How many hemi owners on the board
Discussion in 'The Hokey Ass Message Board' started by axeman39, Jul 3, 2006.
  1. gimpyshotrods
    gimpyshotrods
    I know the feeling.
    I may have accidentally purchased a 6-71 for one of my 354's this week.
    Ain't no Hemi like a blown Hemi.
    Deuces and SEAAIRE354 like this.
  2. oj
    oj
    'Accidentally?' I like that, ok if I borrow the term from time to time?
    Just Gary and gimpyshotrods like this.
  3. gimpyshotrods
    gimpyshotrods
    You go right ahead.[emoji106]
    Deuces likes this.
  4. SEAAIRE354
    SEAAIRE354
    I've accidentally bought a lot of stuff by drinking a little to much and going on eBay.
    Deuces, INVISIBLEKID and oj like this.
  5. kmrumedy
    kmrumedy
    I have a nicely rebuilt 1958 392 Hemi. Just not sure what to do with it...
    mgtstumpy, 30dodgeboy and Just Gary like this.
  6. George
    George
    Buy a car & pull the S.B. Chevy out of it.......
  7. gimpyshotrods
    gimpyshotrods
    Today I accidentally milled out a boost referencing 6-71 to Edelbrock carburetor (design thanks to @ago ), at work.
    Don't worry, it will be deburred, dressed with a file, and all non sealing surface sandblasted, so it looks cast.
    I still need to counterbore the case bolt holes, if I can find my damn counterbores.
    USA sourced aluminum, too!
    Deuces likes this.
  8. brigrat
    brigrat
    from Wa.St.
    I accidently need a 392.................................................................
    Deuces likes this.
  9. gimpyshotrods
    gimpyshotrods
    I will accidentally keep my eyes out for you.
  10. ago
    ago
    from pgh. pa.
    Gimpy, You probably know this already. Make sure you epoxy the secondary vacuum notch of the carb. It lets the vacuum source the power valve metering ports of the carb. You want to isolate the metering port from the intake manifold. The end result is have the power valves of the carb get its signal from below the blower. I used a 4 hole carb gasket and punched two small holes under the metering port.
  11. ago
    ago
    from pgh. pa.
    My intake manifold had 8 holes, I cross drilled the two metering holes, and connected a 1/8" pipe fitting and ran tubing down to the blower manifold.
  12. VonWegener
    VonWegener
    I have a running 354 with rebuilt carb and distributor. Has the buick oil filter manifold conversion.
    I have a Quality Engineered components adapter for a Torqflite and no car to put it in.
  13. gimpyshotrods
    gimpyshotrods
    Yup, I learned it from you!
    I made mine open center, in case I want to up the carburetor size. I looked up the biggest Edelbrock, and sized it for that.
    I will cut a stack of custom gaskets on the laser cutter at work.
  14. gimpyshotrods
    gimpyshotrods
    You should fix that.
  15. SEAAIRE354
    SEAAIRE354
    gimpyshotrods likes this.
  16. gimpyshotrods
    gimpyshotrods
    A truck Hemi, out on Lawn Guy Land?
  17. SEAAIRE354
    SEAAIRE354
    Ok I'm at a loss with that one. What is "lawn guy land". This was once all farm land and occasionally there's a surviver. But now it's all vineyards and tourism if that's what you mean LOL.
  18. gatz
    gatz
    Got this 331 (bored .030 over) as a short-block and heads ***embled but not together.
    Supposedly it was built by a gentleman that was going to put it in a Model T.
    Did the 340SB oil pump & distributor conversions. Hooked it up to a rebuilt 727 using HotHeads adapter.
    Built a test stand and got it running. Sounds great, but might consider a different carb than the Edelbrock I got off eFlay
    Got it sitting in the engine bay of the '40 Chrysler Royal (car in the avatar); just need to nail it down.
    Love some of the other HEMIs on here. They're a great engine. I don't think the engineers at Chrysler knew quite what they had engendered at the time.
    Got a video of it running,...how can I post it?
    Deuces, mgtstumpy and gimpyshotrods like this.
  19. gatz
    gatz
    dang...
    just realized that the safety wire isn't quite right.
    another view....maybe it'll be OK.
    Deuces and gimpyshotrods like this.
  20. SEAAIRE354
    SEAAIRE354
    Ok it's been a long day. I get it my wife explained it. I'm going to bed. Really want to se the 331 running
  21. gatz
    gatz
    SEAAIRE354 likes this.
  22. SEAAIRE354
    SEAAIRE354
    Like the industrial valve covers.
  23. gimpyshotrods
    gimpyshotrods
    Long Island, for those playing at home.
  24. Otto
    Otto
    I have one of the last (maybe THE last Hemi) built by G***er Legend Jr. Thompson. 58-392. Its in my 39 ford and will finally be on the road by the holidays.
    Deuces likes this.
  25. gimpyshotrods
    gimpyshotrods
    I gave up looking for my counterbores and dropped it off at my machinist, after work. He's going to finish it off tomorrow.
  26. gimpyshotrods
    gimpyshotrods
    There is a guy out my way, selling a pair of bare Chrysler Hemi truck heads, for $150.
    Does anyone need them?
    Cleveland Coupe likes this.
  27. manyolcars
    manyolcars
    My 392 is in the1947 Mercury I bought in 1967
  28. Gotgas
    Gotgas
    from DFW USA
  29. desoto
    desoto
    from Ayer, MA
    Hot heads oil pump with 37,000 miles on it. Note the wear on the non-hardened shaft. Nothing to do w/ alignment, it simply isn't hardened like the original shaft that used to be in the 340 pump before HH removed it and subs***uted a chrome-moly shaft, instead. Mellings stresses the fact the oil pump drive be hardened when using a high volume pump. Now you can see why.
    This pump failed at 1,800 miles because the bolts weren't all tightened down correctly when HH put the pump back together after replacing the shaft.
    2 were loose, one fell out.
    BTW, 5 people were standing around watching as the oil pan came off and the missing bolt was found in the bottom, thus, prompting a search for it's origin. (see previous photo)
  30. Nice water crossover. Aluminum or iron?
