Ford Eelco lift kit
Discussion in 'The Hokey Ass Message Board' started by 6t5frlane, Apr 18, 2005.
  1. 6t5frlane
    6t5frlane
    from New York
    Just found a new in the box Eelco front end lift kit probably from the 60's. Thinking of the B/FX look for my Fairlane. Anybody ever use one of these??? There are no instructions in the box
  2. 6t5frlane
    6t5frlane
    from New York
    C'Mon Hambers Somebody must have seen these
  3. beyondhelp
    beyondhelp
  4. Gasserfreak
    Gasserfreak
    from Yuma, AZ
    Which ones were they, like what years, I've had a set of these and they were very simple(in theory but a bit of work) to install. If they are the ball joint spacer ones, for 57 and up ford you just knock the rivets off the stock ball joints(alot easier said than done) install the spacer between the A arm and the ball joint with the long *** bolts that are in the kit and put the front end back together. pull the wheel off and look at the kit and the car and it'll come together.
    Hope this help a little.
    Drew
  5. 6t5frlane
    6t5frlane
    from New York
    Beyondhelp..Thanks...I'll keep looking around. I was hoping someone from the HAMB bopard may have used one in the past.
  6. Gary Jackson
    Gary Jackson
    I am running an Eelco lift on my 64 Cyclone. I don't have any handling issues, but I have broken a couple shocks. I think I have something binding which is causing the shock to break.
    kidcampbell71 likes this.
  7. Jalopy Joker
    Jalopy Joker
    post pics of your new find
  8. Henry J
    Henry J
