Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. leadfootloon
    leadfootloon
    It was posted and the class is full in hours.
  2. UNSHINED 2
    UNSHINED 2
    Good for you for being able to attend, I bet it was the coolest!!!
  3. gimpyshotrods
    gimpyshotrods
    I cut and fit the last piece of tunnel for my Falcon. Tomorrow I will weld it in, and if there is time, make the shifter access plate.
  4. donno
    donno
    Dusted off the Merc @ 6 this morning and went to a parking lot gathering. Met some new folks and saw some new cars. Probably 60- 80 cars. Had coffee, came home and took my DP to late breakfast at a new Cracker Barrell. Good Day
  5. HarryT
    HarryT
    Replaced the failed fuel pressure regulator on my avatar. The one that failed was one of the chrome plated round type. The replacement is a Holley type.
  6. Pulled the electric wipers from a 53 ford truck. replaced the O rings in the wand of my pressure washer. and went to my other place and chain sawed some firewood and worked on the fence.
  7. RICH B
    RICH B
    The E-brake lever for my '35 came back from the plater, so I got it installed and hooked up. Got a new cowl handle from Drake, seems to have a stock looking satin finish; supposed to be stainless; but doesn't want to buff out, have to try more aggressive compound first, maybe. Welded up some cracks for now on my ratty front fenders. The '59came back from getting the bottom blasted and painted; hassled thru getting it off the rotisserie with a couple cherry pickers and the 4 post.
  8. jeffd1988
    jeffd1988
    [​IMG]. We're starting body work
    clem likes this.
  9. tfeverfred
    tfeverfred
    Just got done bleeding the brakes on my T. Ready for some sleep.
  10. DesmoDog
    DesmoDog
    I made this: IMG_1147.JPG
    Fit into this:
    Which would be cool if the whole thing now fit the car. Which it doesn't. I kinda thought that might happen, there is a plan B...
    jeffd1988 likes this.
  11. RDE
    RDE
    Spent too much time on the phone with Jegs trying to substitute backordered stuff for stuff I need now. Ebay was my friend in the end.
  12. LowKat
    LowKat
    Not today but yesterday, got the factory style fuel lines installed on the '61 then went out and burned some fossil fuel.
  13. jeffd1988
    jeffd1988
    [​IMG]. Strippen. Couple hours a day after work.
  14. chop job
    chop job
    from Wisconsin
    Put together my control pannels for the final time and cleaned up my dash. 20170718_140505.jpg 20170718_140515.jpg 20170718_112616.jpg
    JOYFLEA likes this.
  15. junkyardjeff
    junkyardjeff
    Sat in traffic in my F100 for about 45 minutes and the 460 did not get hot so my cooling system must be working good,thought I was going to run out of gas since I only had around a 1/8 of a tank when i left work and the station at the nearest off ramp was closed for remodeling.
  16. gimpyshotrods
    gimpyshotrods
    I rendered in CAD dual carb to 6-71 adapter plate, that allows two Edelbrock carburetors to be boost referenced, and then set all of the tools, tool paths, speeds, and feeds in the CAM program.
    Don't worry, I will file the edges round and sandblast the non-sealing surfaces when I am done.
    If I can get to my supplier tomorrow, I will grab a chunk of 6061.
  17. Blue One
    Blue One
    from Alberta
    Sanded some more on the body and bed of my RPU.
    The never ending paint prep project :D
  18. choptop40
    choptop40
    Picked up this solid 55 Dodge pickem up.....with clear****le......yowza IMG_0338.JPG
    mkebaird likes this.
  19. HarryT
    HarryT
    Worked on fitting a panhard bar to the frontend of my roadster project.
    Jim
  20. 270ci
    270ci
    Yanked my crank a coupla times! Seriously....I started an A manually, with the crank!
  21. ceege
    ceege
    from NW MT
    I spent the morning with my wife. Her first day off in 10 days.
    Spent the afternoon making Taiwan made grill and fenders fit original hood on a 53 Chevy truck.
    My hole sander got one hell of a workout.
  22. MO_JUNK
    MO_JUNK
    from Rolla, Mo.
    After work, it was another evening working on the Cadillac swap into my 57' Chev. pickup. Last night was installation of the trans. cooler. Tonight I'll start fabricating and moving the fuel line to the driver's side. IMG_2292.jpg
    Racer29 and JOYFLEA like this.
  23. raymay
    raymay
    Did a little haulin with my 56 ElCamino to pick up a set of wheels and tires I bought for a late model custom "one of a kind" I am currently building.
  24. choptop40
    choptop40
    That's a cool OT conversion....I cleaned up the shop tonight....
    raymay likes this.
  25. jailbar joe
    jailbar joe
    well 9 years ago i started on this 42/47 ford pickup
    and yesterday it was officially finished having achieved registration
    pretty pleased as it drives well and covered nearly 600 k's already....now to start something else
    tfeverfred, Early Ironman and JOYFLEA like this.
  26. The37Kid
    The37Kid
    Picked up a piece of non automotive artwork drawn by Irma Peixotto. She designed the bronze plaque on the Lt. Thomas Selfridge memorial in Arlington, the first aviation fatality in 1908, when a gear broke on Orville Wrights plane. It will turn into car project money, just a neat find if you like history. Bob
  27. gimpyshotrods
    gimpyshotrods
    I cleaned the garage.
  28. Early Ironman
    Early Ironman
    I just got back from working offshore. Returned to a shop full of boxes I ordered while at work. Now the fun begins to finish the 47 pickup so I can sell it and get back to work on the 54.
  29. junkyardjeff
    junkyardjeff
    Just got back from taking my 37 Chevy p/u to a all truck show.
    Early Ironman likes this.
  30. HOTRODPRIMER
    HOTRODPRIMER
    Me too and cleaning up a mildew problem in the old deuce beater,hood is up and drying out in the sunshine. HRP
