Projects The long process of finding a project car and adventures of the new guy.
Discussion in 'The Hokey Ass Message Board' started by RaginPin3Appl3, Apr 4, 2016.
  1. chevy57dude
    chevy57dude
    Great! Then pics at 9:30 ish, right? No pressure or anything...
    1935streetrod likes this.
  2. RaginPin3Appl3
    RaginPin3Appl3
    Thats the plan
  3. RaginPin3Appl3
    RaginPin3Appl3
    Well, got her in my garage, if you can even call it that. Had a heluva time getting it off the trailer because the front tire was shredded. The l6 is full of oil so im going to go get a battery and see if it will turn over. Water pump is pretty rusty though so i dont have high hopes. I took a few pics of it once it was in the garage, me and 3 other guys had a hard time getting it in like i said, so once we made progress there was no time for pics. [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  4. treb11
    treb11
    Dont try to turn it with the starter. Thats how you break things. Use a socket and long breaker bar and turn by hand. If you can get access to a borescope pull the plugs and peek inside first
    Sent from my SM-G550T using The H.A.M.B. mobile app
  5. enloe
    enloe
    from east , tn.
    I like to take about an ounce or 2 of Kroil and put down each spark plug hole and let it sit for a couple of hours before I turn it.
    then put plugs in and give it a shot.
    chevy57dude likes this.
  6. RaginPin3Appl3
    RaginPin3Appl3
    So, i've run into my first problem. It's my understanding that tri fives are negative ground, which means the single battery cable goes on the positive, the cable running to the starter and to the core support goes to the negative? I'll attatch some pics of what i'm seeing. Thanks[​IMG][​IMG]
  7. RaginPin3Appl3
    RaginPin3Appl3
    And i put oil in each cylinder through the plug holes. I couldnt turn it at all by hand so hopefully the oil helps
  8. low budget
    low budget
    from Central Ky
    Hot dog! You finally did it! Starter cable to +pos , ground cable to neg - like normal.
    I was gonna try and root for ya whatever you bought but I secretly liked this one the best especially for the money;)
    So heres your long awaited big CONGRATS! I like it, looks pretty solid, especially the trunk area.
    ...I would put a little marvel mystery oil in the cylinders.
  9. RaginPin3Appl3
    RaginPin3Appl3
    Got the engine turned over, now i just need help with my battery cable situation
  10. chevy57dude
    chevy57dude
    Congratulations.
    You are now a Tri 5 ****! Ha ha
    Those cables are ****. Ground the battery to the block, and frame. There's other body grounds, but those are the big ones.
    RaginPin3Appl3 likes this.
  11. low budget
    low budget
    from Central Ky
    first pic is ground- The second with 2 wires is pos+ notice the positive is for the bigger positive battery post/terminal
  12. flatford39
    flatford39
    Not sure what your question is. The cable from the starter goes positive. The cable from ground goes negative. You are going to want to replace those cables eventually but they should turn over the engine. You may have to play with them a little to get a good contact. What are you doing for fuel delivery???
  13. 1964countrysedan
    1964countrysedan
    from Texas
    Congratulations on your patience and find.
  14. RaginPin3Appl3
    RaginPin3Appl3
    Thanks guys, well, the wiring works, right now i'm putting new plugs and wires in and then i'm gonna see if it will fire. Damn the horns on these things are loud. Sounds like a freight train rolling into town
  15. RaginPin3Appl3
    RaginPin3Appl3
    Another question. Where does this run to? Should i run a hose to a certain place? Besides that i'm getting a spark but the carb leaks gas everywhere[​IMG]
  16. steinauge
    steinauge
    from 1960
    Clean the carb.Sounds like the float is stuck.BTW congratulations!
  17. flatford39
    flatford39
    That looks like a heater hose port. You are going to want to remove it and plug it or you are going to have coolant everywhere.
    Gumout is your friend when it comes to cleaning all the **** out of the carb.
  18. henry29
    henry29
    Is that dusk pearl? Hard to tell in the pics.
  19. RMONTY
    RMONTY
    Someone will be in the garage until 3 or 4 am tonight lol!
  20. RaginPin3Appl3
    RaginPin3Appl3
    Alright i'm taking a bit of a break, i leave for school tomrorow so i'm a bit busy. Took the carb off and the intake is full of rusty gas. Can't seem to get the gas cap off which ****s because according to the gas gauge, it's completely full... great. Full tank of 25 yr old gas
  21. chevy57dude
    chevy57dude
    You'll get it. You made a big step this week.
  22. RaginPin3Appl3
    RaginPin3Appl3
    Yeah it's dusk pearl, my least favorite 57 color...
  23. RaginPin3Appl3
    RaginPin3Appl3
    I looked closely at the heater and i dont think its anything heater related. There are no dangling hoses anywhere either. I wont be able to work on it for about a week anyway, so i have time for you guys to enlighten me
  24. chevy57dude
    chevy57dude
  25. RaginPin3Appl3
    RaginPin3Appl3
    Thank you, i'll have a look at it in the morning to see if i can figure out what going on.
  26. Torkwrench
    Torkwrench
    Congrats on your purchase. Yes, that is a heater hose connection.
    By the way.....Have you looked into getting a shop manual? This would be a "Factory" Chevrolet shop manual, NOT a Chilton's or Motors manual.
    The factory manuals are well illustrated. Plus they are very simple and easy to read, unlike new car shop manuals. They are available in reprints and are relatively cheap. This would be one of the best investments that you can make in your 57. It will basically tell you how to work on every part of your car, from wiring, to suspension, to removing / installing trim, or gl***. Basically everything on a 57 Chevy is covered in the factory Chevrolet shop manual.
    A "Factory" ***embly manual would be a great help, too.
  27. chevy57dude
    chevy57dude
    Torkwrench is 100 % correct. It's the "Bible". Many of the tech pix I've put up are takeoffs from the shop manuals. Mine is worn and has greasy fingerprints all over it. Useful and great reading.
  28. low budget
    low budget
    from Central Ky
    Just be safe, a fire extinguisher might not be a bad investment especially with the carb issue, also making it a roller to be able to roll outside would be good too.......
  29. RMONTY
    RMONTY
    I'll give you a few bucks for one of your bowling pins to help fund your project since you have multiples! Glad you finally have something to work on. Looks like a pretty solid start!
  30. bobss396
    bobss396
