Hot Rods HAMB Drags!! Who is going???
Discussion in 'The Hokey Ass Message Board' started by luckys8ba, Jul 31, 2017.
  1. Tim
    Tim
    from KCMO
    @Rusty car looks so good with fenders! I had to have taken thirty photos of it tonight trying to get a single one that looks like it does in person! Very cool
    bchrismer and loudbang like this.
  2. wrenchbender
    wrenchbender
    H.A.M.B. Drags are the best found a real nice crack in the ol oil pan this morning 30 min I had it off welded up and reinstalled good god it's nice to live so far away from mokan [​IMG][​IMG]
    It's off to the races now
    Chrome don't get ya home
    loudbang and enloe like this.
  3. enloe
    enloe
    from east , tn.
    Good luck :)
    I still need to get one of your tshirts
  4. Rand Man
    Rand Man
    I made an appearance at the drags. Stayed till I decided it was too hot. Already home.
    loudbang, Tim and Sancho like this.
  5. straykatkustoms
    straykatkustoms
    Had a great time at the Drags. Like always there is a lot of kool stuff to check out. Couldn't stay as long as I wanted but it was worth the trip.
  6. mwideopen
    mwideopen
    MCMOPAR and I making are way home. Trucks doing good, been cruising 85-90. Had great weekend.
    Sent from my SM-G900V using The H.A.M.B. mobile app
  7. Roadsir
    Roadsir
    Obliterated my pinion yoke on the first p***, didn't even get a 60ft....Not even sure if I clocked a reaction time! Pretty sure it was softened from the heat:). Man, that was hot for us Northerners. 1350 mile RT and were back home.
  8. Tim
    Tim
    from KCMO
    Yeah I saw that from the starting line and thought "well, now we know if those tires stick or not" ****ty luck to have it happen right away :/
  9. saltflats
    saltflats
    from Missouri
  10. saltflats
    saltflats
    from Missouri
  11. Russco
    Russco
    from Central IL
    Man! I hated to see that. Let's try it again next time.
  12. Roadsir
    Roadsir
    Well upon further inspection the yoke failure was the result of rear folding up the leaf spring brackets. I guess the Towel City tires and Cal Tracs do work. I'm sure others may have seen this......but I am a little surprised.
    loudbang and flatout51 like this.
  13. saltflats
    saltflats
    from Missouri
    Sorry about that.
    loudbang and Roadsir like this.
  14. lostone
    lostone
    from kansas
    Yeah seen that before ! Weld on some new ones then run some 1/4" strap off the back and front of the bracket half way up the tube and weld her up solid. Boxes in the spring brackets and adds a lot of strength. Should handle your problems there ;)
  15. saltflats
    saltflats
    from Missouri
  16. saltflats
    saltflats
    from Missouri
  17. @Roadsir your coupe is beautiful. Sorry about the breakage!
  18. saltflats
    saltflats
    from Missouri
    Had to get my shameless plug in.
    loudbang, Gammz and cactus1 like this.
  19. saltflats
    saltflats
    from Missouri
  20. saltflats
    saltflats
    from Missouri
  21. saltflats
    saltflats
    from Missouri
  22. saltflats
    saltflats
    from Missouri
  23. saltflats
    saltflats
    from Missouri
  24. saltflats
    saltflats
    from Missouri
  25. saltflats
    saltflats
    from Missouri
  26. guthriesmith
    guthriesmith
    I have never had that happen, but have also never had a car that hooked up with lowering blocks. I will take that into consideration now when building my son's car since he thinks it needs to be fast...:D
  27. Nostrebor
    Nostrebor
    I'm not sure who owns the "Meek's Furniture" silver car, but he was puttin on a killer show! Another obvious example of a car dealing with a greasy track, but refusing to take "no" for an answer.
    We were down at the traps, and having so much fun watching that it should have been illegal! Thanks to all who came and raced in our blistering heat.
    loudbang, Deuced Up! and saltflats like this.
  28. Russco
    Russco
    from Central IL
    I have 3" blocks on mine. I already had the perch pads gusseted to prevent what happened to Eric. I tried to put Cal-Trac bars on mine but they hang down so low on mine it wasn't feasible. So I clamped my spring pack with 2 clamps on the front side of each spring. It helped a bit but, on my second p*** it broke the 5/16 bolts on the clamps on both springs which led to a pretty severe wheel hop. I'm not sure what you are building but if it's a 35-40 Ford with parellel leafs, if you modify the front spring mount by moving it to the inside of the frame rail and mounting the spring above the bottom of the tail instead of below the rail line the kits intend, it will both lower the car and give you more room for cal track bars too. The biggest mistake I made when building my 40.
  29. saltflats
    saltflats
    from Missouri
  30. Tim
    Tim
    from KCMO
    Any idea what @Kerry was leaking? Looked like antifreeze. Was bummed that I didn't get to see him run
