Technical Model A Roof Insert
Discussion in 'Traditional Hot Rods' started by gbgh, Aug 17, 2017.
  1. gbgh
    gbgh
    The 29 Model A Tudor which we've adopted needs a roof insert. Back in my youth.... I saw a car or 2 that used a roof panel from a station wagon, which had very similar contours. In fact, somewhere in my hoard, there's a magazine article. Can anybody who's memory is better than mine give me an idea what worked? Love those roof ribs!
    AB Normal and els like this.
  2. b-bob
    b-bob
    '78-87 Malibu's are a natural. Did many of them years ago.
    els likes this.
  3. Just Gary
    Just Gary
    You're doing it backwards.
    Many of the donor recommendations you'll hear about have long since been turned into razorblades.
    Instead of asking what fits, make a plywood template of your roof's curvature, take the template to the local recycling yard, and see what's still *available* that fits.
    You may be surprised. I found that an '86 Toyota minivan fit my '28 Model A Tudor sedan perfectly, both lengthwise and laterally. Here's a thread that shows my steps:
    https://www.jalopyjournal.com/forum...e-6-steel-roof-covered-by-stock-vinyl.636247/
    I hate to sound negative, but around many metropolitan areas, junk yards shred anything older than ~10 years. :-(
    EDIT: The pictures in my roof thread were "kidnapped" by photobucket. I've since replaced them with the same photos, but hosted here on the HAMB.
  4. dana barlow
    dana barlow
    from Miami Fla.
    G20 Chevy van can be a donner,or any number of junk yard SUV. If you want ribs. If not,just get a SUV that has none
    els likes this.
  5. 30tudor
    30tudor
    Write down the width and length of what you need, take a hammer and a hack saw and head out to the junk yard. Hammer the gl*** out of the way and cut off the whole roof at the top of the posts.
    Station wagons are usually a good place to start. Have fun.
    AB Normal, els, gbgh and 2 others like this.
  6. sloppy jalopies
    sloppy jalopies
    I use a length of wooden strapping...
    measure the front to back length needed and mark it on one edge...
    then center that length on your roof and when you have an equal gap at each end mark that gap measurement onto the stick...
    repeat for the left to right, mark the length and that measurement on the opposite side of the stick...
    now just take the stick and a tape measure to the parts yard... HIH...
    els, gbgh and Just Gary like this.
  7. 28TudorAZ
    28TudorAZ
    Okie Pete, tommyd, Almostdone and 6 others like this.
  8. 28 Ford PU
    28 Ford PU
    from Upstate NY
    els and gbgh like this.
  9. X38
    X38
    And how is that useful to the OP and his question about a sedan roof?
  10. scrap metal 48
    scrap metal 48
    Okie Pete, els, porknbeaner and 2 others like this.
  11. fiftyv8
    fiftyv8
    from CO & WA
    An early Falcon station wagon roof ain't that bad a fit for a Tudor and early Mustang for a Coupe.
  12. 29moonshine
    29moonshine
    a mid 90 suburban will work if you want small ribs in the top
  13. sloppy jalopies
    sloppy jalopies
    Okie Pete, els and gbgh like this.
  14. 28 Ford PU
    28 Ford PU
    from Upstate NY
    harpo1313 and els like this.
  15. Vega wagon roofs work real well but they are like hen's teeth any more. Last one I had I hauled to California and the guy who got it traveled from SoCal to Santa Rosa to get it from me.
    Most modern wagon roofs work, they are real think and conform real well if you leave the roof bows in.
    els likes this.
  16. papajohn
    papajohn
    els likes this.
  17. 28TudorAZ
    28TudorAZ
    els and papajohn like this.
  18. pro tc
    pro tc
    from Dubuque Ia
    els likes this.
  19. 28TudorAZ
    28TudorAZ
    Cause it gets really hot in AZ.
    dirt t, hemihotrod66 and els like this.
  20. Fabber McGee
    Fabber McGee
    Is that rag top water tight?
    els likes this.
  21. Flathead Dave
    Flathead Dave
    from So. Cal.
    els likes this.
  22. Flathead Dave
    Flathead Dave
    from So. Cal.
    els likes this.
  23. 28 Ford PU
    28 Ford PU
    from Upstate NY
    It's a white pleated vinyl with a orange center insert.
    els likes this.
  24. 28TudorAZ
    28TudorAZ
    Yeap. If you look at the website. They put them on a lot of other types of cars.
    els likes this.
  25. Marty Escarcega
    Marty Escarcega
    from Mesa, AZ
    Old thread...let's resurrect it!
    Has anyone ever used the ribbed roof out of a 59-60 Chevy station wagon to fill the roof opening in a Tudor? (I heard they were popular back in the day for a filler panel) The ribbed roof is actually about 2/3 ribbed and 1/3 smooth. Wondering if you did, did you leave the ribs or fill them. If you didn't fill, any pictures of your roof? Thanks in advance.
    Okie Pete likes this.
  26. panhead_pete
    panhead_pete
    Have you seen the prices those long roofs are bringing? Unless you have access to a cheap body with a useable roof it may be an impossible task to locate one.
  27. Marty Escarcega
    Marty Escarcega
    from Mesa, AZ
    I have access to just the roof...
  28. gtokid70
    gtokid70
    My 26 t I just bought needs roof repair and I was thinking maybe a steel roof. After seeing this thread it looks like it might be a good idea. Thanks for all the suggestions, now just to find a suitable roof.
    Just Gary and Okie Pete like this.
  29. Okie Pete
    Okie Pete
    IMG_4807.jpeg Here’s what the previous owner used
    Junk yard, badshifter and Tman like this.
  30. BJR
    BJR
    In the late 60's I put a piece of blue tinted plexigl*** in the roof of a 34 Ford 4 dr sedan. The car still has it in it today.
    Okie Pete and Tman like this.
