Technical Porta Walls
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jul 15, 2017.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Yeah,I know it's been discussed in the past but ladyhrp want's whitewalls on our vintage 1957 Shasta camper and the camper already has brand new ST tires designed for campers.
    Anyone have a positive results with using porta-walls on something that doesn't see daily use? HRP
    ladyhrp and 3W JOHN like this.
  2. 302GMC
    302GMC
    from Idaho
    14'' or 15'' ? PM me if 14'' ...
    ladyhrp, 3W JOHN and HOTRODPRIMER like this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    D'oh, the tires are 15". HRP
    ladyhrp, 3W JOHN and Petejoe like this.
  4. 302GMC
    302GMC
    from Idaho
    %^%(@#@*(!!*$%, anyway ...
  5. Jalopy Joker
    Jalopy Joker
    have seen problems even at installation, and even driving at low speeds - know if there is a "hidden" whitewall under black that WW can be exposed?
  6. TagMan
    TagMan
    It's been a long time (50+ years), but the ONE time I tried using porta walls, I had nothing but trouble and wound up taking them off and tossing them. They were such a disappointment, I still remember them and that's saying something, since I don't remember what the hell happened yesterday !
  7. wheeltramp brian
    wheeltramp brian
    i used them for a while .they make a flapping sound at low speed.the smaller the better.as in 2" instead of 3".
  8. Chili Phil
    Chili Phil
    Those things have ALWAYS been cheesy. The fact that they are vintage does not make them cool.
    ladyhrp, 3W JOHN, hotroddon and 2 others like this.
  9. HOTRODPRIMER
    HOTRODPRIMER
    I have been researching tires,the ST tire designed for campers are of a different construction and have a stiffer side wall that radial tires so I would doubt there is a white wall that could be exposed after grinding. HRP
  10. Squablow
    Squablow
    Paint them on. I've used the white elastic trailer roof coating so many times (Seal-Best white elastomeric roof coating is the brand I got, there's apparently another brand called Snow-Seal) and I've had tires go flat that it never chipped or cracked.
    Best way is to sand the sidewalls smooth with an 80 grit on a DA to get all the modern lettering off, super clean the sidewalls multiple times with lacquer thinner (if your rag is getting brown, they're not clean enough) then brush the white on, preferably in the sun on a hot day (taking them off and putting them on a table works best). You'll need 4 coats, and after the first two it'll look like absolute **** but keep the faith. Best if your tires have a nice line in them to brush up to, if you go over the line you can sand the edge back a little bit once they're dry but it's tougher. Make sure it's dry to the touch between coats.
    Portawalls are dog****. I've done a lot of tires with the snow seal for budget purposes and I'm sure on a camper it'll turn out nice too.
    ladyhrp, 3W JOHN, 51 BIRD and 4 others like this.
  11. upspirate
    upspirate
  12. Schwanke Engines
    Schwanke Engines
  13. 3banjos
    3banjos
    from NZ
    I'd mask them out, rim and all, and when you see the road marker lads up the road, ask if you can throw them down under his jets. That paint is the ****.
  14. willys36
    willys36
    I had no choice on my Mysterion clone. Got some great new/old Inglewood Pos-A-Traction 10" x 15" slicks on Ebay which are a perfect match to what Big Dally Roth used on the original car except mine had different narrow whitewalls on each tire. No modern 'reproduction' slick looks correct Remember, back in the day racing slicks were recapped Cadillac tires. Port-A-Walls were the perfect fix for this mostly static show car.
  15. G V Gordon
    G V Gordon
    from Enid OK
    If you go port o walls, don't drive in deep snow. I speak from experience.
    Sent from my SM-G920T using The H.A.M.B. mobile app
  16. HOTRODPRIMER
    HOTRODPRIMER
    I appreciate everyone's reply,be it pro or con.
    Hopefully the quality of rubber used in manufacturing the ports-walls in this day & time has improve. HRP
    The ST tires have a much stiffer sidewall than the tires we use today. HRP
    Phil,have you ever heard the term?,"If mommy ain't happy- no one is".
    The boss lady want's something that is not readable available,I realize they are not the most ideal way to go but it's not like the camper will see daily use. HRP
    ladyhrp, 3W JOHN and 55hdyman like this.
  17. HOTRODPRIMER
    HOTRODPRIMER
    BTW,that Mysterion clone is beautiful! HRP
  18. willys36
    willys36
    Thanx. BIG bucket list check-off!!
  19. All the way to Los Angeles and back (4,000 + miles) with them on F70/15s & H50/15s back in the 70s and the only issue was them "sticking out" a bit at highway speeds. They always came back to the sidewall after slowing. Of course I never tried gluing them down, they were just pinched in the rim.. Should work on the trailer until a better option comes along!?
    Dave
  20. Mr48chev
    Ran them on my 55 Nash Metropolitan and never had a problem. Not with the fake white walls anyhow.
    I remember my dad painting white walls on his tires back in the late 40's or early 50's probably on the 41 Buick or the 51 Ford that replaced it. Even then if there was car stuff going on I was right there.
    With the stiffer side walls and no faster than you tow the trailer you might get away with the porta-walls without many problems or at worse case give your buds a good laugh.
    ladyhrp, 3W JOHN, hipster and 2 others like this.
  21. bondolero
    bondolero
    I used to have a great set I got from Western Auto growing up and had the same problem. My 6 cylinder chevy wouldn't run fast enough to make them flare out much. Maybe a dab or two of RIGHT STUFF but that will stick them down permanently.
  22. skipstitch
    skipstitch
    Purchased the portawalls in '87. Drove, abused and put away wet often. Parked for many years and driven periodically with no issues. Never glued 'em down, but found you had to use Wesley's Bleach White OFTEN to keep 'em bright...
  23. HOTRODPRIMER
    HOTRODPRIMER
    Using a cleaner like Wesley's Bleach White is a normal practice with whitewalls & I am well versed at that,I am happy to here you had good results,thank you. HRP
  24. upspirate
    upspirate
    I remember back around 1960 my did put a set on one of his cars.
    Ripped them off after a day or two....can't remember why.
    Were there problems getting them mounted concentric or balancing maybe?
  25. waldo53
    waldo53
    from ID
    Here's a pic of my truck, proudly wearing 2" port-a-walls. I ran these for 5 years over radial tires, many miles at 70mph on the freeway. No problems whatsoever. No one who looked at my truck at shows or cruise nights ever knew they were "flappers" unless I told them - and then most of them thought that was pretty cool and remembered they used them back in the day.
    The key is to get them on right. Find yourself a gray-beard tire guy that has mounted them before (I called around until I found one). Make sure when they get mounted that the bead on the port-a-wall sits right down on the rim, and is even all the way around. You might have to break it down and do it over a time or 2. You should have good results with those tires - the less sidewall flex the better. I read somewhere in my research that they should not be glued to the sidewall - so I didn't.
    I wouldn't think twice about running them on your trailer. Whadya got to lose? Give it a try. Even if they fail (and I don't think they will) momma will be happy you tried!! Edit: the narrower you can use - the better the results
    v8flat44, AHotRod, ladyhrp and 6 others like this.
  26. HOTRODPRIMER
    HOTRODPRIMER
    Thank you for positive reply. HRP
    ladyhrp, 3W JOHN and waldo53 like this.
  27. ratrod0
    ratrod0
    Danny you will be fine just don't get 3". I have 2" on the scotty 20161008_155636.jpg
    AHotRod, ladyhrp, 3W JOHN and 5 others like this.
  28. HOTRODPRIMER
    HOTRODPRIMER
    Thanks for the advice Barry. HRP
  29. hotroddon
    hotroddon
    I've had two sets of New Porta Walls blow off on the freeway, resulting in immediate flat tire. NEVER again.
  30. HOTRODPRIMER
    HOTRODPRIMER
    Two sets? eight tires? HRP
    Atwater Mike, ladyhrp and 3W JOHN like this.
