Projects 55' Ford Customline Build
Discussion in 'The Hokey Ass Message Board' started by 8x0x5, Aug 8, 2017.
  1. Hdonlybob
    Hdonlybob
    I like it a lot....simple, sanitary, and pure old school !!
  2. leadsled
    leadsled
    My thoughts exactly
  3. Knghtcadi
    Knghtcadi
    Do you have any pics , or any problems with the drive shaft rubbing?
  4. ElAndy
    ElAndy
    from Phoenix AZ
    I do not have any pics of the clearance but due to the angle of the blocks, there is plenty of room and no rubbing.
    Sent from my SM-G955U using The H.A.M.B. mobile app
  5. 8x0x5
    8x0x5
    So the other day I got my kit in the mail to switch the 6 volt setup to 12 volt. All went pretty smooth, except once I started digging into the electrical, I nearly **** myself in amazement that this car hasn't been up in flames yet.
    I found numerous wires behind the dash that were bare copper wire that were merely wrapped with electrical tape however many years ago. I found bare copped splices looses spun around wires to junction in with NO insulation of any kind. And finally when I pulled my headlights, found completely exposed and deteriorated wire housing wrapped in electrical tape as well... Being that I'm an electrician by trade, this ultimately just infuriated me, so I finished the swap, ordered a new wiring kit, and parked her until it gets here...
    Talked about being frustrated [emoji35]
    lothiandon1940 likes this.
  6. Knghtcadi
    Knghtcadi
    Ok thanks , how about room between the frame does it bottom out and where did you get your blocks from ? Sorry so many questions but that's all
  7. ElAndy
    ElAndy
    from Phoenix AZ
    I would say only 3 or 4 inches between frame and axle bumpers. If I let all the air out of the shocks it will lay on the axle bumpers. Its a comfortable ride. I also have 5:60 15's to help with the ride height.
  8. ElAndy
    ElAndy
    from Phoenix AZ
    I found the blocks at a swap meet. Just a local guys parts box.
  9. Knghtcadi
    Knghtcadi
    ElAndy likes this.
  10. drtrcrV-8
    drtrcrV-8
    Very nice ride!! For some reason I always preferred a customline with a "California Rake" (nose down) but that's just personal taste as it's your car, not mine. LOL!
    PunkAssGearhead88 likes this.
  11. 8x0x5
    8x0x5
    My EZ wiring kit came in the mail this week. Hopefully this all goes smooth and gets back on the road this week
  12. 8x0x5
    8x0x5
    Wiring is going good. Got about 2 hours into it. Most of the time was figuring out the best way to run the wires to the rear. With the way that Ford originally ran the tail light and fuel sender wires, I had to extend the left side tail light and fuel sending wire a hair because they wouldn't make it all the way into the trunk. Going to start on the dash when I get home and hopefully finish today. Need to get heat shrink.
    [​IMG][​IMG][​IMG][​IMG]
    Toot_55 likes this.
  13. JeffB2
    JeffB2
    from Phoenix,AZ
    Almost all the universal wiring kits are "GM friendly" this creates an issue in these 50's Fords because the GM cars headlight switches are different from the Fords,GM has two "hot" leads and Fords use only one. Contact EZ wiring Tech for info some the guys in the 1952-59 Ford Group that used Rebel Wire did that. Or if you have this: http://www.speedwaymotors.com/Book-How-To-Wire-Your-Street-Rod,2824.html
  14. JeffB2
    JeffB2
    from Phoenix,AZ
  15. 8x0x5
    8x0x5
  16. JeffB2
    JeffB2
    from Phoenix,AZ
    You need to use the one in the link I posted,a regular reducer 12 to 6 volt will not function with the fuel gauge the one in the link will handle all three gauges. If you run 12 volts to the gauges without the one I posted they will end up toast the one in the link is under $20,DO IT Right.
  17. 8x0x5
    8x0x5
    These were originally wired to 6v with no regulator or reducer, is there a reason a 6v reducer wouldn't work? Haven't heard that yet or seen it. Very curious. Thanks for the info
  18. 8x0x5
    8x0x5
    Wiring all done for now, will post a pic soon, but for now I just want to drive this thing while I can, before I tear into the front end. Ventura Nationals are coming up and need her running until then!
    I may or may not have somehow lost the brake light circuit somewhere along the floor before it made it too my trunk... so I need to pull the carpet up and look for it. I'm 99% I didn't trim it so I'm not sure where it went. I taped it all up before install and double checked, but I guess **** happens. We will see!
    Dos Cincos likes this.
  19. mikew
    mikew
    looks like a nice car!
  20. 8x0x5
    8x0x5
    Thanks man! She needs a lotta work but she's coming together.
  21. 8x0x5
    8x0x5
    Ignore the battery cable ugliness. That will all be sorted out. Here's a rough install pic gallery. Kind of want to change it up a bit. We will see.
    ElAndy and olscrounger like this.
  22. NashRodMan
    NashRodMan
    I really like how this car looks all white with the www and black wheels and chrome caps. Smooth.....
    8x0x5 likes this.
  23. bobss396
    bobss396
    Wiring looks good! I ran the wires to the rear of the car right down the middle of the car, to the right side of the trans hump. I made up a harness board to replicate the dash locations. I had 2 major legs going out the firewall, one for engine and one for lights.
    Summit makes a nice braided wire wrap that neatened up things a bunch and I can access the wiring to add or change things if I need to. Half the price of what Painless sells.
    https://www.summitracing.com/parts/sum-890341/overview/
    8x0x5 likes this.
  24. bobss396
    bobss396
    This is some of the wiring routing.
  25. Toot_55
    Toot_55
  26. Redlighting
    Redlighting
    from Tn
    Great car, thanks for the pics.
    8x0x5 likes this.
  27. bobss396
    bobss396
    Clutch master for the hydraulic clutch.
  28. Roothawg
    Roothawg
    Nice build. I own the twin to it.
    8x0x5 likes this.
  29. 8x0x5
    8x0x5
    Yup. That's how the factory ran power to the rear. There's an indented wire track specifically for it that goes from the cent front of the dash all the way to the rear seats and then into the left side inner wall of the quarter panel. I followed suit and taped up the whole run and utilized all the factory wire holders. Works well and don't even notice it's there. Can barely even feel it.
  30. Dixon Bastie
    Dixon Bastie
