Projects Chopped Fendered Model A?
Discussion in 'Traditional Hot Rods' started by Hombre, Jul 7, 2017.
  1. Hombre
    Hombre
    I have decided I want to chop my full fender'd Tudor Model A. My other Model A is a fenderless car and I chopped it 61/2". I have looked and looked for examples of chopped Tudor's and have not had much luck finding one with fenders and a chop. I am thinking somewhere around 4 or 41/2" might be good on this car, but I sure would like to see some examples before I break out the saw. Anyone got some pictures of chopped Model A sedans with fenders?
    Here's a picture of mine as it is today, I really want to change that. IMG_2757 (Small).JPG
    kiwijeff and 28 Ford PU like this.
  2. alchemy
    alchemy
    Are you doing anything else to the car? Changing wheels or stance? I think those things should be done first, as they will influence the style of car. And the chop should match the style.
  3. 28 Ford PU
    28 Ford PU
    from Upstate NY
    jeffd1988, thomas h, Dino 64 and 4 others like this.
  4. justabeater37
    justabeater37
  5. paul55
    paul55
    from michigan
    kiwijeff, 1lucky1, mgtstumpy and 3 others like this.
  6. Hombre
    Hombre
  7. Hombre
    Hombre
  8. Tim
    Tim
    from KCMO
  9. upspirate
    upspirate
    Best bet would be to photoshop chop it first.
    I personally like 2-2 1/2 " on a model A
  10. green73
    green73
    Two things to think about with chopping the Tudor. 1: Drop the front seats to match the chop (kind obvious). 2: Rear Window size. Looking through the rear view mirror and a smaller rear window may be a challenge. I would try and keep the back window as tall as you can. Just my worthless $0.02.
  11. akoutlaw
    akoutlaw
  12. swifty
    swifty
    Fred Steele had an early A sedan which was chopped 6" in the early 60's and he didn't drop the seats as green73 suggested and it was a real pain in the neck riding in that thing. Marcus Edell has it now and it's for sale on the HAMB cl***ifieds. I'll see if I can find the link and post it.
    19ChevyFleetline50 likes this.
  13. swifty
    swifty
    Hombre likes this.
  14. Steffen Jobst
    Steffen Jobst
  15. deadbeat
    deadbeat
    wow that was fast,,lol,,Good job Steffen
    zbuickman and Steffen Jobst like this.
  16. Steffen Jobst
    Steffen Jobst
  17. Steffen Jobst
    Steffen Jobst
  18. Steffen Jobst
    Steffen Jobst
    In the digital space age everything is so easy ...
    deadbeat likes this.
  19. Steffen Jobst
    Steffen Jobst
    Ok, that's stupid now...
    deadbeat, Hombre and Dago 88 like this.
  20. Just Gary
    Just Gary
    I'd lower the front end first - give it a proper hot rod stance & tuck those front tires under the fenders - before thinking about chopping it.
    B Bay Barn and 1stGrumpy like this.
  21. sloppy jalopies
    sloppy jalopies
    nice work SJ, not just chopped, but lengthened and shortened versions... thanks
    Steffen Jobst likes this.
  22. Barn Hunter
    Barn Hunter
  23. Hombre
    Hombre
    Steffen, Man I envy your skills with that Photo Shop great work. Would you have any idea on how much chop that is? You have found the exact look I am wanting for this car.
    The stance on this car has changed quite a bit since I took those pictures. It installed a dropped axle that not only lowered the front of the car quite a lot and gave it a better rake, but also brought the front tires under the fenders. I also went with a little different rear tire as those were just to big.Steffens third picture is to me the perfect look.
    IMG_2873 (Small).JPG IMG_2873 (Small).JPG IMG_2874 (Small).JPG IMG_2875 (Small).JPG IMG_2762 (Small).JPG
  24. Steffen Jobst
    Steffen Jobst
    @Hombre
    My Photoshop skills are low level. I have seen on the HAMB much better work.
    That was pippifax. Only cut and paste.
    I have absolut no idea how much inch it was.
    But you can easily figure out by compare the difference between B and C and you get the percent it was chopped and you can measure this on your car. Make sure that in both pics A has the same size.
    Hombre and Ron Funkhouser like this.
  25. Steffen Jobst
    Steffen Jobst
    Attention!
    The body was also sectioned!
    deadbeat, Hombre and Ron Funkhouser like this.
  26. Steffen Jobst
    Steffen Jobst
  27. 56shoebox
    56shoebox
  28. mike bowling
    mike bowling
    I like the "Photo-Chopped" pictures- easy to fix!
    upspirate and Steffen Jobst like this.
  29. sloppy jalopies
    sloppy jalopies
    dig it !
    but I would stand a better chance of doing it in steel than on a computer... don't sell yourself short SJ.
  30. Steffen Jobst
    Steffen Jobst
    Is the car chopped now? Let's see pics!
