Period correct 1926 Model T Speedster for sale. It has the following features/modifications: Fresh rebuilt Ford 4 cylinder motor manufactured in May 1926 Twin-High auxiliary transmission High compression Z head Zenith 2 carburetor with modified Model A intake Straight exhaust Rebuilt radiator 3 1/2" drop front axle Dual 6-volt Optima gel battery used for the electric starter Period correct horn This Speedster was built to follow all rules for TROG, Hot Rod Dirt Drags and Hot Rod Hill Climb. It was taken apart down to the frame, the plywood was replaced and the body was widened to hold two people comfortably. It was rebuilt using all period correct hardware and wiring. The seat was reupholstered with durable all weather leather-like vinyl. Extra storage is under the seat. The headlights and taillights are easily removable with wing nuts for racing. This Model T Speedster is perfect for period correct drag race and hill climb events. It will also turn heads at car shows and parades. It won a trophy at the 2017 Texas Thaw and was a featured car at the 2017 Lonestar Round Up. $14,000 Also interested in a trade toward 1935-1940 Ford Coupe. This car is located northeast of Dallas, TX. Please call Chris at 972-658-7444. .
Bump...this car will be at the Fredericksburg swap meet this weekend, July 28th. Sent from my iPad using H.A.M.B.
