  1. Two pics of a BP gas station in Christchurch, New Zealand, from the 1950s and early '60s. There is still a BP gas station there, just bigger and newer, and now known as BP Fendalton. Fendalton garage 50s.jpg Fendalton garage 60s.jpg
    chryslerfan55 and Chrisbcritter like this.
  2. Auckland, New Zealand has a large harbour which, until the opening of the well known harbour bridge in 1959, relied on cars ferries for commuters wanting to get from the North Shore to get to the city. These are a couple of them. The Eaglehawk, photographed about 1938, and the Mollyhawk photographed in the 1920s and about 1949. Akl ferry Eaglehawk circa 38.jpg Akl ferry Mollyhawk 20s.png Akl ferry Mollyhawk 40s.jpg
  3. rudestude
    rudestude
    Just found this picture in a box of junk I was going threw... don't have any info on it...[​IMG]
    Sent from my QTASUN1 using The H.A.M.B. mobile app
  4. yellerspirit
    yellerspirit
    from N.H.
  5. yellerspirit
    yellerspirit
    from N.H.
  6. yellerspirit
    yellerspirit
    from N.H.
  7. yellerspirit
    yellerspirit
    from N.H.
  8. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
  9. yellerspirit
    yellerspirit
    from N.H.
  10. yellerspirit
    yellerspirit
    from N.H.
  11. Spyder64
    Spyder64
  12. yellerspirit
    yellerspirit
    from N.H.
  13. yellerspirit
    yellerspirit
    from N.H.
  14. keef59
    keef59
  15. loudbang
  16. loudbang
    Tom Madigan entered the world of drag racing in the early 1960s, when he teamed with engine builders Paul Pfaff and Dave Sowins to run a blown small-block Chevy in a home-built dragster.
    Ramchargers Don Westerdale
    Rapid Red Lang Tulsa wold Finals
    Rickshaws Of Riverside Hot Rod Aug 1961
  17. loudbang
    Radke Speed & Kustom
    Costlow & ? Larson
    MHRA??
  18. indyrjc
    indyrjc
    from Indiana
    Parnelli Jones' car in 1964 in his garage. Notice that the dual fuel filler caps are extended above the tail bodywork to increase tank capacity; in prior years they were recessed. Because tires weren't going to be changed in 1964 (Firestone designed their tires to go the distance) Eddie Kuzma rebuilt the Agajanian car to utilize a 90+ gallon fuel tank in the tail. Most roadsters had previously held around 50 gallons and ran on a three stop strategy. For 1964 teams started at least thinking about running the 500 on just one stop because tire stops weren't going to be needed. Of course, the extra fuel caused its own issues and by the time the race rolled around the Agajanian team apparently started the race on a partial fuel load about like they had previously used because they pitted on lap 55 which looked to put them back on a three stop plan. That's when they had the pit fire and Parnelli had to dive out of the car. There are several theories as to what happened and obviously something (maybe the hot exhaust) ignited the fuel during the pit stop. Joe Pittman was the fueler and when he saw the fire he did what was considered the right thing which was to shut and lock the fuel cap. This should have cut off the air supply and the fire would go out. However, in this case the tank exploded and the dual fuel caps went sailing into the air while Parnelli drove off. It's possible that because they had only filled the new tank about half way and didn't use the full capacity there was still plenty of oxygen in the tank which caused the explosion. The other theory (and there is some merit to this according to oldtimers) is that crew chief Johnny Pouelson was running nitromethane in the methanol and since nitro is oxygen bearing that was what caused the tank to go off even though the outside air had been cut off. The truth may be in between somewhere and both potential causes could have been a factor.
  19. treb11
    treb11
  20. Jim Nise
    Jim Nise
    IndyRJC
    I was in Tower Terrace one car length behind Parnelli's pit. Everything you said is true, but I would add, for some reason they shorten the exhaust. The usual slide on asbestos sleeve meant the exhaust wasn't halfway towards the end. As the fueling hose nozzle was extracted there was a noticeable pop, you could see the fuel tank internally on fire, then the closing and subsequent minor explosion of the refueling cap being blown into the stands. Lucky it was methanol, not gas.
  21. DDDenny
    36 ROKIT and loudbang like this.
  22. Old and Slow
    Old and Slow
    I see Dean Martin's buddy just p***ed away, RIP
