Hey guys. I am just a beginner. This is the rear end inside my '35 coupe project. Someone told me it is not stock. Hoping you guys can ID it for me and lastly, could a smaller Hemi from the '50s or a SBC run with this rear end ? Thank you and have a great weekend.
how are you measuring? Original on a 35 would 5.5" circle. Try measuring from the center of one stud, to the outside of the opposite stud, it will give you a good approximation. Does it have wheel adapters on it?
No wheel studs. I was measuring incorrectly before. My mistake. It has an odd number of studs and measures at 5.5". Sent from my Pixel XL using The H.A.M.B. mobile app
Hmm. I measured from the center of one stud and then opposite between two. Sent from my Pixel XL using The H.A.M.B. mobile app
Interesting. Can you run newer engines on a rear end like that? Sent from my Pixel XL using The H.A.M.B. mobile app
you can, but it's designed to handle about 150 hp. not much available for gear ratios, etc. It would be a good choice for a very traditional mid 50s type build, which might be why it's in the car in the first place? I wonder what the axles look like, if it's really a large bolt pattern, with that center section?
Thanks so much for your help. I'm glad to hear this. I'll get more pictures soon after I finish a clean up around the yard and shop. Hoping to get the Hemi going after I deal with the seize. Sent from my Pixel XL using The H.A.M.B. mobile app
That diff/suspension setup is hill billy at best. Do not run it like that. A parallel leaf kit would be an easy solution.
To me, I looks like the '56 and older Chrysler rear. The one that looks like an 8.75 but really isn't.
I will get the body lifted as soon as possible and get clearer photos for you all. Not sure what is going on with the suspension. Sent from my Pixel XL using The H.A.M.B. mobile app
so, you think this looks like this, which is a 1940s Mopar rear? or maybe it looks like this, which is a 50s mopar rear?
Sorry I didn't have one at hand to look at. I was looking more at the rear of the housing, it's shape, the weld seam at the top, and the brake line bracket. Please excuse me ignorance.
You're right, the back does sort of look like a Mopar. But there is more you have to look at, to figure it out. And google has pictures of many things, but it is not easy to find some of them. One thing I have noticed about the Mopars is that the studs that hold the third member to the housing, are not evenly spaced.
My memory of these has been pushed to the back caverns of my brain. I have been in many 8.75's. I have one in my '40. But I haven't worked on any of the early rears since my uncle died 15 or so years ago.
really? I'd love to see a picture of a Toyota differential that has that style ribs, and that type of U joint yoke.
Well, so show us a photo of the Brake drum wheel flange (wheel off or on). If it's Mopar it will have a tapper and key axle end showing past the drum. Also I believe the style I'm talking about used wheel bolts not studs in drum. The differanc in back side of backing plate and housing flange are pretty clear between Mopar and Ford. The Wizzard
Interesting....I never knew that Toyota copied the 49-56 Ford rear! but the one in the old car is still a Ford rear end, not a Toyota...
Hey everyone. Thank you all for your ***istance. I should have more pictures later this afternoon for you guys. I'll make sure to get the drums. Sent from my Pixel XL using The H.A.M.B. mobile app
