Technical Help me identify this front end
Discussion in 'Traditional Hot Rods' started by kiljoy, Jul 6, 2017.
  1. kiljoy
    kiljoy
    Anyone know what year and model this is from? looks like late 40's ford to me but im not sure. Any help would be appreciated. [​IMG]
  2. BJR
    BJR
    Picture doesn't show.
  3. timwhit
    timwhit
  4. Flatblack 31
    Flatblack 31
    X3 [emoji37]
  5. Texas Webb
    Texas Webb
    Nope...ERROR.
  6. kiljoy
    kiljoy
  7. kiljoy
    kiljoy
    hmm they are all showing up on my app/browser. did the last one show up for you all?
  8. landseaandair
    landseaandair
    from phoenix
    With the shock mount under the axle ends it should be F1 pickup, 1948-'52 Ford.
    kiljoy likes this.
  9. uncleandy 65
    uncleandy 65
    Looks like the one that was under my 1938 Chevy
  10. vtx1800
    vtx1800
    I agree with uncleandy 65, how many lug nuts on the wheels, if there are six it is probably a GM model. As I look at the picture again, if there is a factory stud to mount the shock then it isn't a GM (at least a 38)
  11. Chris
    Chris
    That is an F-1, like stated above 1948-1952
  12. Ask Sid at Nostalgia Sids. He's dropped hundreds of them and always has a stack (chevy & ford) out there in his shop. He could likely add more info.
  13. kiljoy
    kiljoy
  14. kiljoy
    kiljoy
    I know these hubs, backing plates and drums (if i had them) would work on 37-48 spindles but why cant i use these spindles on a 32-34 axle? What about the steering arms that make them not work with cross steer?
    Sent from my SM-N910P using The H.A.M.B. mobile app
  15. RICH B
    RICH B
    You can trim the l/h spindle ugliness along with the r/h arm and use aftermarket bolt-on steering arms; whether the cost of the arms and the labor time is worthwhile in comparison to buying a pair of '42-'48 spindles (which usually sell for less than "good" aftermarket steering arms) is something you have to decide. Picture is of a set of trimmed F-1 spindles. f-1 with arms.JPG
  16. kiljoy
    kiljoy
    are these arms designed for 42-48 spindles? what brands would you recommend? i like the way the ones in the picture you posted look.
  17. flatford39
    flatford39
    F- pick up like everyone else has said. Its cheaper to find 42 48 spindles than trying to make those work. The hubs, backing plates and drums are great on 28 thru 40 axles as long as you use the 37 39 or 42 48 spindles and matching king pins. Those are self adjusting bendix brakes and are sought after.
  18. Budget36
    Budget36
    And definitely F1 shock mounts.
  19. RICH B
    RICH B
    Any arms that are made for '37-'48 spindles will fit.
    The side steer arm is Super Bell, I think the lower arms were Speedway; but came with a project and I don't know for sure.
    I prefer the Ch***is Eng arms with the thru bolts, if you have to use bolt on arms.
    I only used this set-up because the parts were all on hand; preferable to use early spindles with good arms.
    kiljoy likes this.
