Technical 1955 331 Cadillac to 37 LaSalle trans! Can it be done???
Discussion in 'Traditional Hot Rods' started by 31pickemup, Aug 4, 2017.
  1. 31pickemup
    31pickemup
    Hey guys I just picked up a 1955 331 Cadillac engine. I have everything to mount a 37 Lasalle to a 54 and earlier extended bellhousing block. But is it possible to mount one up to a 55 modern style block engine? Did they ever make an adapter? Help most appreciated!
    cactus1 and kidcampbell71 like this.
  2. alchemy
    alchemy
    I've got a bellhousing that will put a CadLasalle behind a flathead Ford, so the same should bolt up to your short bellhousing there.
  3. 31pickemup
    31pickemup
    So I would have to run two adapters? Alchemy is your adaptor for sale?
  4. 51 mercules
    51 mercules
    It can be done! The one on my old T was a Cragar!. Kevin Gill now owns my old T! You might try Wilcap they have some Cad adaptors.[​IMG]
  5. alchemy
    alchemy
    I've seen adaptors bolted to adaptors. But mine is not for sale.
    ghornbostel likes this.
  6. 31pickemup
    31pickemup
    Somebody sent me this. It was at Portland swap.
    mgtstumpy and kidcampbell71 like this.
  7. sproadster30
    sproadster30
    from Natick, Ma
    I'm running the stacked Wilcap set up for the early cad to early ford, early ford to the T5, without issues for 10 years. You can surely adapt the lasalle to the adapter you have.
  8. I am running stacked adapters, sort of. Cadd 331 to flathead ford, Truck Hogs head to a T-5 that I built. Anything can be done, just a matter of thinking about the puzzle pieces and picking the right pieces to make it happen.
  9. cad-lasalle
    cad-lasalle
    from grafton nh
    I have the adapter from 55-62 Cadillac engine to the 49 -54 Cad bell housing, which the Lasalle trans bolts to. I've been running this same adapter in a land speed car for years. I bought this adapter for a spare. Seems like it's an Offenhauser 5018, could be wrong. Guess I'll never use it, so it's for sale.
  10. Caddy painted orange?? Blasphemy!!
    ls1yj likes this.
  11. 31pickemup
    31pickemup
    Hahaha I know makes me want to cringe
  12. ckh
    ckh
    Good score. I've been looking for a '55 331 for some time with no luck.
  13. @31pickemup isn't this what you're after? ^^^
  14. Dogberg
    Dogberg
    Yes I realize this post is 2 years old, but I've kept uneccesary stuff for longer periods than that!
    Do you still have it? :) If so I'm interested.
  15. cad-lasalle
    cad-lasalle
    from grafton nh
    That one is gone, but I have another vintage ad that adapts the 55-62 Cadillac engine directly to the Lasalle transmission.
    kidcampbell71 likes this.
  16. JJK
    JJK
  17. E Fudd
    E Fudd
    I know this is a long shot, but would you still have the early to later cad adaptor?
    Thanks, Greg 660-654-1988
