Hot Rods I am building a hotrod 1962 f-85 olds
Discussion in 'The Hokey Ass Message Board' started by Eric GILROY, Jul 9, 2017.
  1. Eric GILROY
    Eric GILROY
    from GILROY CA
    I bought this on craiglist . it was a 1962 f-85 olds cutl*** with factory 4 speed and alum 215 v8. the guy I bought it off wanted the motor back . I gave him motor and ****** back. here is picture of it when I got it. since then I have done some work to it. when I figure out how to use this forum better I could add pictures 2017_0417olds19620003.JPG
  2. Lebowski
    Lebowski
    Where are you from? It would be cool if you could find another Olds engine to put in it instead of one from a Chevy like everybody else. Good luck.... :)
  3. steinauge
    steinauge
    from 1960
    Neat looking cars. What are you figuring to use for an engine?
  4. Rusty O'Toole
    Rusty O'Toole
    The Rover company bought the tooling from GM and built the same engine for years and years. If you can find a wrecked Range Rover and buy the engine cheap. I don't know what kind of trans you could use.
    Another choice would be a 3.8 Buick V6 which is a close relative.
    Otherwise a Chev V8 would be cheapest.
  5. wisdonm
    wisdonm
    The Buick 300 is a cast iron stroked version of the 215, but I would go with a Rover.
  6. The last time I was in one of those cars was when my mother worried about popping the key out of the ignition while the car was running. I was about 5. Dad was running a drawbar pull J.I.Case combine with a cotton belt to feed the thresher, tractor PTO and ground wheel powered mechanicals. Car was primarily white in color.
    Looks like the front wheels are related to Pinto or Ford Capri.
    Make Mondello happy! Make it Olds!
  7. haychrishay
    haychrishay
    I have a complete Olds 215 4bbl Engine if you're interested
    6inarow likes this.
  8. Eric GILROY
    Eric GILROY
    from GILROY CA
    first thing i did was build a jig to hold it level . then i cut out the pressed sheet metal frame members out.
    catdad49 and mgtstumpy like this.
  9. Eric GILROY
    Eric GILROY
    from GILROY CA
    here are some pictures of where i am at on it, I am in Gilroy ca. making a straight axle , 4 speed g***er type hotrod. 355ci chevy with tunnel ram and two fours.
  10. "first thing i did was build a jig to hold it level . then i cut out the pressed sheet metal frame members out."
    OK, that pretty well says Hot Rod alright!
    (I've got a 215 4bbl w/auto sitting in the garage for the last 50 years too!)
    catdad49 likes this.
  11. Eric GILROY
    Eric GILROY
    from GILROY CA
    so far i got front axle and rear end in ,today i am working on a panhard bar.
  12. 1934coupe
    1934coupe
    haychrishay I think we are waaaayy beyond that now. I just gave some new motor mounts to a guy in Portland OR who is putting one of those engines in a 33 Willys.
    Pat
  13. Eric GILROY
    Eric GILROY
    from GILROY CA
    The car i bought was sitting in a barn in napa ca , since 1972 . it had so much rat **** though out the car and a giant nest in the trunk it took me days of power washing with bleach just to start working on the car. any way i found a little booklet in the glove box that the owner had used in keeping a very accurate account of the gas mileage on the little 215 v8 its was not to good mostly around 13 mpg.
    kidcampbell71 and catdad49 like this.
  14. gbazinet
    gbazinet
    Does this have the 15" 4bolt rims? Or 13" like the Buick Specials?
  15. chevy57dude
    chevy57dude
    Love it! The grille/front end is nice looking. Best thing to do with an early '60's GM compact is to lose the factory driveline. Apologies to Winnona..
    Tickety Boo likes this.
  16. That thing is cool. Nice shop too!
  17. To help with your choice of engine........Jack Brabham, an Oz driver of some note had a word to Phil Irving an engineer of some note and both had a word to an Oz company Repco in the early 60's and came up with a few SOHC heads and other bits to make the 215 get up & go.............I don't know if a Repco Brabham engine would fit but would certainly put a smile on a few faces.....lol.....cost might be a small issue tho'........lol......on a more down to earth choice, Leyland here in Oz used the 215 and came out with a 260 cube version in 1973-75 in the Oz only Leyland P76...........anyway back in reality, your car, your choice but neat car.....Rusty's suggestions are probably the most sensible........lol........regards, andyd
    61Cruiser and kidcampbell71 like this.
  18. Eric GILROY
    Eric GILROY
    from GILROY CA
    yes 4 bolt 13 inch i dont need them are you looking for some
  19. Eric GILROY
    Eric GILROY
    from GILROY CA
    yes your right it was a tiny little two piece deal no way it would power a heavy 9inch ford, and the clutch being side stepped at 4 grand lol
  20. JimSibley
    JimSibley
    Love those cars. I had one for years with a 350 chevy, 4 speed and a pinto front end.
    chevy57dude likes this.
  21. NashRodMan
    NashRodMan
    That's gonna look killer as a g***er.
  22. quick85
    quick85
    I'm surprised no one (as of yet) balked at your plan to axle this car, especially since it seems like
    a righteous ride. So I'll be the first, but I realize it's your car, not mine.
  23. sunbeam
    sunbeam
    Get a 350 Buick paint it with aluminum paint and keep quiet.
    60F250 likes this.
  24. Bird man
    Bird man
    from Milwaukee
    Beats the hell outa a falcon, huh? ;)
  25. NashRodMan
    NashRodMan
    I'm glad no one balked at his plan! Screw that...axle that *****! Otherwise its just a grandma car!!
  26. CNC-Dude
    CNC-Dude
    I think a Nailhead would give it a cool G***er look!
    1927graham likes this.
  27. Eric GILROY
    Eric GILROY
    from GILROY CA
    set up where i want engine set back to be, waiting on a set of fenderwell headers to come in from speedway motors to finalize the location. my guy that was putting together the engine was in a bad accident and is in coma from a driver who was texting and driving. plowed right into him at a stop sign.
    Tickety Boo and catdad49 like this.
  28. Eric GILROY
    Eric GILROY
    from GILROY CA
    as of 7-17-17
  29. Eric GILROY
    Eric GILROY
    from GILROY CA
    waiting for my clutch to show up so i can drop motor in.
  30. Eric GILROY
    Eric GILROY
    from GILROY CA
    engine in starting on roll cage
