Customs 47 torpedo trunk latch
Discussion in 'The Hokey Ass Message Board' started by 74kingwood, Jun 28, 2017.
  1. 74kingwood
    74kingwood
    Anybody know how to separate one of these things????? Driving me nuts
  2. Got a picture? Probably the same as the Chevy latch, I have gooned around with one of them.
  3. 74kingwood
    74kingwood
    Can get one this afternoon. Trying to separate the inner latch from the exterior handle
  4. 74kingwood
    74kingwood
    Pic. Need to move square peg to seperate.
  5. mgtstumpy
    mgtstumpy
    After you remove the nut the locking handle should just slip out. It may require some penetrating oil to facilitate its removal. Chances are its just frozen over time and not having been dis***embled before. There are square shoulders on the lock that corresponds with flats on the locking handle. The above ferrule goes in the trunk lid and door, the locking handles go through it. You need a tool to crimp the edges over and hold it in place.
  6. 74kingwood
    74kingwood
    So. Is the key necessary to get it out? I didn't get any keys
  7. mgtstumpy
    mgtstumpy
    You may need a key to rotate the mechanism as you need to extract the handle ***embly. That foot needs to clear the latch otherwise if not lined up, it won't come out. A locksmith may need to remove the barrel.
    Fisher body manual, rear compartment lock is the same as Chevy and other GM.
    Chevy shop manual
  8. 74kingwood
    74kingwood
    Thanks for all the info. Time to see a locksmith
