Technical 1949 Cadillac 331 Valve covers
Discussion in 'The Hokey Ass Message Board' started by Pewsplace, May 28, 2017.
  1. Pewsplace
    Pewsplace
    Early 1949 Cadillac's had two bolt valve covers and in searching I have struck out. Does anyone know who makes these or has a pair for sale. The bolt holes are centered and 14" C/L . They bolt into the rocker shaft end caps. Thanks.
  2. Well, ya learn summick new ever day.
  3. Bleach
    Bleach
    I never knew that and I thought I knew everything there was to know about the 331's.
    I Googled photos of early 331's an there they were but still I don't know when they changed to 4 bolt covers.
  4. 1941coupe
    1941coupe
    I think 1949 331 was a one year only to have 2 bolt covers
  5. Dreddybear
    Dreddybear
    Yup and there's even some aftermarket cast covers for em for lots of $$$$$ if you ever come across them.
  6. Seein' is believin'...............
    ls1yj likes this.
  7. 31pickemup
    31pickemup
    The two bolt valve covers were only used in the first 3 months of production. Also the red oil filter and wing nut type canister were also early production. But I think only the first month or two.
  8. The other difference is they use a spring loaded plunger in the end of the cam,also only used for the first 3 or so months of production
  9. cad-lasalle
    cad-lasalle
    from grafton nh
    Somebody told me those early 49s had floated wristpins.
  10. Piston Farmer
    Piston Farmer
    Did you ever find a set? Because I’m pretty sure I have some
