rebuilding after the crash
Discussion in 'Off Topic Hot Rods & Customs' started by racer-x, Sep 19, 2015.
  1. milwscruffy
    milwscruffy
    I like the dent in the tube as a badge of honor kind of thing !
    els, David Gersic, OahuEli and 2 others like this.
  2. Hilborn needs to get the barrel valve back before they comment. There will be a call tag included with the new one coming monday. The new bv wont go on my car without a set screw positively holding the bushing in place. The dent will stay for a while. Jim is very busy and has no time to replace it. It wont effect anything it just looks out of place to me. I guess it can be considered a character mark.
    els, saltflats, mad mikey and 5 others like this.
  3. milwscruffy
    milwscruffy
    If you have a HAMB alliance tag, rivet it over the dent and your ready for the HAMB Drags !
    els, chryslerfan55, saltflats and 5 others like this.
  4. Im at rogers shop dealing with the wheels and brakes. The wheels turned out to be for chevy spindles. With no others available we are doing what hot rodders do and thats make them into fords. We have a ford hub to get measurements off so we are machining for races and seals. The pic of the back side of a wheel is of the reproduction aluminum five spoke. There are threaded holes to mount a rotor. The originals dont have material there so i have already made a adaptor that will press on. Its all very time consuming. 20170730_183440.jpg 20170727_111106.jpg
    els, chryslerfan55, JUNK ROD and 7 others like this.
  5. Tim
    Tim
    from KCMO
    Looking good man. Your gonna have quite the welcoming party down here ;)
    els, loudbang and racer-x like this.
  6. Runnin shine
    Runnin shine
    Would it have been too difficult to remove the adapters,that took a very long time it seemed to make, from the old wheels?
    els likes this.
  7. The wheels are the last piece of the puzzle to get back on the road. I cant wait for the hamb drags. I have tried for several years to get there. It will be fun running at a new track. We plan on trying a few things as we prepare for drag week. Is mokan a nhra track? I need to make one more pass to get my cross over licence.
    els and loudbang like this.
  8. The old adaptors are on for good. If i would want to remove them i would have to turn them off in a lathe. The other issue with them is they were set up for a anglia spindle. We are now using a ford spindle. They have different dimensions. Good question.
    els, loudbang and Runnin shine like this.
  9. Tim
    Tim
    from KCMO
    Looks like ihra
  10. Ok thanks. I have a license for that. Roger has run there. He said its a long shut off.
    els, loudbang and porkshop like this.
  11. Tim
    Tim
    from KCMO
    3075' to the last turn off
  12. wrenchbender
    wrenchbender
    Yes mokan has a good shutdown the return road is a bit sketchy but a car with suspension isn't a big deal but my dragsters solid suspension is a bit rough lol it is a ihra track and is a lot nicer than George rays lol but has the same vibe if you need anything Brian I'm only 10 min from the track glad you are gonna be able to come
    els, loudbang, mad mikey and 2 others like this.
  13. It would be fun to hit george rays on sunday. I have not been there in a few years. Too bad mr george ray is gone. He was one of a kind. Thank for the offer of help. Im hoping it all goes smooth and i dont need to take you up on that.
  14. saltflats
    saltflats
    from Missouri
    Make sure you get signed up.
  15. I took care of that last week. Im in.
    els, kidcampbell71, loudbang and 3 others like this.
  16. enloe
    enloe
    from east , tn.
    Man I wish we were going:(
  17. wrenchbender
    wrenchbender
    If you decide to go to George's on sun I would go too that would be a great place to run my dragster especially for some good pics with the 57 chevy push car
  18. The first half is done. The spindles now fit the wheels. After lunch the hats go on. 20170731_110304.jpg
    els, chryslerfan55, loudbang and 4 others like this.
  19. 20170731_183617.jpg A register was cut on the inside of the wheel. Being a casting there is some variation on the size. We cut in enough to have a .125 register. The adaptors are then cut to be pressed on. 20170731_154228.jpg 20170731_141957.jpg 20170731_160241.jpg
    els, chryslerfan55, Jet96 and 5 others like this.
  20. pigfluxer
    pigfluxer
    Making chips and rapid conversation .. Go man go.
  21. 20170731_190018.jpg I just need to make caliper brackets. 20170731_185201.jpg
    els, chryslerfan55, OahuEli and 9 others like this.
  22. 20170801_021244.jpg I got home after a 5 hour drive to find that the new barrel valve had shown up. The new one is pinned to retain the bushing. I dont know if this was done special for me or if this is a design change. The incident certainly has not gone unnoticed at hilborn. I will follow up with them soon. 20170801_020406.jpg
  23. enloe
    enloe
    from east , tn.
    You drawing so much attention to this might have saved someone's life down the road.
    els, chryslerfan55, Dog_Patch and 4 others like this.
  24. milwscruffy
    milwscruffy
    I'd say it was done special, otherwise the roll pin hole would also be black anodized. Think I'd still be more comfortable with a threaded set screw with lock tight, but they should know what will work.
  25. Runnin shine
    Runnin shine
    ^^This is not the kind of R&D one wants to get paid for.
    I try not to think of what could of happened after a less abbreviated pass.
    els, loudbang and bobwop like this.
  26. I wish i got paid. The main thing is the videos recorded the incident. Now hilborn will decide if they are going to make a design change. Im thinking they will. They cant have anything like this to ever happen again. Everyones safety is my biggest concern.
  27. I started mocking things up this evening. I have a good idea how to proceed from here. All three steering arms need to be heated and bent. They can be rechromed at a later date. 20170801_212320.jpg 20170801_212346.jpg I think the brake caliper brackets can go were the spacers are now between the spindle and upper steering arms. Then i can make the tie rod. I think making and mounting the caliper brackets will be the hardest part. It all sounds so simple. Im sure it wont be. At least i have a plan.
  28. I put the new barrel valve on today. Hilborn put the roll pin on the bottom of the bv. This is a good idea. The pin is now trapped between the bv and the injector casting. It cant possibly come out.
    els, OahuEli, milwscruffy and 4 others like this.
  29. saltflats
    saltflats
    from Missouri
    It is never easy......
    What is your fuel plan for the H.A.M.B. Drags?
  30. I plan on bringing the drag week trailer with me. That way i have nitro tools oil and slicks. I can drive it down on gas then convert it over to nitro at the track. I plan on doing everything the same as what i do for drag week. I will be trying a few different things related to exhaust and cooling. There is always something to learn.
    els, Dog_Patch, Woogeroo and 4 others like this.
