Where are you guys buying your seat belts? I'm not looking for originals just a quality set with chrome buckles.
Have you seen the price for OEM belts? eBay has a used set for $450. That's about as cheap as I've seen them. I'm thinking about removing mine and making a little money.
I need a set for the front also. I looked at them in the past but didnt pull the trigger. One of the things holding me was that I couldnt get to a conclusion on the SIZE of the belts I'd buy. So what size are you guys using? I'm talking 2 point non retractible.
Rui if you are asking length when you say size.I would suggest 72 inch as they will adjust to fit a more robust person then yourself.seriously if you order the size for a person of your size then you will have a problem.look at a site like julianos for an idea for total length and mounting.
Thats it Barry, sometimes I dont use the proper words. I was looking at these proposed by Brodie: https://www.seatbeltplanet.com/seat...n-retractable-lap-belts/m.products/123/view/4 They've got a 74 inch option. Thanks.
Take a look at wescoperformance.com lots of good info and good prices on belts. I bought my most recent ones from them.
I put the front and rear seats from a 83 Olds 88 in my 53 Ford and used the seat belts at the same time. They seem to work just fine and they do retract.
I got mine from Wesco, totally happy with them too. There is one maker of most of the belts you see, shop with price in mind.
I just ordered belts from Julianos. I looked at Wesco but they would not put the correct ends on the belts for me. Thanks everyone for your input.
