Technical Car Bucking At Low Speeds - What's The Deal?
Discussion in 'The Hokey Ass Message Board' started by Boondoggle, Jul 1, 2017.
  1. Boondoggle
    Boondoggle
    Hey all, long time lurker, first time posting. My dad just bought a faux-g***er 57 Chevy. 383 stroker, M22 4 speed, 9 inch rear. When taking off from at low speeds it gets pretty bouncy. If you ride the clutch or speed up it obviously goes away, but it seems pretty excessive.
    Has a crossram intake, dual Holley 450s, and 4.11 gears. Cam specs are 243/257 duration @ .050, .533/.519 lift, and a 107 LSA.
    Any ideas where to start here?
  2. pat59
    pat59
  3. lothiandon1940
    lothiandon1940
    That set-up is not conducive to "slow speed" starts.:eek::D
  4. El Caballo
    El Caballo
    from Houston TX
    Are there pics of said g***er? Post them up!
  5. Allmotor
    Allmotor
    I would start by checking the jetting in the carbs, may need bigger jets. Also check initial timing as well as mechanical advance. I would start with 12 to 14 initial with 36 -38 total, and then start playing with the springs in the dist. Also check power valve size. Holley site has instructions on how to determine proper power valve size.
    Boondoggle likes this.
  6. Boondoggle
    Boondoggle
    Probably not hamb approved, but
    20170630_120533.jpg 20170630_120311.jpg 20170630_120353.jpg 20170630_120438.jpg
  7. Have your dad leave the stop sign at...... oh 3500 RPM and see if the car "bounces". ;) As another said, not built for a "casual" start.
  8. I have no way of telling whether you are describing an engine surge kind of thing, or a mechanical "grab" sort of thing.
    often times it could also be a clutch disc with weak center springs.
    I've had standard or hd discs do that. I have always had great success when I put in some heavy duty performance disc, and thoroughly washed the flywheel and pressure plate to remove any oil or grease film.
    You don't have to use a heavy pressure plate if you don't want a stiff pedal, just a high quality disc such as Mcleod or zoom or something...
    ...that is... if this is a mechanical grab-and-chatter problem, not an engine surge problem....
    why be ordinary?
    X38 likes this.
  9. Crusty Chevy
    Crusty Chevy
    Sounds like a lean surge, follow above tuning suggestions.
  10. which also brings up another thing....
    If a home made clutch linkage does not have a correctly designed floating shaft belkcrank, sometimes engine movement can make a clutch feel grabby when you are trying to feather the clutch on certain take-offs.
    these are just ideas, since I have no idea how yours acts in person...
    why be ordinary?
  11. "lean surge" is worth investigating if it is not a mechanical type problem.
    why be ordinary?
  12. El Caballo
    El Caballo
    from Houston TX
  13. '49 Ford Coupe
    '49 Ford Coupe
    The posted description isn't sufficient for anybody to give you an accurate ****ysis. Choose some better words.
  14. Boondoggle
    Boondoggle
    I only got to drive it maybe an 1/8 mile, feels like you're learning how to drive a manual transmission all over again. A quick takeoff and it's fine. A slow crawl like you're in traffic makes for a rough ride. Speed up to maybe 15 mph and it's great. Basically I guess under 10 mph it's ready to stall.
    Guess it's not the easiest thing to explain.
  15. oj
    oj
    Like others said, it is lean. But, it is the idle circuit that is too lean. The idle circuit can't supply enough fuel for the greater HP of the engine, drill the restrictors to about .035 or change the idle air bleeds if they are repaceable, maybe to .o65ish.
  16. '49 Ford Coupe
    '49 Ford Coupe
    Are you trying to say that it's a clutch issue or an engine performance issue? Is the engine missing is your engine backfiring? Are you having trouble at low RPMs in every gear? Is it in first gear only that you jerk around? By the way I'm surprised your post is still up as I thought g***ers/pseudo g***ers were frowned upon around here.
  17. s55mercury66
    s55mercury66
    from SW Wyoming
    That is a nice looking car. That said, in driving it, I think you will find it to be a noisy extrovert that will scare old women and children.
    '49 Ford Coupe likes this.
  18. Petejoe
    Petejoe
    from Zoar, Ohio
    Great car. It's telling you to drive it on track, balls the the walls.
  19. Boondoggle
    Boondoggle
    I don't know what the issue is. No backfiring. Only low RPM first gear.
  20. '49 Ford Coupe
    '49 Ford Coupe
    Drive it and enjoy it. The car is telling you that it doesn't LIKE to go slow! Anybody who would do that to a beautiful '57 should suffer just a little bit.
  21. seb fontana
    seb fontana
    from ct
    Pretty healthy cam and at 107° it will be lumpy down low and dual carbs with large volume manifold all adds up..If you are not knowledgeable at tuning it is a looong learning curve, both in research and hands on [if read the right info making better or worse]..I'd say you need local hands on help but you do not state where you are located...
  22. Bill Rinaldi
    Bill Rinaldi
    Any idea what the reading gear is? 4:56 and higher (number) will baulk even more at low speed.
  23. oldtom69
    oldtom69
    from grandin nd
    no one has mentioned motor mounts? if the engine is moving at all during clutch engagement you will get erratic clutch engagement.common problem with 55-57 chevys that are still using the original front of the block motor mounts and then have a trans mount at the far rear
  24. 31Dodger
    31Dodger
    65pacecar and clunker like this.
  25. clunker
    clunker
    from Boston MA
    Not a bad triad of cars right there.
  26. slowmotion
    slowmotion
    No dis meant, but sounds like operator error. Let the clutch out & get that sum***** rollin'. No way in hell that car was ***embled/intended for low gear idling.
    And I agree, damn nice batch of cars ya got there.
    lothiandon1940 likes this.
  27. s55mercury66
    s55mercury66
    from SW Wyoming
    Ay
    Aye, I agree.
    65pacecar likes this.
  28. s55mercury66
    s55mercury66
    from SW Wyoming
    My fellow Buckeyes and I agree, get on it and drive it. An 1/8 mile aint even around the block.
  29. Jalopy Joker
    Jalopy Joker
    had a mild big block/4 speed / 9" OT '66 car that had tall rear gears that was never happy from a dead stop at low speeds. had to gently ride the (hydraulic) clutch.
  30. belair
    belair
    Don't go slow. Problem solved.
    lothiandon1940 and Boondoggle like this.
