Projects The next $500. investment
Discussion in 'Traditional Hot Rods' started by The37Kid, Aug 2, 2017.
  1. The37Kid
    The37Kid
    There is another thread on why we don't like working on our projects, money and parts is a reason some times. What is the next $500.00 + investment you need to make to allow progress to be made? Me, I need a Steadfast kickup kit for Model A body to '32 Ford frame kickups. Bob
  2. typo41
    typo41
    cab corners and tires for my 41 pickup
  3. Bandit Billy
    Bandit Billy
    I'm hoping one of you says a new moon fuel tank since I listed one on the parts page last week for $500. :rolleyes:
    46international, slv63 and Hnstray like this.
  4. williebill
    williebill
    If I could buy time, $500 worth would be a bargain in my garage.
    scotty t, Texas Webb and Hnstray like this.
  5. Von Dago
    Von Dago
    from New Jersey
    I need a new air compressor. My old Sears (circa 1975) 2hp unit isn't up to the task anymore.
    natedeville likes this.
  6. mr57
    mr57
    I have the Fenton's. Now to run the pipes....Should still have money left over for a cheapy set of 1/2" deep sockets...
  7. flatford39
    flatford39
    Need to have my Model A radiator recored and the tanks modified for a flathead V8. Not holding me up right now as I am working on final fitment of the rear end and getting my driveshaft cut.
  8. Flathead Dave
    Flathead Dave
    from So. Cal.
  9. metalman
    metalman
    $500? I wish. My 41 PU needs a bed and wood kit, just shy of 2000. Then I can start thinking about the $500 parts + all the $20 to $100 parts that add up to multiple $500 real quick!
    This hobby sure isn't a cheap as it use to be!
    Bandit Billy likes this.
  10. tfeverfred
    tfeverfred
    Almost 1/3rd of what my T's body will cost.:(
  11. sloppy jalopies
    sloppy jalopies
    Sloppy's next $500 speculation...
    radiator, grill and insert for my '30 coupe..
    original grill guard [wire mesh] was too narrow... $150... nope.
    3" chopped alum. A radiator was $225 shipped...
    top half of the '31 grill was $75 , local...
    bottom half of a '30 was $35, local..
    welding the 2 together, free...
    sheet of 4' overhead light diffuser... $13 at lowz... does 2 A inserts...
    all 5 for less than $500... yahoo !
    there are different size squares... chose 3/8".
    painted flat black, adhered with industrial silicone,
    side view.
    silicone drying, with weights.
  12. TVC
    TVC
    WOW ! That light defuser grill insert is BRILLIANT ! I'm heading over there this weekend to score some for myself.
    Thanks for the post ! ! ! !
    Oh, if I had an extra $500, it would make a good start on another project. Have my eye on one right now for a grand but might possibly talk him down to $750.
  13. tb33anda3rd
    tb33anda3rd
  14. Koz
    Koz
    Need the radiator to move forward. $500 will be a good start......
  15. Turbo26T
    Turbo26T
    More like $ 600 for a full set of subrails for the Model A coupe ...Then $500 +/- for roof -wood kit ...Then $500 for...oh heck ,it never ends !!!!
    I seriously need to win the lottery...
  16. squirrel
    been thinking about getting the bumpers chromed. That would wipe out $500 pretty quick. And then some, is my guess.
    no, I don't want to buy new chinese bumpers for half the cost.
  17. treb11
    treb11
    Either Newport wipers or a bonded ***le for my '40 project. But a spare $500 will probably go toward the chimney repairs needed before winter.
    InstantT likes this.
  18. InstantT
    InstantT
    from SoCal
    I had a set of matched tripower Rochester 2 jets. I've moved twice and can't find them anywhere.
    Sent from my LGLS990 using The H.A.M.B. mobile app
  19. 325w
    325w
    Wish 500 would finish it.
  20. RMR&C
    RMR&C
    from NW Montana
    Right now time is needed more than parts.....need to build the new floor in my '34 sedan after channeling.
    A shrinker/stretcher is on the want list though.
  21. barrnone50
    barrnone50
    from texas
    Paying for me and the Mrs. to go to the Hot Rod Hill climbs.
  22. Mr48chev
    That would buy about half of the 13 yards of concrete I need for my shop floor. I need the shop floor and the shop before I do much of anything on the projects.
  23. Dirty Dug
    Dirty Dug
    Why don't you make your own kick-up? Guys have been doing it for a lot of years before Steadfast started selling their overpriced kit. Save yourself a bunch of money and learn something new while you're at it. That's what hot rodding is all about
    bct likes this.
  24. gene-koning
    gene-koning
    I've been working on a 39 Dodge pickup, but I just bought a 47 Dodge pickup. The 47 is a lot nicer truck, the 39 is pretty rough, but the 39 is closer to being roadworthy. I need to decide which truck to spend the $500 on. Sorry, no pictures yet. Gene
  25. Rocky
    Rocky
    Classified Editor
    An 11" pressure plate to work on my "long style" drilled aluminum flywheel. I may get a mustang plate to work with a chevy clutch disc. And some paint supplies. Variprime would be a good start.
  26. The37Kid
    The37Kid
    True, But some times it is better to step up and use a proven product, and besides at 66 there is time better spent on other things. Bob
  27. sloppy jalopies
    sloppy jalopies
    IMO... if it need not be sculptured to match the frame rail's contour, try using model A subfloor cross rails [3] for $75...
    angled up, flat top and angled down at the rear...
    trim the outside flange off from the wheel well back as the sub-rail gets narrower...
    the section you don't trim sticks outward and gives you something to attach the quarter panel to...
    if you have access to a brake you could make your own... $
    ... go bob go !
