiting for news on the rest. Do you have the correct 2nd/3rd fork for the trans? (it's 3" wide, and has a slightly rearward position in neutral...so, widening (grinding) an earlier fork ('35-'38) won't work, it will push the sleeve too far into 3rd, and your synchros will fly out from under the sleeve.
    You probably knew this, but it is 'esoteric'...
  18. LSR 2909
    LSR 2909
    from Colorado
    Looks great .
    Good to see.
  19. 26 T Ford RPU
    26 T Ford RPU
    Cool to catch up on your progress. JW
  20. Six Ball
    Six Ball
    from Nevada
    Great up date. That's a lot of work. I like the Edmunds 2X2 gen up front manifold though my Edmunds heads already have fins removed for a side gen mount.
  21. alanp561
    alanp561
    Do the folks over in Golden know about you? I'm surprised you haven't been run out of the state yet.;)
    brEad likes this.
  22. PINEAPPLE
    PINEAPPLE
    Yeah Alan, always lookin over my shoulder.. They are a lot more tame than the old days though. Good stories about the wild west and the coors compound from the old timers around golden.
    brEad likes this.
  23. h.i.
    h.i.
    from denver
    Hey time for an update! Thanks Alan haha. Heres 15 years of progress in 10 pics or something.
    20170622_233639_001.jpg 20171023_010146.jpg 20171023_010211.jpg 20171103_200411.jpg 20171104_104209.jpg 20171201_003615.jpg 20171210_162126.jpg 20180102_224900.jpg 20180221_000806.jpg 20180504_200021.jpg
    Shadow Creek, cactus1, brEad and 8 others like this.
  24. h.i.
    h.i.
    from denver
    Cheers to Pineapple for building a distrubutor, teaching me how to paint, moral support, and cheap beer.
    brEad, PINEAPPLE, alanp561 and 3 others like this.
  25. 26 T Ford RPU
    26 T Ford RPU
    Thanks for the update, just love this build. Rock on.:cool::cool: JW
    PINEAPPLE likes this.
  26. Six Ball
    Six Ball
    from Nevada
    WOW, That is exciting to see it going together.
  27. lodaddyo
    lodaddyo
    looks great! I would be interested to learn more about your distributor? is that a chevy tach drive? im pretty sure this is the route im gonna have to go to to hook the tach up in my roadster
  28. PINEAPPLE
    PINEAPPLE
    Yes sir it is. we machined the housing to 8ba spec. , annealed an 8ba drive gear,reamed it to the chevy shaft diameter,drilled it and the chevy shaft in the new position, re-hardened the gear, then put it all back together. This one is a mallory, and it has some adjustment in the breaker plate, so we set it up for around 16-18 degrees total advance. much more than that will hurt a flathead.
    OFT, cactus1, Tim and 3 others like this.
  29. Jiminy
    Jiminy
    Damn. Sounds like some great work. Did you do a build thread?
  30. PINEAPPLE
    PINEAPPLE
    Thanks buddy! I did not, i never really thought about it. I made one for myself first, and was about to test it out on an engine I had on my run stand.. I ended up selling the engine before I could get it tested out. So honestly, we have not ran either one of these yet. Maybe once we haven proven one out I will do a build thread. As far as mechanical tach drives go, I am going to build a crank drive for a friends car that I am working on, it's a 59a flathead, the drive will be similar to the old stewart warner kind that used a short piece of speedo cable as a coupler. I will take lots of pics on that and do a build thread.. if it works of course. Thanks for the kind words.
    brEad, h.i. and Willows like this.
