Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. Blue One
    Blue One
    from Alberta
    Yes, the time is intense. But I'm actually starting to enjoy it.
    Because things are going good.
    I'm wearing a good 3M respirator all the time and working outside in front of my garage.
    Using my air hose to blow big clouds of dust away.
    Better than in the garage :D
    I'm awful glad not to be doing this for a living :D
  2. Now you guys will understand my signature sentence I took from the lyrics of a song written by the late great Waylon Jennings, " I'm a little bit crazy, but it stops me going insane ". When I think back to the amount of lead filler that I sanded using electric tools etc without any face mask and then the body fillers of old which only God or a chemist would know what was in it, then I'm surprised that I still have excellent lungs. But then I only took up the bad habit of smokin' in my early twenties and then only for approximately three years before I decided I was wasting valuable money that could be spent on my next project. I am so looking forward to getting out into the workshop again and working on the body of my Roadster. :mad:;)
    t-rod, brad2v, Blue One and 1 other person like this.
  3. 26 T Ford RPU
    26 T Ford RPU
    You are doing such a good job Larry and you will be able to stand back with a big smile and say.......''****.....I did that'':cool::cool:
    Marc, I hope you get out into your garage soon buddy. JW
    Blue One likes this.
  4. Thanks Jeremy, but our judiciary in the family court system are so busy, my lawyer is now thinking it will be between September and Christmas before we can have a resolution to the issues that have unsettled my life and Mums'. Never mind, now back to the programmed channel and sanding dust and nice smooth finger tips.
    Blue One and loudbang like this.
  5. Tim_with_a_T
    Tim_with_a_T
    From one novice to another, wait until the very end to screw it all up LOL.
    eddie1, t-rod, Blue One and 1 other person like this.
  6. Tim_with_a_T
    Tim_with_a_T
    Really though, one thing I've noticed in my limited time around body shops is to pay attention to your air hose while spraying. It's easy to drag it across something freshly painted or get it snagged on something then F up your spray pattern.
  7. loudbang
    Pick up some GOOD tac clothes for a last minute wipe down just before you start spraying. :)
  8. K13
    K13
    Glad I could help Larry.
    It was cool to get to see your progress in person but now after seeing how small that body is I really don't want to hear any more complaints. :D
    Looking forward to future updates.
  9. Blue One
    Blue One
    from Alberta
    Ok, I promise, no more complaints :D I think I'm getting past the worst of it now so it's looking up :)
    I went on Eastwood and ordered a run razor and some tiny little aluminum blocks :cool: (just in case ;))
    I also ordered some good tack cloths.
    Took the day off today because it's my B'day :D
    Thanks for the product and moral support too :)
    t-rod, brEad, loudbang and 2 others like this.
  10. Dick Stevens
    Dick Stevens
    Happy Birthday Larry, I am anxiously waiting to see the paint job when you get it done! I'm sure it will look very good when you get it finished as you are wired to make things top shelf.
  11. loudbang
    Now I know why your are so meticulous in your work. We are both "cancers" my BD was the 9th LOL :)
  12. tfeverfred
    tfeverfred
  13. Blue One
    Blue One
    from Alberta
    Patience Fred :D
    I just spent another 8 or 9 hours block sanding and then filling and then sanding most of it off and more blocking :D
    Spent about half the day prepping the pickup bed.
    Then lots of time fussing with the edges all around the body and bed.
    Getting close to being satisfied to where I can lay on the high build.
    Progress is being made :D ;)
    Larry
    brad2v, whiplash1923T and loudbang like this.
  14. Blue One
    Blue One
    from Alberta
    Happy late Birthday.
  15. Blue One
    Blue One
    from Alberta
    Taking a break so that the first coats of high build can dry :cool:
    That stuff is thick :cool:
    I'll spray the bed next :)
  16. Blue One
    Blue One
    from Alberta
    The body and doors and the grille shell are coated with a nice heavy layer of high build polyester primer -surfacer. :cool:
    Now for the bed...
    AndersF, Tim, loudbang and 4 others like this.
  17. Blue One
    Blue One
    from Alberta
    My days work, an ***ortment of parts basking in the sun :D :cool:
    A little more sanding ahead now :D
    Larry
  18. tfeverfred
    tfeverfred
    Smooooooth.
    loudbang and Blue One like this.
  19. Dick Stevens
    Dick Stevens
    Maybe we should start calling you the "Sand Man"? o_O:rolleyes::D:p:)
    loudbang, Blue One and tfeverfred like this.
  20. Blue One
    Blue One
    from Alberta
    I'll fill your eyes with sanding dust and you won't even have to be sleeping ;) :D
    rjgideon and loudbang like this.
  21. Dick Stevens
    Dick Stevens
    I'm not worried, it is too hot around here for you! :D:p;)
  22. Blue One
    Blue One
    from Alberta
    Probably so although the temperature here today was 30 C - 86 F.
    I had everything done before the heat of the day kicked in, it's about 15C in the early morning.
  23. Dick Stevens
    Dick Stevens
    You do what you have to do, work when it works for you, just get the job done!
    We had a break in the weather, it was about the same here, just not as cool in the morning.
  24. loudbang
    Now you can understand why low man on the totem pole or any apprentices get stuck with sanding work. And it sure isn't "So you can learn the trade" like the older guys tell you. :rolleyes:
    brad2v and Dick Stevens like this.
  25. Six Ball
    Six Ball
    from Nevada
    How do you keep the High-Build primer from filling the details like the panel line and the Ford lettering in the tailgate? How do you get to the tailgate latch brackets and rivets to keep them from looking like gobs of old paint?
  26. K13
    K13
  27. Blue One
    Blue One
    from Alberta
    You sand down smoothly around them by hand and then the details appear as they should be and you can then proceed to go on your crime spree ;) :D as your fingerprints are no longer there :D:D
    :p I'm slow but I'm striving for quality ;) And the hours pile up...... :D
    Sure glad I work cheap :D
    whiplash1923T, loudbang, OFT and 3 others like this.
  28. brEad
    brEad
    Looking good! It will all eventually be worth it.
  29. Blue One
    Blue One
    from Alberta
    Are we there yet :D ?
    Another day closer.
    Started at 6 AM and fine tuned a few low spots I found while blocking the high build.
    After that I realized that the one side of the cowl that had been coated heavier than the other parts of the body (it's a mystery :D) with high build blocked and out really nice and smooth.
    So, cleaned it up and back in the booth and shot another 2 coats of high build.
    It's sanding out really nice now :cool:
    Spent a bunch of time on the firewall.
    Stopped at 5 PM.
    Tomorrow will be blocking with 320 and then 400.
    That's just the body, then there are all the other parts like the doors and bed, all of which have had some attention but need more. :D
    I have to say I'm actually enjoying this.
    brEad, t-rod, AndersF and 4 others like this.
  30. 26 T Ford RPU
    26 T Ford RPU
    Getting more exciting as the days go by.:cool::cool: JW
