Technical Missing steering link
Discussion in 'Traditional Hot Rods' started by kimfmx, Jul 7, 2017.
  1. kimfmx
    kimfmx
    Hi.
    Have purchased a teflon repair kit for the tie rod links for 32 ford. [​IMG]
    The nut on the left is different than the other 3. Am i missing something?.
    I cant find an exploded view of the ***embly, and doubt it was put together correctly originally.
    Also. Is the ball link the same between steering arm and tie rod.
    Best regards
    Kim mortensen.
    Sent from my SM-G850F using The H.A.M.B. mobile app
  2. jseery
    jseery
    from Wichita KS
    Does the Green Book diagram help any?
  3. kimfmx
    kimfmx
    Yes actually! But still cant figure out the different nuts.
  4. Mr48chev
    That plug looks like and old style no insert plug. More like is what is on my 48 Chev than what the Ford green book diagram shows.
  5. kimfmx
    kimfmx
    What is the name of that green book. I should get me a copy of it.
  6. TagMan
    TagMan
    The "Green Bible" is the Ford issued "Ch***is Parts & Accessories Catalogue (ford's spelling)" issued by FMC and it covers p***enger cars from 1928-1948 and trucks 1928-1947. It's available from most major vendors in book form or as a CD. I have a copy of the CD format for sale, if you want that one.
  7. kimfmx
    kimfmx
  8. kimfmx
    kimfmx
    Ok. Hazzled with the ball joints today, as i could do one side. I found that the ball was badly warn, so a new one is needed. However i notised from the setup that depending on how much i tighten the link adjusting screw, i change the toe in setting. And that goes for both sides. If i tighten the nut i do toe out, this cant be a right setup.
  9. kimfmx
    kimfmx
    In another way... if i push the wheels through a sand dune they will toe out because they are held in by two springs only...
