Projects 50 Chevy Southeast Gasser build (Purple People Eater)
Discussion in 'The Hokey Ass Message Board' started by Purple_People_Eater, Jun 13, 2017.
  1. Fiddle Picker
    Fiddle Picker
  2. chevy57dude
    chevy57dude
    Great progress! Any idea how much the Hightower transmission costs?
  3. southcross2631
    southcross2631
    The last I heard a southeast G***er member can buy one for $3750.00. As Hightower is one of the series sponsors and gives a discount.
    Purple_People_Eater likes this.
  4. Purple_People_Eater
    Purple_People_Eater
    Been busy at it. Spindles, king pins showed up so I installed them. Lucky for me they were a returned item and someone had honed and fitted the bushings. Also got the old front body mounts cut off and welded in the new front perches for the roll cage. knocked the hot rivets out of the rest of the crossmember and removed it. Engine is setting within a few inches of final placement now.
    [​IMG][​IMG]
  5. saltflats
    saltflats
    from Missouri
    Looks like you better change that shift knob.....you don't want to be behind the 8 ball all the time.
  6. Fiddle Picker
    Fiddle Picker
    I used those same headers on my 53 Chevy Wagon drag car. Got them un-coated hoping for the best.
    Had to cut the collectors off and go to 3 inch. Then, I had to cut and extend every one on the driver's side to clear the factory steering box. I see they will work for you thanks to relocating everything else !
    Nice work !! Keep it up.
  7. Purple_People_Eater
    Purple_People_Eater
    Yeah more like change the whole transmission. Don't think that saginaw is going to like high rpm launches too much. Haha
  8. southcross2631
    southcross2631
    That Saginaw will work for mock up only. It will break when you hammer it. go with the good stuff to start with and you will be money ahead. Broke in the wallet ,but not on the track.
  9. Purple_People_Eater
    Purple_People_Eater
    Yeah I am going to buy the good stuff for sure
  10. Purple_People_Eater
    Purple_People_Eater
    Slow progress lately, just working on the roll cage.[​IMG][​IMG][​IMG]
    Ordered rotors and bearing for the front so I can get some wheels back on it for now. Ordered my low back seats. And I got a 12 point conversion for the 10 point cage. I am in search of a another engine now. When someone walks into your shop willing to pay $700 for a rebuildable 327 you don't refuse. Possibly going to find a BB now.
    Dog_Patch and loudbang like this.
  11. southcross2631
    southcross2631
    A big inch small block will put less weight on the nose. You already have headers for the small block.
    I thought about going with a .030 over 429 after I get all the bugs out with my 306.
    If you are going to run with the Southeast G***ers, remember weight per cubic inch.
    Check and see how often a big block wins at their races.
    loudbang and Purple_People_Eater like this.
  12. Purple_People_Eater
    Purple_People_Eater
    I agree on the big cubic small block, the BB idea isn't set in stone.
  13. neal 136
    neal 136
    I'm getting ready to build a 50 Chevy coupe for seg didn't realize I could to the set back. What cl*** are u looking to run it in
  14. Purple_People_Eater
    Purple_People_Eater
    Hopefully C cl*** for starters maybe A one day
  15. Purple_People_Eater
    Purple_People_Eater
    Got ahold of some Ansen 15x10 Sprints for $200 came with some 15x7 also.[​IMG]
    Dog_Patch, OahuEli, loudbang and 3 others like this.
  16. saltflats
    saltflats
    from Missouri
  17. Purple_People_Eater
    Purple_People_Eater
    Thanks I thought that was a steal
  18. Fiddle Picker
    Fiddle Picker
    I'm Jealous !! Great Deal !!
  19. southcross2631
    southcross2631
    Super deal on the rims. My progress has stopped until I deliver this shorty wagon next week.
    With the car count that they have and the amount of cars being built I look for another cl*** being added. Maybe between A and C/Gas.
    That could be why they never had a B/Gas. So they had the option later.
  20. Baumi
    Baumi
    Great build and awesome deal on the wheels!
  21. Purple_People_Eater
    Purple_People_Eater
    Thanks! Yeah I was getting curious about what was going on with your build. Yeah they just might have to add a B cl***. Lots of cars being built.
  22. Purple_People_Eater
    Purple_People_Eater
    Few more progress pics [​IMG][​IMG]
    Oh and my 29.5x10.5x15 M/T slicks i got that has 8 p***es on them I got for $200 today
  23. Fiddle Picker
    Fiddle Picker
    Nice work. I have a question. Are you going to take advantage of the engine setback? I noticed your support bar in the main hoop. Will put your seat in stock location and your distributor will be right at your foot line or close to your knees. Guess I'm a little conservative or just don't want the chance of exploding metallic stuff that close even with a ****ter shield. you could curve the bar and allow more room to set the seat a little further back. Just a thought. Keep up the good work and approach !
  24. Purple_People_Eater
    Purple_People_Eater
    Yes I am going to setback the engine as far as I can possibly go/ allowed. That's why I haven't committed to tack welding the support cross bar in the main hoop. In case I do end up needing to set my seats back further. I will have a new support cross bar bent in a "C" shape to get the clearance I need. Can't really make that call, until I get a Engine/****** mounted. And get the seats mocked up. Thanks man
    Dog_Patch, Fiddle Picker and loudbang like this.
  25. southcross2631
    southcross2631
    Makes no sense to set 550 lbs back and not move your own body weight back to totally take advantage of the set back rule. It will also make your foot box larger.
    Which is a real problem with my car. I have already moved my front down tube out 2 inches to give me more foot room . Now trying to get room for 3 pedals and a ****** tunnel. Probably going to use a hydraulic throw out bearing because the fork will be in the way of my feet. I am back as far as I can go. Right at the rear frame kick up.
    Good deal on the slicks. I need a deal on some 28 x 9 's . I may take advantage of the 9 inch radial slick rule.
  26. enloe
    enloe
    from east , tn.
    Oh great now I have another g***er thread to watch
  27. Purple_People_Eater
    Purple_People_Eater
    Guess you can say things are getting kind of serious...
    [​IMG][​IMG][​IMG][​IMG]
    Oh and I got my 9" I'm going to cut down.
  28. Fiddle Picker
    Fiddle Picker
  29. Dog_Patch
    Dog_Patch
    You and me both - just found this one and it's looking good!
  30. savannahDan
    savannahDan
    Just to echo whats been said earlier, and I'm not racing yet - still building, but over 70% of my build budget will be for driveline components. I'll cheap out on paint and interior if it allows a bulletproof drivetrain to fit the budget. Also, planning ahead and buying used as you come across deals will help alot.
    Watching this thread now too (along with all the the other southeast g***er builds)!
