  1. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    The Guy Mabee Spl. which I believe used a Victress glass body.
    Bomb, loudbang, biggeorge and 2 others like this.
  2. Steffen Jobst
    Steffen Jobst
    gas pumper and biggeorge like this.
  3. Steffen Jobst
    Steffen Jobst
    Guess who ... äh .. forget it ...
    Bomb, jerome jeup and biggeorge like this.
  4. jimmy six
    jimmy six
    Guy Mabee...oil man for Texas... Car was recently found in either southern Texas or Mexico outside in a field or wrecking yard. I found the speeds I some of the SCTA archives in a private collection a few years ago.
  5. Hemi325
    Hemi325
    from Boerne, TX
    In 1953 the Mabee Victress ran 203 at Bonneville with fuel-injected Chrysler power.
  6. yellerspirit
    yellerspirit
    from N.H.
  7. twin6
    twin6
    from Vermont
    Tom Mix?
  8. Hudsonnutt
    Hudsonnutt
  9. Speedwrench
    Speedwrench
    Steffen Jobst and chryslerfan55 like this.
  10. Bubba1955
    Bubba1955
    "Automotive Industries Dec 1 '51
    ...A tank truck and trailer combination built by Kenworth Truck Co. of Seattle and owned by Mr. Ray Ogg of Portland, Oregon, was powered with an adaptation of a Hall-Scott 12 cyl marine engine. This is the only such installation and is rather an experimental unit.
    The marine engine is normally built with 5 3/4 by seven cylinder size with 6 1/2 or seven compression ratio and develops better than 700 hp at 2100 rpm However, for the truck installation it was realized, of course, that the torque would have to be cut down as no transmissions or drive lines were available to hold the marine engine torque or power. Therefore, a six in. stroke crankshaft was adapted from one of the 400 series engines and the compression ratio was reduced to 5 1/2.
    Two nominal 1 3/4 in. duplex down-draft carburetors were installed in place of the three 2 1/4 in. updraft units used on the marine engine. In this manner the torque was reduced to a maximum net value of 1300 lb ft and the horsepower to a net value of 450 bhp. Even with this derating the rig must still be handled with some discretion to prevent overloading the drive components.
    Gross vehicle weight cannot be increased, of course, due to legal limits so that no greater loads can be carried on this rig than on the others in the fleet. It is reported, however, that running time can be reduced some 2 1/2 hr. over that required by other trucks in the same fleet with same loads. This on a route containing many steep grades over a distance of some 320 miles.
    Cruising is done at around 1500 to 1650 rpm. The engine has to date operated over 200,000 miles with one replacement of spark plugs. It is interesting to note that the gasoline mileage averages somewhat over four miles per gal, as good as, if not slightly better than the six cyl engines on the same route. This result seems to check with other findings indicating that gasoline consumption, other things being equal, is proportional to loads carried.
    This particular truck can seldom be accused of slowing traffic behind it...." [​IMG]
    mammyjammer, gas pumper, Bomb and 4 others like this.
  11. That was a Pete.
    Ben
  12. Ghostcruiser
    Ghostcruiser
    from NE Florida
    A 1955 and 1960 needlenose 281 were used.
    Rob
    bramdax, Bomb, loudbang and 4 others like this.
  13. deucendude
    deucendude
    from norcal
    I an pretty sure that this Brewster is on a 33-34 chassis.
    loudbang and biggeorge like this.
  14. Steffen Jobst
    Steffen Jobst
    Sorry. I didn't research.
    @Rootie Kazoootie perhaps can help.
  15. Steffen Jobst
    Steffen Jobst
  16. Steffen Jobst
    Steffen Jobst
  17. rudestude
    rudestude
    Stop the guessing and questioning .......and just look up on Wikipedia- Brewster & Co scroll down to Automobiles then down to The Ford deal and the end...that has the complete story and the answers to all these questions......34 Brewster g search will open the door and they where 34's they started by purchasing 135 chassis from Ford ...hell go there and read it for your selves......
    Sent from my QTASUN1 using The H.A.M.B. mobile app
    loudbang and Steffen Jobst like this.
  18. Steffen Jobst
    Steffen Jobst
    That's too easy and too much facts.;)
    rudestude likes this.
  19. Steffen Jobst
    Steffen Jobst
    You're the top!
    You're a Ritz hot toddy.
    You're the top!
    You're a Brewster body.
    Cole Porter
  20. Steffen Jobst
    Steffen Jobst
  21. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    It's the Hoyt Spl. built very much like a Lotus 7
    bramdax, Bomb, biggeorge and 4 others like this.
  22. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
  23. Mike
    Mike
  24. Steffen Jobst
    Steffen Jobst
  25. thark
    thark
    from Oklahoma
  26. Steffen Jobst
    Steffen Jobst
    Thanks! Interesting story.
  27. loudbang
    Finish off the cars from Texas Strips
    Competition Garage
    again
    Huston Drag Race Way
    Loftin Steel Tying
    47ragtop, Bomb, Bubba1955 and 6 others like this.
  28. loudbang
    Robinson vs Collett
    Roland Leong 1965 Nationals Winner
    Rutledge, Musch & Walker AA Fuel Dragster at Wichita Falls Dragway, Texas.
    Rutledge, Musch & Walker AA Fuel Dragster at Wichita Falls Dragway, Texas..JPG
    San Diego Romona Raceway
    San Diego Raceway
  29. loudbang
    Milan Dragway 1964
    Onondago Dragway Michigan
    again
    Daddy Wagon with CRAZY driver
    Painting? Or what
    47ragtop, gas pumper, Bomb and 9 others like this.
  30. Steffen Jobst
    Steffen Jobst
