1930 Ford Coupe Project
Discussion in 'The Hokey Ass Message Board' started by BenLeBlanc, Dec 5, 2014.
  1. BenLeBlanc
    BenLeBlanc
    So, @flatheadtommy got slammed with work. I figured that I could handle the job.
    I took the engine down to Millworks hot rod & custom and tore into it. The rear main seal did end up being a slinger, but the rear main was good, so it couldn't have been the problem. Meanwhile, the oil pump access cover was also pretty gunky, but not leaky. I goobered it up with sealant though to be sure.
    Unsure or what the problem was, I started to clean the oil pan for re***embly when I saw this
    I took a flashlight and looked on the bellhousing side to see this:
    The spot weld had rusted and caused oil to drain through a pin hole and into the bellhousing! When I heated the motor up, the oil just flowed more easily. I just filled the hole with jb weld and I should be good to go!
    I then made a canvas top for my car while it was too rainy to reinstall the motor. If anyone wants, I can explain it, but it was very simple. ****ons down and is removeable. Cheap too.
    I then reinstalled the motor. Fixed a couple of things while I was at it. I used hockey tape (3m friction tape) as loom to protect everything.
    My new favorite picture...
    chop job, AHotRod, Speed~On and 14 others like this.
  2. wheeldog57
    wheeldog57
    Ben, you have done a great job on your car bud. You have built a cool, unique, and soon to be very fun hot rod there. Can't wait to see it!
    Sent from my SM-G900V using The H.A.M.B. mobile app
  3. simplestone
    simplestone
    I love that last picture, too. Great looking hotrod!!
    volvobrynk and BenLeBlanc like this.
  4. brEad
    brEad
    You're killing it! Great pic!
    BenLeBlanc likes this.
  5. Pete
    Pete
    Yup....what he said!!!
  6. Aaron D.
    Aaron D.
    Looking great Ben, you have come a long way.
  7. dentisaurus
    dentisaurus
    from Boston
    Top job, looks fantastic!
  8. captain scarlet
    captain scarlet
    from Detroit
    Cool ride.
  9. BenLeBlanc
    BenLeBlanc
    Thanks for all the kind words-
    I still cannot get the car to run well enough to drive. I worked on the timing and got it ok, but any throttle above idle breaks up, so I am back to carburetor work.
    While I wait for parts, I wanted to work on the hood again. There was a crazed in repair that was done to one of the halves that I wanted to get rid of. I figured some people also have hinge issues, so maybe they can see how I did it...
    I formed these flags by hammering sheet around a 3/8 rod on a vise.
    I then mounted the hood, and found out kinda what I already knew. The grille is too high and needs to be lowered. I have a tab that mounts off the front cross that already moved the radiator out three inches, I figure putting in a one inch drop will fix the issue.
    Stogy, volvobrynk, brEad and 2 others like this.
  10. waxhead
    waxhead
    from West Oz
    Nice job on the hood hinge. Looks good
  11. Mikel50
    Mikel50
    One step closer Ben, car looks great.
  12. BenLeBlanc
    BenLeBlanc
    Thanks-
    I had most of the day off today and fixed the radiator.
    Here is the new bracket.
    With that finally figured out, I finalized the radiator support rods. They don't make the size I needed, so I bought 2 3/8 x 1 carriage bolts, 3/8 solid steel rod, and 2 5/16 x 2.5 bolts. The real deal used 5/16 solid rod, but home cheapo only sells 3/8.
    I welded the carriage bolts on first. If you want to do the same, just make sure you ***emble all of the hardware onto it before you weld it. It is stuck afterwards. In order to clear the square of the bolt when tightening, I used 7/16 washer and lock. I then dressed the weld afterwards.
    Same deal on the front, but no pre***embled hardware necessary. I cut it an inch short so that you have the ability to thread in or out.
    Plan is to cover it with gloss black enamel to finish it. Turned out well for the price I think.
    AHotRod, Runnin shine, Stogy and 7 others like this.
  13. BenLeBlanc
    BenLeBlanc
  14. waxhead
    waxhead
    from West Oz
    Followed the link. Sounds great.
  15. Pete
    Pete
    Ben,
    I just watched your video, so damn cool! The car looks awesome.
  16. Stogy
    Stogy
    I'd say you stepped beck in time to the good old days in style. You have been finally rewarded. Enjoy the fresh noisy air Ben...;)
  17. patmanta
    patmanta
    from Woburn, MA
    Sounds PERFECT
  18. wheeldog57
    wheeldog57
    Motor has a throaty sound to it, car looks great. Now you get to enjoy it!CONGRATS TO YOU!
    Sent from my SM-G930V using The H.A.M.B. mobile app
  19. Tobbe J
    Tobbe J
    Awesome work!
    Skickat från min iPhone med H.A.M.B.
  20. BenLeBlanc
    BenLeBlanc
    Thanks for the kind words!
    I tried to take it for a drive Friday but broke down- once warm it started to miss and got progressively worse until it would miss anything above idle. I narrowed it down to the coil and hopefully a replacement comes in the mail.
    I did however get to work more on my hood. I was able to fix the extension to my liking, adding a hood center hinge. I then was able to work on the sides, using the same custom rolled hinges, because the piano hinge used before was not separable.
  21. wheeldog57
    wheeldog57
    If the coil doesn't fix the issue, put in a new condenser.
    volvobrynk likes this.
  22. BenLeBlanc
    BenLeBlanc
    It took multiple days of troubleshooting, but mr. wheeldog was right! I swapped in a new-new condenser and it runs flawlessly!
    I was able to make it around the neighborhood so I started to venture out. I was able to make it to flatheadtommy's place and also took it to the lake for the obligatory lakeside pictures. Canvas on and canvas off.
    AHotRod, mike bowling, Stogy and 8 others like this.
  23. GASSERBOB
    GASSERBOB
    from USA
    Looking good Ben. Sounds good too. I bet your glad your driving it now. Keep us posted with updates. And keep up the good work. Bob...........
  24. BenLeBlanc
    BenLeBlanc
    Just a quick update-
    I added plexi to the sides so that I can now “lock” the car up. I also bought some ceramic insulation on eBay at 12 bucks shipped and put it around the baffles in my headers. Worked incredibly well! Much more tolerable, and now driving is a lot more fun!
    After the tune up, I was actually able to drive down the the gathering of the faithful meetup. I left early due to rain and how open all of my car is (and not painted!). Since I live in Lowell, I had ~150 trouble free miles under my belt by the end of the trek. On the highway, I was able to get up to 65ish, with normal cruising speed of roughly 55. Very impressed with how the car did.
    With all of you wondering, what else is left? I still need to chop the top ~4 inches, finish the hood, and do bodywork.
    AHotRod, waxhead, patmanta and 2 others like this.
  25. Stogy
    Stogy
    Congradulations @BenLeBlanc on your maiden cruise...perhaps drive out the season before the next phase of Hotrod...maybe just maybe consider less of a haircut. It looks pretty smart as it is. Are you a tall fellow? Perhaps just 2-3. It's your choice of course. Hey nice pics...;)
  26. mike bowling
    mike bowling
    did you say 3" (haha - you still might end up as tall as Ronnie!)
    Car looks PISSAH! Tommy must of loved it.
    Happy Motoring, my friend
  27. Mikel50
    Mikel50
    It was great to meet and chat with you Ben. Here’s a few pics of your Coupe. I have a few more I’ll post up when I’m in a better area. [​IMG][​IMG][​IMG]
  28. Mikel50
    Mikel50
    Job well done !
  29. Mikel50
    Mikel50
    Awesome looking hotrod and from what Mike and Ronnie said she’s a mover on the highway too ! [​IMG][​IMG][​IMG]
  30. Mikel50
    Mikel50
    Ben if you want any of these file let me know.
    They can be blown up to 36”x24” posters. The resolution is perfect for it I’ll send you over a Dropbox file.
    mike bowling and BenLeBlanc like this.
