Projects new member. watch me section my Desoto.
Discussion in 'The Hokey Ass Message Board' started by rytang, Jun 29, 2016.
  1. choptop40
    choptop40
    Nice....well be waiting in anticipation for the doors .....
    rytang likes this.
  2. Tim
    Tim
    from KCMO
    I'm just waiting for you to realize that you need to re drill some of those holes for something lol
    brEad and rytang like this.
  3. rytang
    rytang
    from Arizona
    Well yeah, but there won't be 300 extra holes. Also if you zoom in on the drivers side hood hinge, there's a huge hole there for wiring.
  4. GordonC
    GordonC
    Going to be kind of hard to drive it from that seat position won't it!:D
    rytang and brEad like this.
  5. IowaMercMan
    IowaMercMan
    Great combination of vision, talent, hard work and persistence. It takes a long*** time to build a car.
    timmy2times likes this.
  6. Wow bro you really got back at it i havent checked in here for a while and bam your gettin stuff done good work
    sent while dropping a deuce
  7. Ryguy442
    Ryguy442
    from Nc
    Man just went thru this whole build, gotta tell ya your doing some killer work. It's funny I did a very similar treatment to the rear end of a 55 chevy convertible for the shop I work for. I did 56 tail lights with one piece lenses and tucked and frenched a wagon bumper. Even made a new body line just above the number to give it something to tuck into. I won't highjack your tread with a bunch of pics, I'll just show one. I only have one tail light done in the pic to show the difference. [​IMG]
    13lav, rytang, Peanut 1959 and 5 others like this.
  8. choptop40
    choptop40
    Hey hey , that hole is the same one I used for my wiring , have one for throttle cable and that's it , great minds think alike...
    rytang likes this.
  9. rytang
    rytang
    from Arizona
    20170721_110822.jpg 20170721_113309.jpg 20170721_123341.jpg 20170721_130049.jpg 20170721_150720_HDR.jpg Removing some bad metal work from the door jam. Replacing it with some mediocre metal work. It's all practice.
    RockinRivi, Stogy, kiwijeff and 8 others like this.
  10. Ray C's son
    Ray C's son
    Hey, don't sell yourself short, Rytang, that's what we're all here for. Seriously, though, you're killing it. Great work.
    Kevin
    whiplash1923T and rytang like this.
  11. GEBHARD
    GEBHARD
    from TX...
    Awsome build! Just read this whole thread
    rytang likes this.
  12. rytang
    rytang
    from Arizona
    Filling more holes on the drivers side. And fixing factory spot welds. 20170722_120242.jpg Pretty sure this is a bullet hole. 20170722_121802.jpg All welded and ground. Welded every single pin hole. Now just have to do it to the rest of the car 20170722_164817.jpg 20170722_181306.jpg
    j-jock, RockinRivi, kiwijeff and 8 others like this.
  13. tb33anda3rd
    tb33anda3rd
    while your there, weld a ground stud on the inside of the cowl under the dash. will help when wiring it.
  14. rytang
    rytang
    from Arizona
    What do you mean? Sorry this is my first time doing anything like this.
  15. tb33anda3rd
    tb33anda3rd
    when ever i get the opportunity, i will weld a 1/4" bolt to the inside of the cowl firewall. tape it off so it doesn't get painted, then when it is time to ground the radio, gauges, dash lights etc. i have a solid point to run a ground wire too. otherwise you will have to drill a hole or use a screw to ground to.
    just real easy to do it at this stage of the build with the welder right there.
  16. rytang
    rytang
    from Arizona
    Thank you
    triman62 and Tim like this.
  17. rytang
    rytang
    from Arizona
    That's Awesome! What did you do with the old taillight sections? I wanted 55 tails on mine so bad. 56 was what I had.
  18. Ryguy442
    Ryguy442
    from Nc
    Well I used the lower half the old section or the stock 55 housing, did some reshaping and moved it lower. The rest of the tail light surround I had to make from scratch. I used to have a bunch of pics of the process but not sure were they are. I did a **** ton of custom work on that car. The left side tail light is motorized to swing out of the way for the gas filler neck. If I come across those pics I'll share them with you. Get back to work your making some killer progress!
    Ryan
    Ps I'm going to steal your idea on mounting the shrinker/stretcher to my English wheel. Might even mount a place for a beater bag and post dollies on there!
  19. Ryguy442
    Ryguy442
    from Nc
    I found on if the in progress pics. [​IMG] all the metal work done on this car was done with just basics and tools and a mig welder. I wish I had my tig welder at the time but I was in between welders then. Since then I bought myself a new tig, and my boss has bought a tig for the shop. So now that misty what I use
    AndersF and kidcampbell71 like this.
  20. Early Ironman
    Early Ironman
    I do this too, but weld a bunch of 1/4" bolts along the inside of the body seam at the top of the firewall. Great for hanging a wire run, Mounting a vintage air a/c evaporator, mounting the fuse block, and using for a convenient ground. Then paint the entire under dash area white for the best visibility possible.
  21. rytang
    rytang
    from Arizona
    I didn't take you guys on the ride for this one. But I cut out the bad section of the p***enger side. Couple pin holes to fill, and this part is done. 20170726_182941.jpg
    RockinRivi, kiwijeff, Sancho and 4 others like this.
  22. rytang
    rytang
    from Arizona
    20170727_125015.jpg 20170727_134332.jpg 20170727_134347.jpg 20170727_170856_HDR.jpg Ehh why not? I'm not gonna bolt the fenders back on anyway.
    j-jock, RockinRivi, Tim and 5 others like this.
  23. choptop40
    choptop40
    .?????? Tilt nose?
  24. rytang
    rytang
    from Arizona
  25. The37Kid
    The37Kid
    Just noticed something for the first time, you never had rust problems to repair. Bob
  26. Early Ironman
    Early Ironman
    Nice work, your making good progress!
    rytang likes this.
  27. rytang
    rytang
    from Arizona
    Most of the rust is in the floor and rockers. But the car was pretty decent.
  28. rytang
    rytang
    from Arizona
  29. Tim
    Tim
    from KCMO
    Probably a tilt nose with a dancing hydraulic set up like you'd see on the bed of a mini truck. Sure makes a scene out of checking your oil lol
    rytang likes this.
  30. Ralphies54
    Ralphies54
    That looks great. I had my doubt about how you were going to tackle it but you feffin did it in spades. Now, on to the doors?? Fabulous work!!! Ralphie
    rytang likes this.
