Projects 41 Ford pickup finally got it home and pictures pictures
Discussion in 'Traditional Hot Rods' started by joel, Jul 19, 2017.
  1. v8deuce
    v8deuce
    I'm at the point in life where I don't really care for the million dollar ride give me something like this and I would be grinning from ear to ear, you sir are a lucky man!
    Motorwrxs and 1Nimrod like this.
  2. joel
    joel
    Thanks. I'm going to drive it soon, but I can't stand the rust. I can live with faded paint, chipped paint and more than 1 color, but I have to fix rust and holes.
    1Nimrod, koolkemp and 1oldtimer like this.
  3. Plans?????? I think my first order of the day if it was mine would be to get the lights wired and drive it. LOL That truck has The '****** written all over it just like it sets. ;)
    @joel neat score man. I like it a ton.
  4. joel
    joel
    I was going to patch in the headlight wires, but I ordered a complete harness yesterday. I have to clean up the headlight buckets anyway. Maybe I can steal a couple of days this weekend to get it on the road.
    1Nimrod likes this.
  5. So-cal Tex
    So-cal Tex
    What size tires did you put on the truck? Is it all stock suspension?
  6. joel
    joel
    5.90-15 front and 8.20-15 rear. The front is lower than it should be because the wrap around 2nd leaf is missing. The main is bending backwards; I think about the same effect as a reversed eye spring.
    1Nimrod likes this.
  7. joel
    joel
    It will remain as it is, except for some preservation efforts right now. Yesterday, I got the parts to install rear shocks. The wiring should be here tomorrow and I can't completely abandon the body work on the coupe. Maybe in a week I'll be on the road with the truck
    I had to weld a pin hole in the seal trough, but the back is ready for the new seal. Shiney paint really shows the dings.
  8. The 39 guy
    The 39 guy
    A little flat clear should help hide the dings a little. Make her safe and drive her Joel.
    1Nimrod likes this.
  9. joel
    joel
    I kind of liked the new blue; when I go to the hardware store, maybe I' see if they have it in quarts.:) I'm fixing the choke rod so it will be easier to start. I also have to put the headlight buckets back in and I'll be ready to install the new harness. This afternoon I'm going to put some time in on the coupe fenders.
    1Nimrod and tomschev2 like this.
  10. joel
    joel
    I installed a new choke rod and rejuvenated the headlight buckets and added the new wiring from Tyree Harris. The rest of the harness should be in by the end of today. I hope that means 5:00 and not midnight. View attachment 3621950 IMG_0633 (800x600).jpg IMG_0635 (800x545).jpg
    1Nimrod and PONTNAK123 like this.
  11. joel
    joel
    Wrong again. I got the headlight wiring back to the firewall and started removing the old wiring. I pulled the gauge cluster to get better access.... wow! It was nasty. I worked on cleaning that up and since I had the spray cans out, I cleaned the rust off the dash. I just needed an excuse to clean up that mess.
    I did get the headlights in; they just don't have any power yet. Oh, I happened to have a spray can whose cap matches the glove box door.
    1Nimrod and tofords like this.
  12. joel
    joel
    I'm still wiring but it's moving along.
    1Nimrod and Thor1 like this.
  13. I like the way you think.
    You claimed a beauty. ;)
    1Nimrod likes this.
  14. hotrodA
    hotrodA
    Good progress!
    Mine is patiently waiting for me to get started on it. Thanks for the incentive!
    1Nimrod likes this.
    What color is this one?
    TomT likes this.
  16. hotrodA
    hotrodA
    Folkstone grey??
    olscrounger likes this.
  17. TomT
    TomT
    I really don't care what the name if the color is - it looks goooooood!
  18. Good score. Friend of mine has a 41 with a helper spring in back. Its is so firm it does not need shocks. Just good springs in the seat bottom. Check to see if you have the overload spring and if you do don't waste money on shocks.
    Asphalt Demon likes this.
  19. Early Ironman
    Early Ironman
    Nobey, 1Nimrod, barrnone50 and 5 others like this.
  20. joel
    joel
    You have 2 very nice trucks. I think that I like the satin body with shiny fenders. It's like a one color 2 tone.
    No helper and actually some leaves removed; it's pretty bouncy in the back.
    1Nimrod and Early Ironman like this.
  21. Early Ironman
    Early Ironman
    Thank you very much!
    I had not seen this combo done on anything from this vintage. It is fairly common on muscle cars though. Figured I would give it a try and see how I liked it. As you can see I have kept it this way[emoji3]
    1Nimrod likes this.
  22. Rick Wiers
    Rick Wiers
    Looks like a great start, here's my 41, taken at the Lonestar Throwdown this year. LST2017 2.jpg
    Motorwrxs, Luke stone, Nobey and 9 others like this.
  23. joel
    joel
    The cab wiring and wiring forward of the firewall is done. I'm working on the tail section and replacing the copper fuel line while I'm at it. IMG_0642 (800x600).jpg IMG_0643 (800x564).jpg
    1Nimrod, The 39 guy and Early Ironman like this.
  24. barrnone50
    barrnone50
    from texas
    PERFECT!!!
  25. joel
    joel
    It's not my color, but it's a great finish and the look is perfect.
    1Nimrod likes this.
  26. joel
    joel
    I wasn't going to do this, but things came up that made it easier to remove the bed to finish the wiring and install the rear shocks. I'll probably do some preservation on the back of the cab. I'm putting a new bed on so, if anyone here needs a bed project contact me. I'm saving time and spending my kids inheritance. IMG_0645 (800x749).jpg
    IMG_0646 (800x618).jpg IMG_0647 (800x491).jpg IMG_0648 (800x485).jpg IMG_0649 (800x615).jpg
    Notice the flat green paint on the cab; is that military or just a faded Ford color?
    1Nimrod, Early Ironman and PONTNAK123 like this.
  27. The 39 guy
    The 39 guy
    I saw a T shirt at a GG show yesterday Joel. It said just ONE more car I PROMISE! Don't know why that made me think of you......:)
    joel likes this.
  28. sololobo
    sololobo
    what a charmer, congrats on a super score. One of my all time fave pick up styles.
    1Nimrod likes this.
  29.
  30. This is what it is supposed to look like Joel. This is Quality Restorations work, cast in translucent as mine was originally. A beautiful wheel for sure.
    Love the truck, keep it up. [​IMG]
    Nobey, 1Nimrod, Bandit Billy and 2 others like this.
