which gm wheel studs?
Discussion in 'The Hokey Ass Message Board' started by mink, May 1, 2010.
  1. mink
    mink
    from CT
    Hey guys want to run centerlines on my 32 chevy which has a disc brake from end that uses 70-77 Camaro/Firebird 73-76 Chevelle/Monte Carlo rotor and caliper (or GM equivalents).
    Any one know what studs are run on these or where i can find that out?
    The special lug nuts dont thread on enough of the stud thats on the rotor. I need longer studs.
    any advice as to removing the studs and intalling longer one?
    Thanks
  2. mink
    mink
    from CT
    anyone know where i can figure this out the stud size
  3. Thommyknocker
    Thommyknocker
    from Colorado
  4. ECIGUY
    ECIGUY
    If your centerlines use a conical seat style lug nut you need the ET style lug nuts which project down into the hole in the wheel.
  5. mink
    mink
    from CT
    Ralph I've got the correct lug nuts but they only thread a half inch on the stud. I need longer wheel studs. What I was looking for was the size of the studs on that are on the 1970-1977 camaro firebird disc rotor. I want to make sure i can get a longer stud before i damage/ remove the original studs
  6. enjenjo
    enjenjo
    from swanton oh
  7. sheddynz
    sheddynz
    Hey guys.
    I have got my bop 28 spline axles but the wheel studs I bought are a fraction over 1/2 " knurl. The studs are 7/16 20 but my axles have smaller holes around 0.44" do you know what size knurl I need for the press fit. Thanks
  8. sheddynz
    sheddynz
    All good I worked it out I needed the Dorman 610 186 wheel studs [not 610-025 .564 knurl] they are .472" od knurl with 7/16 20 threads. So if anyone buys standard gear 28 spline replacement axles for BOP 8.2 rear end they are the ones to get. Im 99% sure this is correct but will report back when I have them installed. I wont know if I have to ease the axle stud holes yet. Cheers
