Technical '34 coupe rear window template
Discussion in 'Traditional Hot Rods' started by challengerman, Aug 18, 2017.
  1. challengerman
    challengerman
    Hi Hambers, maybe this has been done before, but thought I'd say if any one needs a coupe rear window template, I just took a window out I could use for a template if anyone needs one.
    Smoke 'em if you got 'em
  2. Good idea. Do a trace, and and maybe a picture too scale, so that it can be sent as needed.
    Thanks for offering to everybody.
  3. challengerman
    challengerman
    My thought was to do a trace that could be sent snail mail. I suppose a jpg is possible, but I'm not sure how easy it would be to convert to actual size. Depends on preference I guess.
  4. Draw a true 1x1 graph on masking paper.
    Get a good picture of that
  5. lostone
    lostone
    from kansas
    Excellent idea, and just to be super sure drop a flat dollar bill on the middle of the gl*** when you take the picture. Everyone has a Bill in their pocket so it's easy to scale too.
    Also the bad thing about pictures is they tend to distort the edges and give a false view so the idea of a 1x1 graph paper back ground should be perfect.
  6. I'll take a copy, Thanks
