Projects 1955 Pontiac gasser build
Discussion in 'The Hokey Ass Message Board' started by 55chieftain, Aug 10, 2010.
  1. Snowman454007
    Snowman454007
    from Austin, TX
    I got a question. So I'm at the stage of my build where I'm trying to put my engine and transmission in the car and build mount and I'm following your advice and building front engine mounts out of square tubing and I was wondering what are you using for a rear transmission mount I saw on your post that you used some side-by-side mounts for the transmission but since we're running aluminum turbo 350 and 400 I didn't think that we could do that. I ordered a Chevy convertible rear transmission mount for a turbo 350 conversion because the Chevy convertible has an X frame similar to our Pontiacs so I figured that would be a good place to start. Would like your thoughts
    Sent from my SAMSUNG-SM-N910A using The H.A.M.B. mobile app
  2. Chuck Craig
    Chuck Craig
    from Ocala FL
    Pontiac in a Pontiac, like it!!!!!!!!!!!!!!!!!!!! If you happen to see an extra pair of front seat skirts, let me know, a buddy needs a pair for a 56 Safari that he is working on.
  3. wvenfield
    wvenfield
    This is a week old but since no one addressed it...........I'm using a Muncie 4 speed but we simply built a simple mount.
    saltflats and Snowman454007 like this.
  4. Snowman454007
    Snowman454007
    from Austin, TX
    55chieftain likes this.
  5. Snowman454007
    Snowman454007
    from Austin, TX
    Cool so that's essentially what I got. Thank you sir!
  6. 55chieftain
    55chieftain
    I do but don't know if I want to separate them from the seat. I have my 2dr seat still with skirts
  7. 55chieftain
    55chieftain
    done racing for the year went 10.56 as my best. I plan on filling some more holes over the winter in the body. may put in a bigger stall and see what happens
  8. loudbang
    Ya done Good. I been following from the start and 10.56 is nothing to sneeze at.
    55chieftain and Snowman454007 like this.
  9. wvenfield
    wvenfield
    Yeah, that should work. Or easily be made to work.
  10. 55chieftain
    55chieftain
    Making a few small changes, i picked up an old set of skinny slots so I can have some proper tires for racing at 125 mph+. Also got ahold of a nice insert for the hood ornament that will be lit 20161216_122642.jpg 20161220_132246.jpg 20161220_132233-1.jpg
  11. OahuEli
    OahuEli
    from Hawaii
    Thats a cool looking hood ornament!
  12. 55chieftain
    55chieftain
    The ornament is for a higher level Starchief, the Chieftain sedan would have got the plain airplane looking piece without an insert . So it doesn't really belong on a a sedan or don't know about a g***er either, but I sure like the way it looks. Can't wait to get it mounted and lit up in the dark. My tach backlight is wired so anytime the car is running is on so I don't have to mess with lighting switch, will wire up the hood ornament the same way.
  13. loudbang
    Screw it it will look good.
  14. OahuEli
    OahuEli
    from Hawaii
    Yup, I agree. If you ever run night drags it'll be cool as hell shining up there in the front.
    Snowman454007 and loudbang like this.
  15. Snowman454007
    Snowman454007
    from Austin, TX
    Speaking of tachs I have been tossing the idea of getting a gto hood tach and putting it on my 56 Pontiac. Any thoughts?
    SS327 likes this.
  16. 55chieftain
    55chieftain
    20170508_195920.jpg Lighted good ornament finally. Got ladder bars done, housing floaters next FB_IMG_1494290873290.jpg
  17. 55chieftain
    55chieftain
    Lost 3rd in the trans and ended up with one with a transbrake. Got a nice pic from the Meltdown Drags , been waiting to get the wheels off the ground nice. I'm told it went up higher than the pic. Best p*** was a 10.56. 20170716_125514.jpg
  18. Dog_Patch
    Dog_Patch
    Wow that's moving for a big car!
    55chieftain, loudbang and mad mikey like this.
  19. mad mikey
    mad mikey
    Very well done! :)
    55chieftain and loudbang like this.
  20. loudbang
    Did the "Lighted Indian" lead the way. :)
  21. Gas_Tires_Oil
    Gas_Tires_Oil
    Very cool, great pic of the wheels up.
  22. 55chieftain
    55chieftain
    Yes it did, should have a good pic from someone from the night racing that will show up good. The p*** also had my best 60 ft with a 1.40
    Tickety Boo, loudbang and bobwop like this.
  23. bobwop
    bobwop
    from Arley, AL
    good job Bill
    loudbang and 55chieftain like this.
  24. lippy
    lippy
    from Ks
    Congrats, that lit up ornament should be good for a tenth! Looks cool as hell. Nice to see a Pontiac out there! Lippy:cool:
  25. 55chieftain
    55chieftain
    Hey guys been a long time. Upgraded to a bigger aftermarket Pontiac block. Cars been 9.96 @131. Car pretty much looks the same. FB_IMG_1716762978255.jpg
    slayer, Chucky, wvenfield and 11 others like this.
  26. 55chieftain
    55chieftain
  27. swade41
    swade41
    from Buffalo,NY
    Any winter upgrades ?
    mad mikey likes this.
  28. 55chieftain
    55chieftain
  29. 55chieftain
    55chieftain
    my 3 piece fibergl*** front end that I had built is now a 1 piece. still to build a frame to have it slide forward and tilt.
  30. 55chieftain
    55chieftain
