Hot Rods T Bucket Interiors
Discussion in 'The Hokey Ass Message Board' started by tfeverfred, Aug 12, 2017.
  1. tfeverfred
    tfeverfred
    I'm far from being ready for an interior in my build, but during these times I like to plan future steps. Today, I'm day dreaming about interior/seating options. My last T Bucket had a bench seat, but this time around I'm thinking of maybe Bomber seats..... or not. Here's a pic of my last T Bucket interior. The bottom was padded and lifted out. The back was padded and folded forward.
    So, what have you other Bucket heads come up with? Naturally, pics and a brief explanation of build and comfort would be cool, too.:)
    AHotRod, Dannerr, volvobrynk and 3 others like this.
  2. Subscribed. I'm hoping what I've got will be decent. I bought some surplus seat frames for a HMMWV awhile back to use in my t when it is done. They're low back buckets. Think I paid $20 for the pair new. Figured I'd get the frames powder coated so they won't wear through and then have cushions made from high density foam wrapped in a water resistant fabric. Hopefully they'll work out but they've likely got a few more years before they'll see use.
  3. tfeverfred
    tfeverfred
  4. Blake 27
    Blake 27
    A lift out bench seat gives room under and access to mechanicals. 13.JPG DSC06173.JPG DSC06174.JPG
  5. HOTRODPRIMER
    HOTRODPRIMER
    Fred,I will get you a couple of photos of fellow club member Steve's T next time I see him,it's got a pretty nice interior although it is a bench seat. HRP
    tfeverfred likes this.
  6. RICH B
    RICH B
    I used white tuck and roll along with a few ****ons to define the top roll. Seat bottom has foam over webbing and sit on an adjustable height frame. Fair amount of storage space under the seat, too.
  7. tfeverfred
    tfeverfred
    Thanks, HRP! I'm undecided on bench or buckets, so all suggestions are welcome. I just want to see what other guys have done and how they dealt with the limited space in a T Bucket.
  8. RICH B
    RICH B
    On an older build, I used brown diamond tuft, removable seat bottom, too; but I put fuse panel and wiring there, learned my lesson on better for use of the space for next time.
    biggeorge, Hombre, kiwijeff and 4 others like this.
  9. tfeverfred
    tfeverfred
    I used a removable seat on the bench in my last T. Man, I had a LOT of stuff under there, including the fuse box. My plan this time is to have the seats closer to the floor and have it or them, tilt forward. Storage and the fuse box would be behind the seat. Or at least that's one plan.
    Here's what I've found so far:
    http://corbeau.com/bench-seats/42-baja-bench.html
    http://corbeau.com/fixed-back-seats/baja-low-back.html
    If you look at the video, these seats have vertical tabs for mounting to a frame that would attach to the floor. That space looks like it would be about 2". No room for storage, but maybe a fuse box. The angle of the seat back allows for a cavity behind the seat. That's why I would make the seats able to tilt forward. With the fuse box and a small storage behind them.
    My other option is to mount either the buckets or the bench to a box about 4" tall. That space would be for storage and a fuse box.
    And of course, my last option is to do like I did before and make my own bench seat with a lift off seat bottom. My budget may make this my best option, but I'm looking at it from all angles.
    Blues4U, loudbang and chryslerfan55 like this.
  10. 28 Ford PU
    28 Ford PU
    from Upstate NY
    What a little cutie. You've been blessed.
    ls1yj, Hombre, Fordor Ron and 2 others like this.
  11. steel rebel
    steel rebel
    Fred I love that Baha Bench seat. You couldn't have a seat like that upholstered for $400. If you have room for it. Looks like the backrest is padded pretty thick. You could probably hinge the whole seat so it folds forward.
  12. RICH B
    RICH B
    Thanks, that's my granddaughter Ardun.
    Hombre and loudbang like this.
  13. RICH B
    RICH B
    Fred; you will have more room to work with, using the stretch body; but I wouldn't squander any on the space needed for those aftermarket seats. Best use of T interior space has always been building the seat back into the rear of the body, with minimum padding, maximizing leg room and permitting lower seat base height.
  14. Marty Strode
    Marty Strode
    I have had them with both bomber style and bench seats. I like the buckets if it is a race car or replica, but the space that you loose between the seats is precious, but you know that. IMG_1145.JPG
  15. Blue One
    Blue One
    from Alberta
    As you may already know I have Frank Wallic aluminum bomber seats that are mounted right on the floor and then I had 4" thick pads made for the bottom and 2" thick pads for the backs.
    They give me every bit as much seating area as a bench seat in the same space would.
    I know that my steel RPU body is not a T bucket but the space (or lack of it :D ) is similar.
    WC145, Dannerr, biggeorge and 8 others like this.
  16. swade41
    swade41
    from Buffalo,NY
    I always thought a piece of canvas sewn to your liking in pleats or diamonds stretched from side to side as close to but not touching the back would be a room saver. Heck you could even pad the top 6 inches if you wanted by sewing a loop in the canvas, anyways i thought it would kinda be like a hammock but the back only.
    tfeverfred and loudbang like this.
  17. denis4x4
    denis4x4
    from Colorado
    The last time I had the Zipper interior redone, the seat back was fitted with a lumbar support. The seat bottom base had cut outs with 3" canvas strips and all of a sudden the car was comfortable to drive. Aluminum panels are screwed to the doors with sound deadener inside. DSC02855.JPG
    WC145, Dannerr, kiwijeff and 6 others like this.
  18. swade41
    swade41
    from Buffalo,NY
  19. 51 mercules
    51 mercules
    Interior on my old T![​IMG]
  20. tfeverfred
    tfeverfred
    Blue, the more I look at your set up, the more it pleases me. I got the measurements of where my seats would mount and a couple 22" wide buckets would be a good fit. Like your set up, they'd be close enough together, that they'd be as space effective as a bench.
    If I go with buckets, the p***enger side would be removable, to access the battery, which I plan to mount underneath. I'm still gathering info, but whether it's a bench or buckets, my plan is to have them as close to the floor as possible.
    Blue One and loudbang like this.
  21. Atwater Mike
    Atwater Mike
    My other '27 steel roadster was on '32 rails, everything built 'low' in the frame. I sat below the floorboard height, straps under the seating. Legs slightly 'up', but not bent much. Relaxing on a long run...
  22. belair
    belair
    If you go with buckets Fred, make the p***enger on tilt forward to get to the battery. Use a latch so you won't need any tools.
    loudbang and tfeverfred like this.
  23. tfeverfred
    tfeverfred
    Yea, that was also a thought with buckets.
  24. skipstitch
    skipstitch
    One I did several years ago. Both bottoms lifted out. The driver side housed the fuse panel.
  25. tfeverfred
    tfeverfred
    Very nice!
  26. F.O.G
    F.O.G
    from Pacific,Mo
  27. F.O.G
    F.O.G
    from Pacific,Mo
  28. F.O.G
    F.O.G
    from Pacific,Mo
    WC145, DaPeach, tfeverfred and 4 others like this.
  29. tfeverfred
    tfeverfred
    I like it. I have a tendency to gravitate towards a spartan interior in a Hot Rod. No frills... function.
  30. F.O.G
    F.O.G
    from Pacific,Mo
    Tried to keep weight down so the Olds wasn't overworked.:D
