Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. banjeaux bob
    banjeaux bob
    from alaska
    19146193_1547260008649367_1003938143047684623_n.jpg The car in post #9981 from a different perspective.
    loko and 64 DODGE 440 like this.
  2. banjeaux bob
    banjeaux bob
    from alaska
  3. banjeaux bob
    banjeaux bob
    from alaska
    14671247_10154597412868560_7981538511814304740_n.jpg GN single seater ,"GRUB" from Steve Wilkinson.
  4. banjeaux bob
    banjeaux bob
    from alaska
    19553861_1387639667939009_1295953208215773809_n.jpg 19510306_1387651557937820_5841541129289904941_n.jpg A couple of Salmsons from Marc.
    WillyNilly and Herb Kephart like this.
  5. banjeaux bob
    banjeaux bob
    from alaska
    19553848_1706478436097527_23437501901848674_n.jpg 19511574_1706270642784973_2358530123062502645_n.jpg Simon Lewis captured these 2 at Shelsley Walsh Hillclimb. The GN "PARKER" and the historic ERA R4D. Although ERA R4d is not a cyclecar as such, it does have a lot of history at Shelsley Walsh .A former outright record holder at the hill.It has been up the hill more times than any single driver.Perhaps,the car has so much experience on the course that all the diver has to do is hang on!
  6. banjeaux bob
    banjeaux bob
    from alaska
  7. banjeaux bob
    banjeaux bob
    from alaska
  8. banjeaux bob
    banjeaux bob
    from alaska
    19399443_1472075756193474_1019965868375478639_n.jpg From Morgan Flaving
  9. banjeaux bob
    banjeaux bob
    from alaska
    19657245_1391621760874133_8757889484699712904_n.jpg Marc out in his Sandford.
  10. banjeaux bob
    banjeaux bob
    from alaska
  11. banjeaux bob
    banjeaux bob
    from alaska
    19665201_1917112548542217_2526039945642216338_n.jpg The Hale Morgan from Ewan Cameron. 2.6 liter V-4 J.A.P. 19702191_1917112645208874_3656866635812979345_n.jpg
    morac41, rooman and Rolfzoller like this.
  12. banjeaux bob
    banjeaux bob
    from alaska
    19731841_10209378223428150_8574146104810186052_n.jpg Jean Pascal's Amilcars taking a rest.
    WillyNilly and Kume like this.
  13. banjeaux bob
    banjeaux bob
    from alaska
    19248045_559274407756533_3032326602036150087_n.jpg The baby's carriage isn't much smaller than the Morgan carrying it.
    Rolfzoller and lbcd like this.
  14. tarcoleo
    tarcoleo
  15. tarcoleo
    tarcoleo
    Should not the tires be switched left to right, right to left?
  16. banjeaux bob
    banjeaux bob
    from alaska
    These folks are pretty good tuners. So,I'm going to say they probably have them on the right direction. I do see what you're saying about the tread.
  17. Herb Kephart
    Herb Kephart
    A lot of torque going through the second flywheel ***embly. Do you know if the car has run in compe***ion? If the lower ends are standard, I don't see how you can tighten the tapers enough.If one piece cranks are used, then the rods have to have removable big end caps (and insert bearing shells?) I have done this. Also the tires are on the correct way for a non-driving application, per farm tractor practice
  18. banjeaux bob
    banjeaux bob
    from alaska
    Ewan is a pretty busy guy. I will ask about the connecting of the 2 engines.He does some pretty crafty things to upgrade the lower ends of these engines while retaining the original outward appearance.
  19. banjeaux bob
    banjeaux bob
    from alaska
    19756437_1395707720465537_6535102805479751484_n.jpg 1917 Duryea.Marc pic.
    Rolfzoller likes this.
  20. banjeaux bob
    banjeaux bob
    from alaska
  21. motoklas
    motoklas
    from Bern, CH
    Hello Herb,
    I had two dilemmas about that tandem-double-engines Morgan:
    1. As this tyres are from super-bike motorcycle (it looks to me as so), knowing something from experience of my friends in Belgrade - they are put in wrong direction? However, as they have circular cross-section - only one inch or more should be on ground with three-wheeler, so side c****s are not of so big importance?
    2. Is this just because of photo-angle and possible distortion - it looks to me that front engine is something lower and was seating only at wooden blocks? Then, they do not look connected to each other - there are some components infront Morgan, tandem-doubble-engines.jpg of the rear engine (do not know what they are) on the way of possible crankshaft connection between two engines? However, maybe they are on the same level and shift connection is p***ing below mentioned components – and I am totally wrong!
    Ciao,
    Zoran
  22. banjeaux bob
    banjeaux bob
    from alaska
  23. 32 Spitfire
    32 Spitfire
    Testing a new set of Magnaflow Mufflers on my Morgan 3 Wheeler. These replace the factory exhaust that are too restrictive all done with no modifications to the Morgan and the originals can easily be put back on. Now the big S&S Twin-V can breath a little easier, sound nicer and run cooler too!
    High Noon Speed Shop
    Blog: https://ontheroadtonowhereville.wordpress.com/
  24. banjeaux bob
    banjeaux bob
    from alaska
    Sounds great! Any noticeable difference in power ?
  25. banjeaux bob
    banjeaux bob
    from alaska
  26. banjeaux bob
    banjeaux bob
    from alaska
  27. banjeaux bob
    banjeaux bob
    from alaska
    19905309_1679400738797831_3487440833578640029_n.jpg ****** Mary in it's current iteration. Ron Lawrence image.
    t-rod, Ned Ludd and 64 DODGE 440 like this.
  28. banjeaux bob
    banjeaux bob
    from alaska
    19958957_1987445047947855_7353281426186695174_n.jpg salmson from jos Cox.
    Ned Ludd likes this.
  29. banjeaux bob
    banjeaux bob
    from alaska
  30. Kume
    Kume
    This should be in the New Yorker back page caption compe***ion.
