Projects Central Cali auto body/paint shop recommendations
Discussion in 'The Hokey Ass Message Board' started by soddruntlestuntle, Jul 7, 2017.
  1. soddruntlestuntle
    soddruntlestuntle
    from Fresno, CA
    Hoping to finally get my ever-so-slightly-OT '66 Skylark straightened & painted, and am looking for some body shop recommendations. Not needing anything fancy (can't afford it), just a good, solid shop that knows older cars. On a tight budget, so cost will be a YUUUGE factor. Any thoughts?
  2. Jalopy Joker
    Jalopy Joker
    have used MAACO body & paint services for years - check them out and see if they work on older cars at shop near you - no matter where you go have to have lots of patience - and expect the unexpected when sanding down old paint
  3. Budget36
    Budget36
    2nd MAACO...just take as much off the car as you can, really helps to do some prepwork as well.
  4. soddruntlestuntle
    soddruntlestuntle
    from Fresno, CA
    Thanks folks. Yep, I'm going down to Bare Metal as I really want to make sure there are no surprises lurking under the layers. So far found a bit more filler than I'd like, but no rust, no patch panels, pretty clean all things considered.
  5. impala59
    impala59
    from vallejo,ca
    I just got to ask.... What's your budget?
  6. Stovebolts
    Stovebolts
    I work with a old man in Mariposa that has been doing body and paint for over 63 years. He no longer paints but he still going strong on the bodywork. He is a true craftsman. I will PM you his number incase your interested.
  7. soddruntlestuntle
    soddruntlestuntle
    from Fresno, CA
    At this point, probably less than $3k.
  8. impala59
    impala59
    from vallejo,ca
    Then for sure Maaco. If you want a nice job and not experienced, find a Professional bodyman to prep it at a under the table fair hourly rate and not try to charge a shop rate of $125 hour. have him block it ready to paint status then have Maaco shoot it.
