Projects 54 Ford Customline daily driver
Discussion in 'Traditional Customs' started by Shane Spencer, Jul 24, 2016.
  1. Hunter73
    Hunter73
  2. Shane Spencer
    Shane Spencer
    Sorry guys for the slow updates. Went to cruise week in ocean city md a few weeks back, did an air ride install last week and currently looking for a daily driver so progress has been slow
    Managed to get the gas tank back in, gas door has new rubber bumpers, carb rebuilt, new door handles on and rebuilding the vent windows with new rubber. The regulators in this car are a pain in the *** lol
    Heres a shot of sediment in the float bowl
    New fuel pump installed
    Bent up some niccop line to the carb
    The vent rubber was shot. Taking these out ****s lol
    Finish welded the grille today finally. Tig'd and metal finished and sanded to 220. Need to drop back to 120 to take out a few more small low spots then polish it up. Hand filed it to get the peak looking decent
  3. brEad
    brEad
    Grill bar is looking good!
  4. Shane Spencer
    Shane Spencer
    Thanks man !
  5. Martino
    Martino
    Progress is looking really good ! The shifter and Knob are perfect !
  6. Shane Spencer
    Shane Spencer
    Not a ton of progress with the holiday this weekend. Did manage to get the old windshield pulled and theres no rust in the windshield frame area which is good. Got a new seal and gl*** ready to go in. Also got the dash two tone finished up, satin brown top with the white bottom
    lothiandon1940 and Hunter73 like this.
  7. greaser 35
    greaser 35
    from FRANCE
    Jolie!!!!!!!!!!!!!!!!!!!!!!;)
  8. cmarcus
    cmarcus
    Amazing stuff here brother! No one has commented on your photography. Side hobby? Cause those pics are crazy good.
  9. Shane Spencer
    Shane Spencer
    Thanks marcus! I just started messin around with photography like 7 or 8 months ago. Trying to learn from a good buddy of mine
    lothiandon1940 and brEad like this.
  10. Allout
    Allout
    Your attention to detail shows in the final product. Very nice work.
  11. Shane Spencer
    Shane Spencer
    Thanks for the kind words....
    Some updates. P*** side window is in and working great. Also lubed up the rear regulators and all is smooth. When i pulled the drivers side vent window to redo the rubber seal, the vent window cracked. New gl*** is cheap at only $28 but the lower pivot stem broke off. Should i try my luck with a strong epoxy? The pivot shaft rotates up into place inside the frame of the vent window, with a solid 2 part epoxy i think itd be more than strong enough. The frame is in great shape otherwise and id rather not drop $120 on a new frame if i dont have to
    Other updates, i pinstriped the dash, turned out decent. Some white and dark brown with just a touch of gold
    Freshened up the speedo, satin black paint on the inner base, repainted the exterior and put a gold tip on the needle
    Also my paint was chipping and scratched all around the windshield and it looked like someone may have just sprayed paint over the gasket half ***ed, so after i pulled the old gl*** i sanded and feathered out all the scratches and chips and shot some paint just to prevent corrosion. The colors not perfect but im planning on getting a rattle can of colormatched paint from a local shop that has a paint reader/decoder, then ill just spray it later on. The paint on this car has seen way better days, but its a driver so whatever
    brEad, lothiandon1940 and Hunter73 like this.
  12. lothiandon1940
    lothiandon1940
    Nice work. Didn't know you were a pinstriper as well.:).......................Don.
    lothianwilly71 likes this.
  13. Shane Spencer
    Shane Spencer
    Far from a legit pinstriper haha. I need way more practice, i do it just enough to get by when i need to hahah. But thanks
    mikhett and lothiandon1940 like this.
  14. brEad
    brEad
    Dash looks great, I like the touch of gold & the speedo needle.
  15. Martino
    Martino
    Dash is looking fantastic !
    I have a question about your sway bar bushings. Did you replace them and if so did you have to put a slice in the new ones to get them on? I don't see how new ones will slide over the ends?
  16. Shane Spencer
    Shane Spencer
    Yea i did slice the new bushings. Most bushings ive come across for swaybars have slices so i figured what the hell. I didnt see a way to get them over the ends either
    lothiandon1940 likes this.
  17. Shane Spencer
    Shane Spencer
    Painted the heater box
    Installed with a new plenum and defrost ducting. Also had to move my harness up from where it is in this shot
    Windshields in. Dont mind the color mismatch, thatll be fixed soon
    Package tray panel cut
    And upholstered
    Rear side panels cut and seat divider wall back in, trimmed to fit the raised trunk floor
    Dash in
    Got the magicaire controls working well and all the cables moving decently
  18. jailbar joe
    jailbar joe
    looking better with every post...gunna be beautiful when finished
  19. greaser 35
    greaser 35
    from FRANCE
    Great updates!!!!!!!!!!!!!!
  20. Shane Spencer
    Shane Spencer
    One of the rear panels is pretty much done
    Pretty happy with the results so far
  21. HOTRODPRIMER
    HOTRODPRIMER
    It's all looking great. HRP
  22. brEad
    brEad
    Looks excellent! Going to be really nice when done.
  23. NashRodMan
    NashRodMan
    Gag,
    It's looking great! Was it difficult to get the dash out?
    Thanks,
    NRM
  24. Shane Spencer
    Shane Spencer
    Dash wasnt bad, 6 or 7 small screws at the base of the windshield and two big bolts on the bottom corner
  25. Shane Spencer
    Shane Spencer
    Got the second rear panel banged out...
    Kick panels cut
    Got the column in as well. The wheel needs to be touched up still but i wanted to get a few pics
    Molded column mount turned out sweet
  26. bobss396
    bobss396
    Nice work on the upholstery. Do you take in side work?
  27. Hunter73
    Hunter73
    Dude, seriously.... you do great work! This car is turning out bad***.
  28. Shane Spencer
    Shane Spencer
    Appreciate it guys, cool to see that people enjoy these builds. I do some occasional side work but never interior. I hate doing interiors hahaha. I order all the stuff from ezboy, now owned by lebarron bonney
  29. Shane Spencer
    Shane Spencer
    Kick panels ready to be covered
    And covered.....
    And i got the door panels cut
    lothiandon1940, brEad and Venom51 like this.
  30. greaser 35
    greaser 35
    from FRANCE
    Nice interior!!!!!!!!!!
