Projects Dodge This - 1939 Dodge Southeast Gasser Build
Discussion in 'Traditional Hot Rods' started by Dog_Patch, Aug 12, 2014.
  1. Dog_Patch
    Dog_Patch
    Its almost licked and now I know how to swap pistons and hone like a top fuel team.
  2. enloe
    enloe
    from east , tn.
  3. Dog_Patch
    Dog_Patch
    IMG_4643.JPG IMG_4746.JPG IMG_4812.JPG IMG_4816.JPG IMG_4835.JPG IMG_5764.JPG IMG_5766.JPG IMG_5769.JPG
    This is the place Silver Streak hit the wall in the finals -
    Check the tire launch marks going towards the wall - this was the next morning.
    wvenfield, kiwijeff, jim snow and 5 others like this.
  4. Bad Banana
    Bad Banana
    Tony's my hero. Not many guys would have the bottom end apart on race morning at the track. You are the man! [​IMG]
    Sent from my SM-G950U using The H.A.M.B. mobile app
  5. Dog_Patch
    Dog_Patch
    Jimmy Huff was under there too and Gabriel was reading the torque wrench because me and Jimmy can't see anything without glasses anymore :D should have seen Mitch's face when I told him we were flipping the bearings like it was last year o_O glad you took a pic Rusty!
  6. dirty old man
    dirty old man
    I'm still of the opinion that Carillo owes you a set of pistons that will work or your money back on those so you can buy some that are built correctly for your application.
    Even with a 3/16" oil ring on those pistons, the fact that you only have 2 oil holes in the bottom of the groove per piston negates the ability to get that oil that the 3/16" ring has scraped off the cylinder wall out the back side of the ring groove and returned to the crancase.
    And to further fuck things up the underside of the piston as shown in a previous photo is forged in a configuration that doesn't allow any more holes. Carillo FUCKED UP!!!!!!!:eek::mad:
  7. Dog_Patch
    Dog_Patch
    At this point I don't want anymore dealings with those guys. I've learned about enough to fix it myself. It was a vacuum sump design piston and I'm making band-aides to get it to work in a non vacuum application - almost there. The skirt is so short its probably rocking and every hone we do is making it worse. There is a coating company that can spray the piston skirt to bring it back up to size. Probably do that when they get 1/16" rings. Also I only had 20W/50W oil at the race. Last year it ran on 10W-40W. It might work on 0W-5W like it was designed for.
  8. dirty old man
    dirty old man
    Is "1/16" a typo, for 3/16"? What's the width now?. Is the 0W-5 a racing oil? I stock 0W-20 and 0W-30 in Amsoil, but it's a premium synthetic, not a racing oil. Have a couple customers with OT late model Nissans that use the 0W-20 and used the 0W-30 in that OT Mkviii used to have, and also in a customer's OT Caddy with Northstar. Both are hi po DOHC 32V engines.
  9. flamin-408
    flamin-408
    No on the Big Block Chevy we will get the Old Hemi right it takes someone special to have a old Hemi anyone can make a BBC run.
  10. Dog_Patch
    Dog_Patch
    That's 1/16" on the top 2 rings. The oil ring is 3mm and there's no room to make it bigger. The next set of pistons will come with big power robbing ancient rings - but we won't be playing the tear down every race game.
    loudbang and Hang'emHigh like this.
  11. Higgy's Henry
    Higgy's Henry
    DOM, not to hijack Tonys thread but I just filled my motor up with ZRod 20w-50 and noticed some lower oil pressure readings at the big end of the track when she got hotter. Is this normal? It usually runs around 60lbs at idle, by the time I was done my runs it was down around 20lbs when I was returning. Any thoughts?
    Dog_Patch likes this.
  12. Higgy's Henry
    Higgy's Henry
    Wholesale changes for the H-BOMB before next race! I drive too far to race in a class that the fastest car qualifies at least 1/2 sec faster than 90% of the field in said class!!
  13. enloe
    enloe
    from east , tn.
    Tony is definitely SPECIAL :)
    Higgy's Henry, Dog_Patch and loudbang like this.
  14. allwilly
    allwilly
    Dog_Patch, loudbang and enloe like this.
  15. dirty old man
    dirty old man
    Send me a Pm and when I can, I'll call the tech line @ Amsoil. Need engine type and clearances and pump info, also previous oil brand,type, weight, etc. Any thing you can think of. Most of tomorrow is either at Drs. or going to and from so will be a day or two later before I can call.
    Higgy's Henry likes this.
  16. Dog_Patch
    Dog_Patch
    I saw this quote -
    • No mistakes leads to no experience, and no experience leads to no wisdom.
    My SBC 383 engine in the sedan delivery does that. Its running 20/50 ZR1 and it will get down to 20psi after it warms up.
  17. allwilly
    allwilly
    That quote has so much truth it's wrong. You don't learn from doing everything perfectly or having everything end up just exactly as it should be you always remember your mistakes or problems and learn from them this engine has given you nothing but problems but the knowledge you learn from it will make the next one way easier
    Sent from my SM-G900V using The H.A.M.B. mobile app
    Higgy's Henry and Dog_Patch like this.
  18. sonic03bluegt
    sonic03bluegt
    from sc
    If you do this even I will disown you!
  19. Mike Colemire
    Mike Colemire
    Tony's car sounded awesome Sat night, couldn't believe it was still smoking. Got to meet him and his wife, "Crew Chief", really nice people. I think him and Quain were the busiest 2 there. Zak"s dad told me he tried setting in that car and decided he was going with the 55. Hope everything works out Tony, you're a trooper.
  20. HEMIBERT
    HEMIBERT
    He can park down by the red car!
  21. Dog_Patch
    Dog_Patch
    That C/G car runs faster than several A/G cars - just put him in A/G
    Thanks Mike! I enjoyed talking to you - we have fun no matter - main thing is don't hurt anyone, don't hurt yourself, don't hurt the car. :D
    Gabriel would be mad because he wouldn't have a broke car to work on. He asked me if I've ever showed up to the track with a running car :confused: had to think about that. I push my car onto the trailer so him and Jimmy can get it running at the track :rolleyes:
  22. Dog_Patch
    Dog_Patch
  23. savannahDan
    savannahDan
    that's some really good press for the Southeast Gassers, Freiburger has a tremendous online following due to Roadkill and the Engine Masters stuff. Expect the attendance records to continue to be shattered. :cool: Also, the comments on Freiburgers post on FB are positive towards the SEGA, folks know the difference and are excited to watch a real gasser race.
  24. Hang'emHigh
    Hang'emHigh
    What is this "Log in" thing? I tried inserting a tree branch and the usb port did not like it.
  25. Dog_Patch
    Dog_Patch
    Yeah I don't think its free - its free for 30 days or something if you create an account.
    If you're on dial up I apologize in advance. Caleb Sewell and Kimberly Peck-Aden posted up pics on Facebook and I know some folks can't see them so brace yourself
    20229317_1710498265627634_193785574622546298_n.jpg 20292875_1710498375627623_2716070770237805692_n.jpg 20770184_1486753261406271_3601879782417026950_n.jpg 20770212_1710507122293415_2215098724266232635_n.jpg 20770238_1486752134739717_8013840119912684707_n.jpg 20798977_1710499332294194_44651810092748941_n.jpg 20799112_1486744538073810_5480308654506780761_n.jpg 20799132_1486744091407188_3465151943814841780_n.jpg 20799177_1486753251406272_3616134230320760040_n.jpg 20799277_1487514567996807_3931759782456680672_n.jpg 20799278_1710505215626939_8334451374430142600_n.jpg 20799351_1710499725627488_4062686614044213010_n.jpg 20799351_1710506408960153_1747439666018400157_n.jpg 20799372_1710499118960882_714196064894477866_n.jpg 20799382_1710500038960790_2482565175406576210_n.jpg 20799386_1710501722293955_8710776056549969735_n.jpg 20799390_1710506845626776_1429682336719407563_n.jpg 20799400_1710498885627572_3827774255594396509_n.jpg 20799402_1710499585627502_8324601941877996365_n.jpg 20799420_1710501818960612_1777642066162321068_n.jpg 20799427_1486744418073822_2756047304515930553_n.jpg 20799470_1710504875626973_2786055954648745894_n.jpg 20799481_1710499698960824_1955619915815106245_n.jpg 20799501_1710502265627234_3958255227462267543_n.jpg 20799517_1710501448960649_3957801222971085175_n.jpg 20799519_1710501468960647_6605117460780611231_n.jpg 20799521_1710502168960577_6023788246412877362_n.jpg 20799529_1710507115626749_1550658751514372812_n.jpg 20799530_1710499818960812_9132461412665466854_n (1).jpg
  26. Dog_Patch
    Dog_Patch
  27. Dog_Patch
    Dog_Patch
  28. Dog_Patch
    Dog_Patch
  29. Dog_Patch
    Dog_Patch
  30. Dog_Patch
    Dog_Patch
