Projects My 41 Ford Deluxe tudor build
Discussion in 'Traditional Hot Rods' started by Hyvolt, Jan 5, 2017.
  1. 1980gold
    1980gold
    [​IMG]did you use these arms? I had these but they wedged up against the inside of the axle and had to get the ce's just curious. My clearance is right around there maybe 1/2" lower
  2. Hyvolt
    Hyvolt
    They did touch slightly, but only at an extreme turning angle. I did grind them slightly, and it worked well. I figured that my best get would steering arms from the same axle manufacturer .
    Sent from my SM-J327P using The H.A.M.B. mobile app
  3. T42
    T42
    I have these exact same steering arms. I planned on using them if I cant get the steering link to fit between the 4 bar rods. With these I would run my tie rods and steering rod below the 4bar. Hope to be able to make the stock ones work though....
  4. T42
    T42
    Got to roll the 41 out the garage today between rain storms to take a couple pics. It wasnt out for 5 minutes before the rains came back again... Damn you Tropical storm Cindy!!!....lol...... 20170622_151447.jpg 20170622_151513.jpg 20170622_151530.jpg 20170622_151513.jpg 20170622_151530.jpg
    1980gold and The 39 guy like this.
  5. Hyvolt
    Hyvolt
    [​IMG][​IMG]
    After about 5 different attempts to brace up the frame around the govonor , I came up with this. Fit the ring to the gap and welded it up. Best thing about it, I can install and and remove the govonor with the ring welded in. Should be strong enough. Still have to finish the driver side frame and booster mount.
    1980gold likes this.
  6. T42
    T42
    Amazing how a little imagination can fix a problem! Looks pretty cool too....
  7. 1980gold
    1980gold
    My problem with these was that there was no room between the drop in the axle and you couldn't turn the car at all. The ce arms bolt up a different way the only compromise is they are lower than they need to be putting your tie rod ends too low for my liking which is why I was thinking of the 4 link set up so I can mount the tie rod on top of the steering arm. nice color by the way
  8. T42
    T42
    What if you were to use your torch and heat the arms a bend them up? It's a very common thing to do....
  9. 1980gold
    1980gold
    yeah I was thinking that but if I do the 4 link thing I wouldn't have to .
  10. 1980gold
    1980gold
    t42 what were you gonna do for lower front shock mounts?
  11. T42
    T42
    Not sure what you mean by lower front shock mounts? I already posted an article in here about the front shock set up I put together. I think it was post # 105. I gave a pretty good detailed post about how to do it...including part numbers...check it out and see if it doesnt answer your questions...
  12. 1980gold
    1980gold
  13. T42
    T42
    I need to make some room in my garage, so I decided to clean up the rear inner fenders and wheel well area. I want to get them back mounted on the car to start making room in the garage. They were mostly just surface rusted and wire wheel on a grinder cleaned them up pretty fast. I sprayed a POR primer and then painted them to give it a cleaner look.
  14. Hyvolt
    Hyvolt
    I have made a little progress in the last few weeks. Due to the Mercury overdrive trans, the brake booster took a little extra effort. Went with a dual 7 inch booster and 1 1/8 master. With the pedal ratio and all the other math involved felt like the right choice. Power brakes are one of my choice modern upgrade( driving hwy 70 around st.louis).
    The nicopp line showed up today, and in the throws of trying to get a driveshaft made for the old slip yoke. Old 2r style?
    [​IMG][​IMG][​IMG]
  15. Hyvolt
    Hyvolt
    Before bracket [​IMG] was finished
    1980gold and brEad like this.
  16. Hyvolt
    Hyvolt
    Driveshaft in, brakes bled, trans filled, motor mounts tight. Ready to test fit the body this week and check out how it sits.[​IMG][​IMG][​IMG]
    neilswheels, LBCD and brEad like this.
  17. T42
    T42
    Looks great! That front end is nice and low. Cant wait to see how it sits with the body on. Looks like you used the same fuel tank and electric pump as I did. Im hoping to fire up the engine this week as soon as I get the high rise manifold and 4 barrel carb mounted.
  18. Hyvolt
    Hyvolt
    I couldn't wait. Got it done today. I'm real pleased. I might go 2 more in the rear, but i think the springs will settle some. Right now i have 23 inches front and 25 rear , me***ured at the wheel arch. 5 inch clearance at the front nose and 5 3/4 at the lowest point on running boards[​IMG][​IMG][​IMG]
  19. T42
    T42
    Looks pretty good as it is! Nice job.
  20. studebaker46
    studebaker46
    hyvolt where in warrenton are you? I live in wright city. also wondering who built your driveshaft for you Tom
  21. Hyvolt
    Hyvolt
    I'm North of town on 47. Inland truck parts in st Charles did the shaft. There is a drive shaft shop in Wright city, "dynamic" , he just wanted to retube my aluminum instead of cutting and balancing.
    Sent from my LG-LS993 using The H.A.M.B. mobile app
  22. studebaker46
    studebaker46
    I used dynamic to make mine 41 ford p/u w350/350 he talks a good story but have some vibration at lower speeds Tom
  23. bchrismer
    bchrismer
    Way cool, @Hyvolt I'll have to catch up with you one of these times when I'm up a dad's house. He is over in New Melle.
  24. Hyvolt
    Hyvolt
    Sounds good to me. Any of you local guys have anything flathead ford powered? I'd really like to take a ride in a flathead powered machine.
  25. sololobo
    sololobo
    wow, love 41's, that 3 piece grille is off the hook, beautiful builds here guys!
  26. redzula
    redzula
    Awesome work guys. I'm planning to rework my setup this winter. 47 Tudor stock drivetrain now with lowered rear (janky shackles the PO made) and lowered front (poses 3" drop reverse eye and a sid's dropped axle)
    Planning to go with a t5 behind the flathead and probably a parallel leaf setup like you're running. Just need to stay budget friendly.
    Side note I'll be working in Warrenton the next couple months as we remodel the Casey's store there.
  27. redzula
    redzula
    If you're ever in Des Moines.
  28. Hyvolt
    Hyvolt
    Let me know when your in town! I'll have Ya over. I wanted to run sids axle but at the timehe was 8 weeks out, and i was trying to get done with the axle on vacation.
  29. T42
    T42
    I started to do a little body work yesterday and got carried away....I decided to strip the old ****py paint off. Got the entire body done. Still have the fenders and hood to do. Over all, shes pretty solid.
    LBCD and Hotrodmyk like this.
  30. brEad
    brEad
    Are you just using razor blades to strip off the paint?
