Projects 48 ford sedan to business coupe
Discussion in 'The Hokey Ass Message Board' started by NewGuyOldFord, Nov 17, 2016.
  1. NewGuyOldFord
    NewGuyOldFord
  2. choptop40
    choptop40
    Dash looks great
  3. steel rebel
    steel rebel
    Can I have the two door parts?
    No I would need bigger doors.
    Oh **** you have them.
  4. NewGuyOldFord
    NewGuyOldFord
    The long doors are actually in really good shape. Was going to use them as patch panels but can't bring myself to cutting them up. I did use the sedan door posts as repair pieces for the really ****py coupe ones.
    Sent from my SM-N920V using The H.A.M.B. mobile app
  5. NewGuyOldFord
    NewGuyOldFord
  6. steel rebel
    steel rebel
    Really just kidding. Thanks anyway. Too far,too much work at my age. Maybe somebody will take the hint.
    Gary
  7. koolkemp
    koolkemp
    The dash looks great! Nice to see the first mock up pics already!
  8. NewGuyOldFord
    NewGuyOldFord
    Koolkemp..... you were a great inspiration to me doing this. I've referenced your build several times. I have a ways to go but I think I have a game plan. And thanks for the words on the dash. It's been fun so far so hopefully it stays that way. I'll keep posting pictures as long as people keep watching. I know I'll get told how bad and ugly a small block ford looks in there but there is no other alternative to me. I'm an all ford guy. Hell is put one in a riding mower if I could. I actually think Chevy motors are ugly and too cliche. BART.
    6sally6 likes this.
  9. NewGuyOldFord
    NewGuyOldFord
    I'm just putting this out there..... if anyone has some useable running boards or the outside running board trim used I'd be interested. And, if deleting the side trim, what outside door handles do you use? Thanks for everyone ***isting me on this project.
  10. BamaMav
    BamaMav
    from Berry, AL
    Haters will hate, don't let them bother you! I'm with you 100%, that's the reason I pulled the belly****on SBC out of my 47 Lincoln and have put in a 302. Keeping the bloodline pure you know!
    Clearance was pretty tight on my steering box, I ended up using Explorer manifolds to clear it, and a WIX 51311 oil filter will give you a good 2" or more clearance there, too.
    King ford likes this.
  11. NewGuyOldFord
    NewGuyOldFord
    Thanks Bamamav. I have fenderwell headers so hopefully I'll be fine. Love to see pictures of you engine compartment and rear setup.
  12. NewGuyOldFord
    NewGuyOldFord
    Could someone with a short door coupe give me these measurements? Thanks
  13. NewGuyOldFord
    NewGuyOldFord
    Could someone with a short door coupe give me these measurements? Thanks[​IMG]
  14. Tim
    Tim
    from KCMO
    They may be the same as the four door front doors in which case maybe @steel rebel could give you a hand?
  15. steel rebel
    steel rebel
    Four door #s
    And this is center of gap.
    Top 30"
    Center 35 1/2"
    Bottom 34 3/4"
    I wally wish I had your energy. I would buy your leftover parts and make me a two door sedan.
    Tim likes this.
  16. NewGuyOldFord
    NewGuyOldFord
    Thanks steel rebel. I want to get things welded together straight and your measurements will help out tremendously. Once again, thanks.
  17. NewGuyOldFord
    NewGuyOldFord
    Steel Rebel, were they at the bottom edge, at the accent line by the door handle and the top at the window curve? Thanks.
  18. steel rebel
    steel rebel
    Old Ford
    It is pretty difficult to get exact measurements 3,000 miles away. Think you should measure the inside of your door and add maybe 1/2" tack then fit. Their are so many curves and not square lines it is impossible to know if I am measuring in the same place as you, and this is critical stuff.
    Sorry
  19. NewGuyOldFord
    NewGuyOldFord
    It's fine. I think you'll get me in the ballpark. I'm going to use your measurements plus the door gap and go from there. I appreciate all of your help. Hopefully I can make something out of this.
  20. 1-SHOT
    1-SHOT
    from Denton
    IMG_0939.JPG Square the door up to the rocker and it will tell you where too put everything else. Build it like a house from the base plate up. Be sure to add for shrinkage when you weld.
    Use a wrench as a gauge to space your gap , it's quick and handy and I have used this trick over 60 years. Always set your door in the center of the adjustments slots so you have some room after you weld.Remember when you have the cowel cut loose from the roof it tends to fall back and you may have to jack it foreward, once you have the door and cowel squared up to the floor you can proceed with the roof and 1/4 panel. I hope this will help you. PM me if you have any questions. Frank
  21. NewGuyOldFord
    NewGuyOldFord
    Now I have it sitting and waiting to bring the mercury frame down to the garage so I can get the body mounts cut off of it and other essential salvageable pieces. [​IMG]
    koolkemp likes this.
  22. NewGuyOldFord
    NewGuyOldFord
    Hey Koolkemp, do you think there is any way to maintain factory running boards with doing the rockers the way you did yours? Thanks for your encouragement and I hope your health is staying steady. Here is another project my dad just bought and I drug it to the garage. It's getting crowded in here. [​IMG][​IMG]
    Chrisbcritter likes this.
  23. koolkemp
    koolkemp
    Honestly I don't even remember what they looked like, I may not have had a pair... I don't see why not though, should be pretty straight forward I would think? I can take a few pics if you need any ideas.
  24. NewGuyOldFord
    NewGuyOldFord
    Squablow likes this.
  25. NewGuyOldFord
    NewGuyOldFord
  26. NewGuyOldFord
    NewGuyOldFord
    Could someone give me the answer to this question? When installing a SBF 302 in my 48 can I use a fox body oil pan instead of an early Bronco pan? Thanks.
  27. NewGuyOldFord
    NewGuyOldFord
    If there is anyone in the Pennsylvania area or surrounding states that had an affordable usable coupe/ convertible trunk lid please private message me. I think I've met my match with the one I have. Thanks.
  28. NewGuyOldFord
    NewGuyOldFord
  29. NewGuyOldFord
    NewGuyOldFord
  30. NewGuyOldFord
    NewGuyOldFord
