Event Coverage Welcome to the 2017 Meltdown Drags
Discussion in 'The Hokey Ass Message Board' started by Okiedoker, Oct 6, 2016.
  1. Fordors
    Fordors
    Where is swap located, is it on far left in photo?
    DubG likes this.
  2. wrenchbender
    wrenchbender
    James you are supposed to look through the shaded lens of the helmet when welding lol now I know why you can't read a tape measure lmao
    loudbang, DubG, grantrobert and 4 others like this.
  3. saltflats
    saltflats
    from Missouri
    I thought that was to keep my pony tail from catching on fire.
    I was just tack welding.....and the helmet was a wash....the auto darkening quit working.
    loudbang, 55belairx2 and Swamp Rat 4 like this.
  4. saltflats
    saltflats
    from Missouri
    The swap meet is behind the bleachers on the right side of the track.
  5. Deuced Up!
    Deuced Up!
    loudbang, Swamp Rat 4 and saltflats like this.
  6. saltflats
    saltflats
    from Missouri
    Flash Burn Out Broke
    loudbang and Swamp Rat 4 like this.
  7. While living in California, we could go to the March Meet, or the Hot Rod Reunion. The bummer was, most of the real deal cars, or righteous clones were relegated to the show car section, or as exhibition cars that may get to make a couple runs the whole weekend. Instead, we towed 1965 miles/40 hours to go to our first Meltdown in 2014. We were treated like life long friends made as many p***es as we wanted to, and we're surrounded by 1966 again! We spend all year, getting ready for the Meltdown Drags like our dad did getting ready for the original March Meet "Smokers Fuel & Gas Championships" @ Bakersfield in the 60's. As an added bonus, you will get to see an un-blown B/Gas '56 Chevy "Yesterday's Child", stomp the silly putty out of a B/Gas Supercharged '57 Chevy "The Okie Doker"!
  8. Church Key
    Church Key
    I just purchased plane tickets to Chicago Midway Airport, I will be arriving early Friday morning. Could I get some recommendations for motels near the track, and some general idea what the area is like. The only time I have been in Illinois is just to change planes.
    racer-x and luckythirteenagogo like this.
  9. DubG
    DubG
    from Nebraska
    Like my welding professor says, " you ain't a welder unless you can weld without your helmet and a hand behind your back"
    wyatt "the Gasman" Gammel
  10. BigDrag
    BigDrag
    from Milwaukee
    I'm unsure of the maker if I had to guess Weiand maybe, WEI is cast in the breather I'd sell them but they come with the whole car.
  11. saltflats
    saltflats
    from Missouri
  12. the burn down tubes look like sae brand. you can still get them.
    loudbang and BigDrag like this.
  13. Fordors
    Fordors
    Those are WRE, Waterman Racing Engines. Sid Waterman started racing more than 50 years ago, raced Top Fuel for years and built race engines and fuel pumps/systems for nitro cars later branching out into NASCAR camshaft driven pumps mounted at the rear of the engine to lessen the chance of fire in a front impact.
  14. BigDrag
    BigDrag
    from Milwaukee
    That's awesome thanks for the information, they do have WRE cast in them not WEI
    loudbang and DubG like this.
  15. powrshftr
    powrshftr
    Took the car out for a short rip and a couple of 1-2-3 gear blasts yesterday.
    Things are working good.I'm so confident,I'm just going to load it on the trailer and leave it as-is til the Meltdown.
    You guys with Superchargers better start working on your list of excuses.[emoji8]
    Scott
    30dodgeboy, 55belairx2, enloe and 4 others like this.
  16. squirrel
    I already have my excuse, I don't have the safety gear to run nines.
  17. saltflats
    saltflats
    from Missouri
    Scott you better find a sticky road.......just sayin.
    powrshftr, loudbang, DubG and 2 others like this.
  18. Nitro Pontiac
    Nitro Pontiac
    from Wisconsin
    I have a question that I'm sure someone here will know the answer to. I'm running a magneto, how do I run a kill switch for that?
  19. saltflats
    saltflats
    from Missouri
    Just a switch to ground from the mag.
    powrshftr and loudbang like this.
  20. Nitro Pontiac
    Nitro Pontiac
    from Wisconsin
    Then run it to the outside of the car? I have the old battery kill switch on the back of the car, but that won't stop the mag. Right?
  21. saltflats
    saltflats
    from Missouri
    It will have to be a separate switch.
    If your battery kill switch is operated by a push pull rod you could mount a micro switch that the rod would make contact with.
  22. Nitro Pontiac
    Nitro Pontiac
    from Wisconsin
    Thanks for the info. I don't have a push pull rod so that's one more thing to fix.
  23. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    I am getting excited! I will only be there Sat. but This year I am going to try to meet as many of you as I can. especialy James , Scott, Jeff with the Scarelane, Gammz, Dub g ect. . But sorry Dub g even though I am a Ford guy , I will have to root for the cute blond in the Chevy from Wisconsin!!! lol Larry
    powrshftr, loudbang, Gammz and 2 others like this.
  24. saltflats
    saltflats
    from Missouri
    When I mounted the kill switch on this car I mounted closer to the battery then used the push off.
    So a switch could be mounted so that a micro switch could work with it.
    powrshftr, loudbang and Tickety Boo like this.
  25. JOECOOL
    JOECOOL
    [QUOTE="Okiedoker,
    Ok, so when it comes to the swap meet. There is a set of bleachers about 100 feet or so from the swap meet. It does require going through a section of the pits. There is also a 500 foot long hill next to the bleachers that makes for an awesome spot to watch racing and would make him highly visible to you. Setting up a tent in your swap space should not be an issue (a camper might be), but a tent should be fine.
    I was planning on bringing my camper this year with a small trailer for swap meet stuff . If there isn't room thats fine just let me know to save the extra work. Thanks .
    This will be my third year, best show on wheels.
    loudbang and saltflats like this.
  26. Tickety Boo
    Tickety Boo
    from Wisconsin
    Like Salty Says
    Tuning issues sometimes surface when you get on the sticky stuff. :eek:
    Thought I was ready a couple of weeks ago, it ran good on the road
    ( two nice long black marks )
    At the track the electrical trouble surfaced, popping and missing under
    heavy load.:oops:
  27. rusty1
    rusty1
    ...I help run the swapmeet, I don't think you'll have any problems setting up in the swap.
  28. enloe
    enloe
    from east , tn.
    I am excited to be coming up there this year and I hope everyone comes by the swap meet and buys something from me:)
  29. rusty1
    rusty1
    ...don't believe these guys ever ran each other, but had to sketch 2 of my favorites...can't wait for Meltdown 2017...
