Projects My sport coupe project
Discussion in 'Traditional Hot Rods' started by nutrocker, Jul 1, 2017.
  1. jeffd1988
    jeffd1988
    When I seen that 6 inch cut I was like. Oh man I wasn't in on it. But reading all the way through and seeing what I didn't see this thing is freegin awesome. Good work good thread
    Sent from my Z981 using The H.A.M.B. mobile app
  2. nutrocker
    nutrocker
    For those that are interested the running gear spec:
    French block, modified for full flow oil filter
    Ported and relieved
    4-1/4" **** crank
    **** rods
    Ross 3-3/8" Pistons
    1.6" stainless valves on both inlet and exhaust
    Mellings M19 oil pump.
    0.395" lift 270F cam
    Edelbrock script heads
    Edelbrock slingshot intake
    2 x 'big' 97's
    Powergen
    Chevy dizzy with Peronix Ignitor 3
    Lighted flywheel.
    Gearbox:
    Volvo M40 fitted with Quaiffe straight cut close ratio gear set
    Volvo clutch plate with ZF hi torque pressure plate.
    Rear axle:
    Hot Rod Works full axle. Winters Quick change, Winters Wedgloc diff and 9" style axle shafts.
    Pete.
    KiWinUS and Stogy like this.
  3. sloppy jalopies
    sloppy jalopies
    haven't been here on the HAMB long,
    so to see that sportie go from stocker to rocker in just a few days was great...
    doesn't seem to go that way here at my house...
    Stogy, kiwijeff and nutrocker like this.
  4. raven
    raven
    First of all, I don't like sport Coupes, second of all, I don't like chopped A's. Especially 6"...
    That being said, I have to eat crow because this is the most bad-***ed sport coupe I have ever seen. The look and workmanship is pure genius. What a beautiful car, man what a beautiful car...
    r
    catdad49, sko_ford, brEad and 4 others like this.
  5. sloppy jalopies
    sloppy jalopies
    ditto on sport coupes... I convert them to coupesters...
    but the radical chop and tasty top take the "I'm a Cabriolet wanna be" sport coupe... and makes it look like a hot rod...
    ... job well done !
    19ChevyFleetline50 and nutrocker like this.
  6. redo32
    redo32
    I saw the 6" chop & thought "Here we go again" . A couple of post later I realize you're an experienced fabricator and doing some pretty nice work, so I opened my mind and followed along. When you said you did this in 6 months I decided I will shut my mouth. Nice job. Thanks for sharing.
    slv63 and nutrocker like this.
  7. haileyp1014
    haileyp1014
    from so cal
    Makes me wanna tear my sport coupe apart now.nice build
    nutrocker likes this.
  8. catdad49
    catdad49
    Sport Coupe Sweety! Wow, does it get any better?
  9. rodderbilly
    rodderbilly
    from italy
    Wow..really nice sportcoupe, like your works....
  10. the oil soup
    the oil soup
    from Tucson,AZ
    What is this for? image.jpeg The detail on this rod is absolutely tops!
  11. nutrocker
    nutrocker
    That is a battery isolator. I didn't like the big red key you normally get so made my own.
    sko_ford, Tim and kiwijeff like this.
  12. Mart
    Mart
    Pete, I said at Pendine the car looks great. I can see now what is under the skin. Mate, it's simply outstanding. Fantastic workmanship. 3-3/8 by 4-1/4. I can see how you got that shirt now. Congrats. I know it ain't easy. I'll have to stick my head under it next time. (Gow?)
    All the best Mate.
    Mart.
  13. the metalsurgeon
    the metalsurgeon
    from Denver
    love this car,and your clean workmanship!
  14. nutrocker
    nutrocker
    Cheers Mart, and congrats to yourself, the shirts suits you too.
    Yeah the motor is 304ci and unlike last year it seems to want to rev better. That's what gave it the edge from last time, that and the oil pump not failing!
    Hopefully it'll be at GOW! So you can have a good nosey around.
  15. the oil soup
    the oil soup
    from Tucson,AZ
    Do you have a photo of the switch before installation, may have to do something like that on my ride.
  16. nutrocker
    nutrocker
    Just like this one.
  17. the oil soup
    the oil soup
    from Tucson,AZ
  18. HotRodHoon
    HotRodHoon
    Read this thread several times its just plain cool.
    slim38 and AmishMike like this.
  19. Bills 50
    Bills 50
    from Roanoke Va
  20. FOURTYDLX
    FOURTYDLX
    Looks pretty good to me.
  21. IronFord
    IronFord
    from NoDak
    Awesome build!!!
    sko_ford likes this.
  22. nutrocker
    nutrocker
    Thank you again for the nice comments.
    Pete.
  23. WillemVelde
    WillemVelde
    Love this build! As others said, the 6 inch drop was scary at first but you made it look great! I came to this post as I was thinking about an m40 volvo box to put behind my 59a engine. You used an truck bell housing by the looks of it. Does the volvo box fit behind this and does the shaft have enough length or does it need adapters? Maybe some pics of this if you don't mind me asking...
  24. Tim
    Tim
    from KCMO
  25. Tall t 26
    Tall t 26
    Awesome build. Very much a head Turner.
    Chop looks killer. Love the look.
    Thanks for sharing.
  26. gnichols
    gnichols
    from Tampa, FL
    Outstanding car.
  27. edcodesign
    edcodesign
    A++++ Great !!!!
  28. rcavaliers
    rcavaliers
    from downey
  29. LKR
    LKR
    from Australia
    Excellent work. As a fellow sport coupe owner I really appreciate you being able to transform it into something that looks so great. Making it look easy!
  30. sloppy jalopies
    sloppy jalopies
    just picked up a rough pair of sporty quarters and a fair tulip panel...
    … go sporties go !
