Projects 1941 Merc custom
Discussion in 'Traditional Customs' started by Black Clover Custom, Jan 25, 2017.
  1. Black Clover Custom
    Black Clover Custom
    I want to make less cuts, but you just can't. At least when i lead this car (no bondo on this one) it will make it all disappear. Thats the plan anyway.
    rodncustomdreams and brEad like this.
  2. patterg2003
    patterg2003
    I have been following your build from day one. The chop is coming together & looks very well done with perfect proportions. All the rear windows look perfect & not the odd portholes that some have. It will be great when it is finished.
  3. Black Clover Custom
    Black Clover Custom
    Thanks for the "mild" support. Sometimes mild is the way to go on these cars. The rest will be wild though because all fenders will be welded onto the body.
    koolkemp and rodncustomdreams like this.
  4. Black Clover Custom
    Black Clover Custom
    Ok. Here she is. Chop is done with just one inner tab left on each side.
    Lots more to do to ****on this thing up but MAN that was a lot of work. Satisfied.
    IMG_1320.JPG IMG_1321.JPG IMG_1322.JPG IMG_1323.JPG IMG_1326.JPG IMG_1328.JPG
  5. Black Clover Custom
    Black Clover Custom
    In between summer fun i have been putting on lots of little filler pieces. Now its time for the firewall. Wondering if its worth removing all of the round discs that were made WAY back and brazed on to fill holes. You can see alot more of them from the inside. I kinda like them because its kinda history work from back in the day. But i have more holes to fill with my own little discs if i go with it. I don't know. IMG_1339.JPG IMG_1340.JPG IMG_1341.JPG IMG_1342.JPG IMG_1343.JPG IMG_1344.JPG IMG_1345.JPG IMG_1346.JPG
  6. Black Clover Custom
    Black Clover Custom
    Rolled a bead with the widest roller die i have on my bead roller with a little help. Help was a piece welding it together so it wouldnt spread open because it was a 16 gauge piece. Well, it just wasnt wide enough so i figured out that the beadroller itself was the perfect size to make the bead wider. Welded it and hammered it with a socket the right width. Worked really well. Patched up the firewall.
    Then i made a couple of cuts on the a pillars to get the roof/pillar seams to match up.
    Next i made the patch for the front left floor to match the other side.
    Piece by piece its working. IMG_1350.JPG IMG_1351.JPG IMG_1352.JPG IMG_1353.JPG IMG_1348.JPG IMG_1349.JPG IMG_1354.JPG
  7. oneratfink57
    oneratfink57
    from Wisconsin
    Nice thinking with using the bead roller frame!
  8. Black Clover Custom
    Black Clover Custom
    Reworked the lower front gaps on the doors and have the curve where i want it. All closed up on the ends and bottom. One side is an 1/8 long but i will wait until the running boards are here to finish that work. They will be welded and smoothed onto the car so it wont matter much to fix them right now. Pic isnt the best but all is flush and gapped right. And lead will make it perfect. IMG_1364.JPG IMG_1365.JPG IMG_1366.JPG
  9. brEad
    brEad
    Very nice! Really enjoying watching your progress!
    Black Clover Custom likes this.
  10. Black Clover Custom
    Black Clover Custom
    You know... i was just thinking about that. My progress is directly related to you guys! I wouldnt be nearly as far if it wasnt for this place. It drives me to the shop just to have something to show you guys. Crazy.
    302GMC, rodncustomdreams and brEad like this.
  11. fortynut
    fortynut
    I like the proportions of your chop. I have been thinking three inches in the A-pillar, etc. But, your solution is pleasing to the eye without having a mail slot greenhouse. Your solution to several obvious hurdles will make this little coupe a very cool mild custom. Keep at it. The biggest hump is behind you.
  12. Black Clover Custom
    Black Clover Custom
    Out with the old motor and... ugh, in with the old motor after it gets cleaned and painted. Not enough cash for a merc flatty or a chevy 348.
    But its time to get the ch***is all cleaned up, wire wheeled and por 15 painted. Cleaned up good.
    Got some things taken off of it and just have a couple to go before wire wheeling.
    Steering box will go down to California (forgot the company name) to get rebuilt.
    Trans will get rebuilt here.
    And motor will get tripower and better smaller alternator with nicer brackets. Will keep the buick 6 blade fan on it. May get headers for it but not sure.
  13. Black Clover Custom
    Black Clover Custom
    Couple more things came off of the frame. Ready to clean it up with good old manual labor. IMG_1402.JPG
  14. fortynut
    fortynut
    Gotta love elbow grease as the best cleaning solution ever. Judicious amounts do wonders. Too bad it's not available over the counter.
  15. Black Clover Custom
    Black Clover Custom
    Yeah it can be a car club name also. Elbow Greasers CC. I would join up.
    rodncustomdreams and Torchie like this.
  16. Black Clover Custom
    Black Clover Custom
    Wow that was a hell of a lot of wire wheel action!!!! ****s. But i pressure washed and used purple power degreaser before and during to get everything squeaky clean.
    Its ready for metal prep and por 15.
    All i have to do is finish moving the p***enger side motor mount over a little so i can use the whole biscuit instead of cutting it to fit the fuel pump. Figured that out with the engine mocked back in the frame. You can see the little drilled hole on the engine mount down and over by the weld. Thats where i will cut the mount and bend it to clear the washer, fill it in with a piece of steel and weld it back together. And then be able to use all of the mount. Not too bad.
    I already made the new hole on the frame. Will fill the old hole in and paint.
    I am keeping all of the old work done to this frame to drop it because after i cleaned it all up it doesnt look too bad. Cant take the history away :) Not gonna be a concourse car anyway right? LOL IMG_1410.JPG IMG_1411.JPG IMG_1408.JPG IMG_1409.JPG IMG_1406.JPG IMG_1407.JPG IMG_1405.JPG
  17. Black Clover Custom
    Black Clover Custom
    I got some more time tonight and finished.
    The p***enger side hole i dremeled and patched up. The drivers side i cut up a washer that i bought at coastal. It was the perfect size. Came from a lynch pin. Lucky.
    So all is welded up and ground smooth.
    The engine mount i cut and bent at a better angle to get the washer and nut on easy. All done.
    Now im going to see if i want to weld on some of the transmission mount and some of the brake and clutch ***embly directly to the frame instead of bolting them on. May be better since its not coming back off ever. IMG_1418.JPG IMG_1412.JPG IMG_1413.JPG IMG_1415.JPG IMG_1414.JPG IMG_1417.JPG
  18. Torchie
    Torchie
    Frame is looking great!
    I wouldn't weld those parts on. But then I never say never either..... :)
    If you have to remove any of them with the body on it could be problematic.
    Torchie
  19. straykatkustoms
    straykatkustoms
    Thank you for taking the time to post the pictures of your progress. Hopefully this will inspire others to build a kustom.
    Lines likes this.
  20. Black Clover Custom
    Black Clover Custom
    Have you checked out (cutting up a 1938 plymouth... uncutting it and cutting it up again) thread? Its a good one!?
    straykatkustoms likes this.
  21. Bandit Billy
    Bandit Billy
    Excellent! A lot of nice work. Speaking of other threads, have you seen the "how much wire to wire your car", you got to be about a dozen spools of .030" in by now. :cool:
  22. Black Clover Custom
    Black Clover Custom
    Just my old pics from the lincoln brake swap i did last year and front end rebuild. King pins and tie rod/ drag link ends.
    Had to marry the lincoln rear emergency brake rod with the 41 end to accept the 41 brake cable ball end. They are different. And the 41 brake cable tube to the lincoln tube mounting plate. All worked out good.
    Wanted those pics on this thread.
    I used copper brake lines then but will swap to steel this time around. 1941 merc lincoln brakes 006.JPG 1941 merc lincoln brakes 009.JPG 1941 merc lincoln brakes 013.JPG 1941 merc lincoln brakes 014.JPG lincoln plates ready 001.JPG lincoln plates ready 005.JPG lincoln plates ready 007.JPG spindles ground wishbones tight 012.JPG spindles ground wishbones tight 014.JPG e brake 001.JPG 1941 mercury lincoln brakes and 3spd swap 004.JPG 1941 mercury lincoln brakes and 3spd swap 003.JPG e brake 008.JPG front lincoln brakes on 002.JPG
  23. Black Clover Custom
    Black Clover Custom
    Your right. I thought about what i had to do to get the trans out when i swapped it for a manual. It would be super hard to get to the bolts. Not gonna be lazy. I will go to fastenal and get good bolts. Haha.
  24. Black Clover Custom
    Black Clover Custom
    IMG_1429.JPG IMG_1431.JPG IMG_1430.JPG IMG_1432.JPG IMG_1433.JPG Better than starry night but not quite the mona lisa.
  25. Black Clover Custom
    Black Clover Custom
    Just got a 39 trans from a member here. All rebuilt and alot of nos parts in it. Pic after work. Now i will paint the motor and trans to get it ready for the roller. Major step closer.
    And my steering box is going out for rebuild saturday. Should be back in a week. Great company in Oxnard Ca. called Express Parts Exchange. They do the best work on any old steering box. No problem sending it with the long steering shaft on it either.
  26. bskustoms
    bskustoms
    from Aloha, Or.
    Glad to hear things are progressing. It's always gratifying when the dreams become hands on. Thanks for the updates, hope to see more soon.
  27. Black Clover Custom
    Black Clover Custom
    IMG_1436.JPG IMG_1437.JPG Time to paint trans and motor.
  28. 1-SHOT
    1-SHOT
    from Denton
    I really like the profile of your Merc. I can appreciate all the metal work you put into it, the time and patience need to pull this off . Makes me want to pull my 46 Merc. In the shop and follow suit. Thanks for letting me tag along. Frank
  29. Black Clover Custom
    Black Clover Custom
    The steering box company in Oxnard Ca. that i sent it to called to say it can be finished early next week. Maybe even monday. The worm drive it needs is $100 plus what they get to rebuild it plus shipping back. Total to be around $500. I think its well worth it because they rebuild and test and actually guarantee it will be better than oem! Yup. They said it. Pics when it gets back.
    kidcampbell71 and brEad like this.
  30. 1-SHOT
    1-SHOT
    from Denton
    Personally I would like to hear it run first and pull the pan and check the bearings first. The used one sounds like a pig in a polk to me. It's to hard to put it in then have to take it out and do it again for the same $$$$
    I think a 261 Chevy or a 302 GMC would be a better choice both have real good torque. Old military Deuce and 1/2 had 302 in them.
