Projects Bad Banana Resurrection - 55 Chevy Gasser
Discussion in 'The Hokey Ass Message Board' started by Bad Banana, Aug 10, 2010.
  1. Bad Banana
    Bad Banana
    I'm on Hot Rod Power Tour right now. Not able to watch the video. If it was coming out of the flywheel area I know what it was.
    Sent from my SM-G900V using The H.A.M.B. mobile app
    loudbang and Fiddle Picker like this.
  2. Bad Banana
    Bad Banana
    I was just able to look at it. The snap ring on the starter drive came off and it let the bendix touch the flywheel. Didn't hurt much. I'll have that fixed for the next race. As much as I would love to blame that for that loss.. it just isn't so. I got treed and he beat me fair and square. I'll be looking for a rematch soon.. ;)
  3. Bad Banana
    Bad Banana
    Latest edition of the official video. You can see the sparks fly in the final.
  4. mopacltd
    mopacltd
  5. Bad Banana
    Bad Banana
    Got beat first round for the very first time since I started running with the Southeast G***ers. Both drivers who were in the finals in C/Gas at the last event were out first round of this one. Goes to show you how tough this deal is getting. I really didn't do much wrong. It was actually the quickest run of the day for me. Just flat got beat. I started plans to improve the car on the return road coming back from my first round loss. I have been working on the car since we got home Sunday afternoon. Here is the video from Lyons last week.
  6. Higgy's Henry
    Higgy's Henry
    Your still a fan favorite!!!
  7. Dog_Patch
    Dog_Patch
    That track didn't hook for me AT ALL.
  8. Hang'emHigh
    Hang'emHigh
    Been a fan of the Banana since seeing you and your Dad at The Beaver many moons ago. A great racing family! My boys, 3 and 5, love the car too! You should hear them when they watch the recap videos. "Dadda Bad Banana!"
  9. loudbang
    Grabbing photos last night and found this one on the track site.
  10. Fiddle Picker
    Fiddle Picker
    Great shot !! Is that a recent photo or back in the day ? Wheel combo throws me off a little.
  11. Bad Banana
    Bad Banana
    That was a couple years ago. I put those wheel covers on the rear to hide the Super Tricks to run at the Meltdown.
    Sent from my SM-G950U using The H.A.M.B. mobile app
  12. Bad Banana
    Bad Banana
    I haven't updated this thread in a while. Caught up a bit so I thought I would add some pics tonight. I've pretty much been forced to change the wheelie bars if I want to stay compe***ive in the SEG. I tried very hard to use the car balance to just stay off the solid frame mounted bars that have been part of this car for many decades. While I was able to get the car pretty close to where I wanted it, I have come to realize that I am not a good enough driver to leave the same every run. That is what it takes is hitting the throttle and clutch release exactly the same and at the right RPM and it works fine. However, with no starting line aids (i.e. 2-step), different length of time between staged and tree activation, adrenaline volume depending on who is in the other lane, etc.. I just can't seem to do it consistently enough and it has cost me several races.
    I decided to stop beating my head against the wall and caved in and spent some time since Lyons making "updates" to the car. Some you can't see and those are gonna stay in my pocket for now, but others you can. One obvious change is I removed the manly castors and built a set of the girly sissy sticks that are fully adjustable and hooked to the rear axle housing like most everyone else is running (yes... they are Quain Stott approved). I re-used the big 6" wheels from the old castors but every thing else is different. I kept the old bars in tact so maybe someday they will go back on the car. Who knows. :rolleyes: As always, every portion of this change was done by hand, by me, in my modest shop with very little modern equipment. The drill press is my dad's he used for many years. It's an antique ..lol.
    20170716_173629.jpg 20170716_173648.jpg 20170719_185551.jpg 20170719_200418.jpg
    Also, Jerry Birch of Freebird C/Gas Chevy II fame kindly donated the front wheels and tires as they won't fit his car. I had to make some lug nuts but they fit my old axle just fine. They are a bit lighter than the steel wheels so we are gonna run them for now.
  13. Bad Banana
    Bad Banana
  14. cowboyinachair
    cowboyinachair
    from colorado
    this car is the best your dad looks down and says change is needed to keep winning so make it win rusty
  15. pigfluxer
    pigfluxer
    Looking good Rusty....
    Fiddle Picker, Dog_Patch and loudbang like this.
  16. Jimbo17
    Jimbo17
    The Bad Banana looks right out of the 60's and very cool.
    Great Job!
    Jimbo
  17. Higgy's Henry
    Higgy's Henry
    The Bad Banana IS right out of the sixties!!!:D
  18. Bad Banana
    Bad Banana
    This quote above is exactly what happened. That was put on this thread in the days after I lost my dad.
    So.. What happened at Clay City? Second qualifying run I stopped at the scales and the scale man says I'm leaking water. I get back to the pit and water is running out of the front of the engine. Behind the water pump. Not leaking out the weep hole but streaking down the center of the timing cover behind the pump, around the crank and onto the ground.
    Pulling the water pump is not an option since the engine is mounted using the water pump bolts and 4 gaskets, etc. I only have a few minutes because they are calling first round to the lanes. I tried to jam a rag in there to diaper it but it was leaking so bad the rag was wet before I could get it wedged in. Besides, it is right above the balancer and if the rag gets caught in the crank it could be ugly.
    I was not going to risk leaking on the track and be shut off or cause me or someone else danger if it wasn't seen. I was ready to go forfeit the race when a voice inside my head said "drain the water and it won't leak". I swear it was my dad's voice. I remembered a clause in the rules that said you could be towed if it was a hardship case. I checked with officials and they said I could tow it to staging and back after the run.
    That's what we did. I would drain it down enough to stop leaking and tow it to the front of staging and fire it up, make the run and the golf cart would be waiting at the time slip booth to tow me back. Fill it with water, cool it down then drain again. Worked like a charm and went 4 rounds that way. Lost at 3 cars.
    Got home and pulled the water pump. Pin hole in the back cover.
    The above picture was just like something my dad had in the garage for many years. If I had given up, I would have lost any chance to possibly do well in the series points with SEGA. As it turned out, I gained ground on the two guys ahead of me. Looks like there is only one round between each of the top 3 in C/G right now with 4 races remaining. It's gonna be good from here on out.
  19. catdad49
    catdad49
    Hey Rusty, you weren't running some of Josh's "antifreeze" in there were ya?! Still trying to get used to those new fangled "mag" wheels on the front, does it feel different? Good Luck in points race, Carp
  20. Bad Banana
    Bad Banana
    No.. nothing but water. Can't tell the wheels are different from the driver's seat.
  21. Trukcrazy
    Trukcrazy
  22. 55Belairman
    55Belairman
    mad mikey, loudbang and Hang'emHigh like this.
  23. Bad Banana
    Bad Banana
    Here is the official Clay City video.
  24. Trukcrazy
    Trukcrazy
    Great video!
  25. enloe
    enloe
    from east , tn.
    Heading to Ringgold Georgia to the Southeast G***ers race. I will have a booth set up selling old magazines today. Stop by and see Ethan and I.
    Bad Banana likes this.
  26. Fiddle Picker
    Fiddle Picker
    Way to go Rusty ! Congrats !!! Stopped by to see you, wife said you'd be back. I know you had your hands full. Had a blast !
    loudbang, enloe and Hang'emHigh like this.
  27. enloe
    enloe
    from east , tn.
    Rusty I posted a bunch of pics from yesterday's event on the thread that's linked in my signature. image.jpg image.jpg image.jpg
  28. southcross2631
    southcross2631
    Good job Saturday night. Watching your lady standing behind your car when got staged up for the finals was priceless. You could not have had a bigger fan than her.
  29. Bad Banana
    Bad Banana
    Wow.. what a week. Started off at Indy first part of the week then drove down to the Southeast G***er race in Ringgold, GA on Thursday. Was able to do a bit of testing on Friday night. Track was good, air was good, car was good and all that equals to a giant wheelstand that broke the wheelie bar brackets off! I was able to find a guy who could weld them back up Friday night and we figured we were ready for Saturday.
    First qualifying run Saturday was against Robert Frazier and he broke in the burnout and put some liquid on the track so they shut me off. While sitting there waiting for the clean up, someone noticed I was leaking oil. I looked at it and they were right, we towed it back to my trailer and found the O-ring for my oil filter adapter had blown out. Took it apart and went thru everything I had and nothing to fix it with. Went thru the pits and no one had anything close. Someone suggested to eliminate it and just use a stock Chevy oil filter. Quain Stott had one and we spun it on quick with just minutes to spare to make the second qualifying run. Leak fixed!
    With a 16 car field, there was not going to be any by-runs for anyone. From there on out, we waded thru 4 rounds of Chevy 2s to be standing at the top of C/Gas for the first time in over a year. In the semi-finals it was 3 carbureted Chevy 2s with and one old beat up fuel injected 55 Chevy. Somehow, with divine intervention, we were abe to get to the finish line first on every run. I was screaming so loud in the shut down area I figure the spectators could hear me over the race cars. My voice is paying the price still...lol.
    I want to say a special thank you to "Sam" who I never got his last name who welded up my wheelie bars Friday night and also Garitt Pugh who jumped in to help me when I was in midst of the oil leak saga. He ran everywhere to grab wrenches and everything else and was also laying on the ground with me fixing the leak. Without his help we would not have made that second qualifier.
    Dennis Ashcraft Speed and Marine have built me an engine that is the best engine I have ever had!
    Mike Chilando from Alkydigger has been a huge help to get this car running like a swiss watch. In my opinion, it is the best running stack injected car in SEGA right now!
    Mike Norcia and Ram Clutches have provided me with the best clutch package in the business!
    Also a shout out to Jerico Transmissions for their help this year as well!
    And of course Sharon my wife, partner, back-up girl and best friend. Without her I wouldn't even have been there at all. I love you sweetheart!!
    It was a big points day for us. Not sure exactly where it all ended up but we are definitely in the hunt with only 3 races remaining. Say tuned. It's gonna be epic no matter what happens.
  30. Hang'emHigh
    Hang'emHigh
    Way to go Rusty!!!
    Bad Banana and loudbang like this.
