Projects 53 ford customline aerostar springs
Discussion in 'The Hokey Ass Message Board' started by Dom138, Jun 23, 2016.
  1. Dom138
    Dom138
    Hey guys so I've read a lot of threads on the aerostar spring swap for 50s fords. Sounds perfect and will actually raise my front end a little since my current springs are cut to hell and sagging badly. I'll probably be going from a nose down stance to more of a taildragger look. Was wondering if anyone can walk me through the process of removing the old springs and shocks. The walk-throughs I've read have been mid to late 50s models so I'm not sure if it's different aside from king pins vs ball joints.
    Thanks
  2. O.Hove
    O.Hove
    from S.D.
    They work in 57 - 59
    Not sure about earler
  3. bobss396
    bobss396
    They are actually better in the '52 to '56 cars. On my '59 with 15" tires I had a tire s****e issue on tight turns. I may toss them back in with a spacer.
  4. 59f100fan
    59f100fan
    from hawaii
    Thanks for this thread just used all the info to get my 53 set up[​IMG][​IMG]
  5. 59f100fan
    59f100fan
    from hawaii
  6. bobss396
    bobss396
    On my '59 Ford it was close to a 4" drop.
  7. paleot
    paleot
    from louisiana
    Got them in my 53, ended up using a 1 1/2 spacer to give me a stock stance
