Hot Rods Cool dual quad air cleaner
Discussion in 'The Hokey Ass Message Board' started by hotrodyankee, Jul 17, 2017.
  1. hotrodyankee
    hotrodyankee
    Had a stock 283 air cleaner, and wanted to utilize it on my dual quad set-up. It was fairly easy, so I thought I would p*** it along. Just tig welded a 18ga plate in for the air filters to seal on and added another snorkel to the lid. Hope ya like it! P1010009 (1).JPG P1010002 (1).JPG P1010003 (1).JPG P1010008 (1).JPG P1010010.JPG
  2. 1934coupe
    1934coupe
    Great job! Much better than some chrome pos made in china. I made a similar one for my 57 Chevy only used 4" round tube I rolled and welded and a 5"rolled circle that the filter goes in with the base and top aftermarket. Then use hoses to connect to the fresh air inlets above headlights on a 57.
    Pat
  3. flatheadpete
    flatheadpete
    from Burton, MI
    Quick, dirty n simple all while being effective! I like it.
    hotrodyankee and dana barlow like this.
  4. tb33anda3rd
    tb33anda3rd
    good job making the air filter adapt to the duals, and a great way to hide them.
    for me, the look of the duals is the cool factor tho.......
  5. i.rant
    i.rant
    Great idea, nice work.
    loudbang and hotrodyankee like this.
  6. Paint_Rep
    Paint_Rep
    Well done! The top looks like a 65 L-79 Malibu lid, which were chrome.
  7. 56sedandelivery
    56sedandelivery
    Very nice job hotrodyankee! You could take it another step forward, and make up some cold air/ram air hoses. The first pic; imagine it with some raised, white letters and tire size numbers to make it look like a tire, and make the center look like a mag wheel. Just a thought, due to the tread-like appearance (like pie crust slicks). It's a bit hokey I know, but I'm surprised no one has done it. A friend of mines son, takes old style valve covers, and modifies them for the LS engines (they're just "covers" on top of the LS covers to hide the coil packs). I am Butch/56sedandelivery.
    hotrodyankee and loudbang like this.
  8. Ebbsspeed
    Ebbsspeed
    Nice idea, but are you sure it's sealing? This picture would indicate that it is not.
  9. lippy
    lippy
    from Ks
    That's some cool **** right there! Lippy
  10. lippy
    lippy
    from Ks
    Give the nuts another turn LOL. Lippy
  11. Bugguts
    Bugguts
    I like it. Recycling at its best.
  12. hotrodyankee
    hotrodyankee
    Thanks. the carbs seal all the way around. I painted the air cleaner, let it sit for about half hour, felt the paint on the bottom side and felt dry to the touch, set it on the air cleaners to see how it looked. let it sit over night, and I guess the paint was not dry enough. Didn't have it tightened down at the time.
  13. oldsjoe
    oldsjoe
    Cool stuff right there. I went through hell trying to adapt an air cleaner for my 455 Olds ended up using a billet piece that I wasn't found of. After twenty five years I'll be removing the billet piece and removing the two fours. Going back to a single four set up for a change! Joe
    hotrodyankee likes this.
